Black Hole Vu+ Solo2 v.2.0.1 OE 2
There is a conflict between internal OpenEPG and CrossEPG, uninstall CrossEPG.
And it's not recommended to use Software Manager to load plugins, use BH panel (traces of old Webinterface inside of your system).
NO
FATAL: epgcache.cpp:150 ASSERTION pos <= 4108 FAILED!
I do however have a different opinion
especially after intensive testing.
This error we had without CrossEPG in the images (not only bh image)
The error in the log does not mean conflict between each epg
but bad EPG data in the EPG.
Enigma Protective react and release / crash.
So there is no need to remove CrossEPG
On the contrary.
CrossEPG works very well, this is more question of good data on EPG server or sat.
EPG quality on them.
Do not forget we have a new option in the panel for the EIT
with which you can select the appropriate EPG
with priority for NET or Satellite EPG.
So experiment until you find the best solution for yourself.
Sometimes EPG crash
is inevitable.
A small error in the EPG data will crash
E2 system.
Still getting green when changing city in BH weather plugin.Please fix it, really like it.
I have no problem in my tests.
If I remember
I saw earlier your log.
you had a problem with obtaining information
from Weather Server.
Network problem or no data on Weather Server.
Thanks for respond. here is my crashlog
It looks like you've got network problem as MX mentioned above.
If not - I'd try to use this plugin on default skin, if it doesn't work - you probably need to reflash the image I'm afraid.
You use hdglass skin ATM, so you've had to modified original image - your action could corrupted some files and that could be the result
Im sorry
You can use what you want in your box, but without support.
We do not have time for that.
We do not provide support for those who do not use skins from BH image server.
We will not investigate here
why something does not work with skins that change the structure of python coding.These are image modification and fall outside our circle of support.
Im sorry
Thank you very much darian23 and Matrix10! and sorry for bothering you! Now i know the source of my trouble.
BH - the BEST!
i did fresh install,after i just set network and made online update (didn't make any restore) - and again got a green after trying change city in weather plugin...
sorry for bothering everybody again...:lamo:
You have networks problems (check DNS & Gateway address) or the Yahoo server are too busy.
The error is: Connection timed out.
Thanks for reply!
As i said - just before trying plugin, i installed BH update online, and im subscriber some ip tv (using plugin for that on my solo2), and i did test from network menu - its ok...
maybe i cant reach some URL from Ireland?! but on previous soft its was ok..
Everything else is working fine! And for me picture sharper and deeper!
Thanks again for great software!
i mount to /universe 2gb partition on my usb stick, but in telnet
df -h
i see only 473,7M for universe....
root@vusolo2:~# df -h
Filesystem                Size      Used Available Use% Mounted on
ubi0:rootfs            196.6M    101.7M    94.9M  52% /
devtmpfs                  2.0M    124.0K      1.9M  6% /dev
tmpfs                  279.2M    952.0K    278.3M  0% /var/volatile
udev                      2.0M    124.0K      1.9M  6% /dev
tmpfs                  279.2M        0    279.2M  0% /dev/shm
/dev/disk/by-uuid/4ec48adb-c222-49ac-b389-ba4a81235dea
                          1.9G    59.5M      1.7G  3% /media/usb
/dev/disk/by-uuid/70b644da-e0cc-42b2-9255-7bb5178124da
                        584.3G    450.0G    104.6G  81% /media/Point2
/dev/disk/by-uuid/72833415-d3c5-4cb4-beaa-863b61f89edd
                        10.5G    154.7M      9.8G  2% /media/hdd
/dev/disk/by-uuid/cb9ab5b1-deb3-4f57-84e7-1d518d3c53ec
                        473.7M    32.9M    416.3M  7% /universe
[EMAIL]root@vusolo2:~#[/EMAIL]
Why ?
Thanks for reply!
That's weird. On-line update works but weather doesn't.
I do not know what to write actually.
You can try to download image again.
Angelofsky suggested another solution.
You can try to use dhcp instead of manual configuration and check again.
Check your PC settings using ipconfig command and set up vu with similar ip addresses (mainly gateway and dns')
Thanks for reply!
I'm in Ireland and everything is ok with my box..
Thanks for your entry mate.
BTW he is there too :)
You could try to post your network settings it may help other people too.
If you can post your dns and gateway it could be good.
But everything depends from his router /well, if he has any/
His dns starts with 89.xx but I do not know if that's the right one (should it not be his router if it can handle server names service?)
I'm sure you can help him out more than myself - however we need to know a bit more about devices on his network....
I'll be glad to help if I could..
is it the attached screenshot you asked me to take ?
Thanks for your concern.
As i said network is working for me, solo2 has the same gateway and dns setting as my all devices in network . When i start weather plugin i see forecast for Rome and its changing.Green happens when i try to change the city, even if i push ok for Rome:). Dont want to think about it, if its a way to change city manually...
