Sorry, I don't understand the answer.
The thing is that I have own IPTV list of working internet channels which works in 2.1.4 and not anymore in 2.1.5. The stream name begins with 1:0:1:1:0:0:0:0:0:0:<ip-adres>
I don't like the skin that much.
Where can we find the skin MX_black found in 2.1.4 and in beta 1 & 2??
The one found in the BH repo isn't the same.
Where can we find it??
for now
We are located just at the beginning of Moving to OpenGL and other changes.
This causes problems that need to be resolved.
This applies not only to this but more needs to be polished.
Moving forward
You need to be patient ,There's more important things to Fix
if there is a straightforward solution that will be implemented.
VU+
is moving to the new code, among other things OpenGL
and IPTV for now does not work.
So we wait for a fix for it.
Until then, you can not use IPTV in BH 2.1.5 as far as I know.
Hi, after the update to this version the display of decoder in standby don't show the date, only the hour, is normal? Before the update the decoder in standby show hour and date. How can i reactivate the date in stanby?
