Black Hole Vu+ Solo2 v.2.0.1 OE 2
Hello.
Is it so difficult to implement subtitle settings options into BlackHole image (as it's in OPEN PLi). Because there are lots of people who likes to watch movies with subtitles (especially from their PC through streaming) but it's really painful not being able to adjust subitlte color / font size / position etc... Actually since there is no spesific setting area in this image we can only see subtitles with White color and default size and default place on the screen.
Below you can see what I need :D As you can see subitltes are yellow, fonts are big enough to see far away and position is the best. I would appreciate If this seperate menu can be implemented in this great image.
I totaly agree with you. Subtitles are the weakest point of BH. They arent good enough when we use the standard ones.
Anyway... try this, like I did another time and for me it's better than nothing (close to good). Install Font Maginifer plugin from BH servers, and with that plugin you can adjust many things on all subtitles (teletext or mediaplayer subs)! Also you can choose the font and size you want :)
Try it and let me know !
Regards
NEW: Support to NTFS usb sticks and external hdd. You can map your NTFS devices in
Devices Manager: Main menu -> Black Hole App's -> Device Manager
it's not work with my ntfs usb drive (seagate portable 1TB)
Device Manager add in fstab this
/dev/disk/by-uuid/C860DB1160DB055A    /media/Point3    auto  defaults    0  0
but after restart disc is not mounted.
I try few times but no effect...
I tested with NTFS USB stick
and for me it works without problems.
USB stick is NTFS formated
I can copy the files on the PC
and listen the music on the box.
Other colleagues from the team tested with USB HDD
with the same positive result.
ok, i understand but for me not work.
i think that's need more delay to mounting ntfs device.
As i write earlier, when i add mount line to end of rc, then work ok.
I think that this is in relation with your HDD
or the power supply for it.
So he needs more time.
And perhaps because of the large number of mounts you have.
I do not know. I am not a specialist in that.
I know that it works.
Maybe Coder knows the answer.
But it works with NTFS USB HDD.
Let's wait for the results of other users
my drive is correct recognized by stb
fdisk -l
Disk /dev/sdc: 1000.2 GB, 1000204883968 bytes
255 heads, 63 sectors/track, 121601 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
   Device Boot      Start         End      Blocks  Id System
/dev/sdc1               1      121602   976760032+  7 HPFS/NTFS
[EMAIL]root@vusolo2:~# [/EMAIL]
no power problem (in other images work ok)
Let's wait for the results from other users .
I think Coder can make changes if necessary.
So who has a USB HDD NTFS pls test
and write abt your test result.
Regards
Thank you so much fore this Font Maginifer plugin it's really good (not the best as you told) to change size + font. But we still need color change. :wallbash:
In fact I tried to change the color of the default skin with changing subtitle color code in the skin.xml file as you can read below. But once I change the color and restart the device, it no boots. :eek: I do no know why because If I change font size, there is no problem.
Is there any programmer here about this subtitle color code issue?
PS: This skin.xml file is under /usr/share/enigma2
You have not forgotten #bab329 (and LINUX EDITOR)
and not only bab329
But this is only for teletext subtitles and not DVB subtitles.
DVB subtitles color you cannot change in skin coding.
@Emre, unfortunately I cant help you with subtitles color, because I use default color, which is nice for me.
btw... which font are you using now? :)
The only thing bothering me is the subtitle position, because I think could be down a bit more. Is it possible to edit that for MediaCenter subtitles?
and not only bab329
@Matrix10, I do not want to change DVB Subtitles color (like "BBC HD" in 13E). I want to change optional subtitles color of the supported channels (like SKY IT package in 13E) and I am pretty sure this can be done in skin coding because I have done it for HD Glass skin.
You can see my screenshot here that I have applied for HD Glass with another 1.6 image (not BH). But I do not know why BH skin.xml does not accept that (I mean it causes booting problem)
Sky ITA using only Teletext subtitles
and you can change color in skin.xml
you can change font and font size for subtitles.
and looks better than on your shots.
But i not like this yellow color.
Example MX HD X2 mod
with the same color and font size you use in your coding.
font="Regular;44" foregroundColor="#f4fa58"
Thank you but once I try your advice, as you can see below. Same not booting issue stands :wallbash:
Maybe I should install MX HD X2 mod? Any idea?
These are now already, skins questions.
I would ask you, ask them in the skin section.
for Finals
in the zip is skin.xml of MX X2 BH 2.0.x Hi-color
Downlaod skin from server and replace skin.xml
restart
Since I downloaded the 2.0.1, most of the HD channels which are on Symbobrate 29500, aren't working. Any ideas ? ?
