Black Hole Vu+ Solo2 2.1.5
good work and greeeaaaaat thanks bh
but i not comfortable about the new move of menu vanishing its make me like daze
can set it as the menu come and go in bh 2.1.4 ?
Hi...
Cannot install any IPK on this image.. It gives an error saying unknown package
PKG _hash_fletch_best_installation_candidate: Package for enigma 2 plugin ******* found but incompatible with the architectures configured
OPKG Install CMD cannot install package
Any idea ??
Thanks
How we can set other boot image when curently booted image is corupted or not start ? After restart always start from this image, and can't set other becouse no boot menu.
Any other way ?
You can change or disable animations by its setup panel.
Menu > Setup > Sistem > Animations
Hi...
Any idea ??
Thanks
You have used * to hide plugin name ... so probably is a plugin not welcome here .... so it's only your problem if you can't install that on your box.
