Black Hole Vu+ Solo2 v.2.0.1 OE 2
I really have no idea,If you have installed agn clean image.
Hopefully it's not HW problem.
Try an older image and try the original image.
fan always work in standby.....even when i set turnoff in stanby to yes....
now i try other image....
Other image test
ok, i found something...
When turnoff fan in standby-yes
fan work in standby until hdd go to sleep. When hdd slleep fan also stop.
When turnoff fan in standby-no
fan work always.
no i back to BH, and test :)
fan looks like to be intelligent :D
in BH image fan always on in standby.....
i found bug in manual fan control plugin included in BH image.
Default work ok, but when i change option "turn off in standby" to "no" (i want to fan work in standby) fan still stoped in standby and not start when stb start from standby.
then
now i install fresh 2.01, upgrade to 2.0.1a.
i set pwm to max, and test fan, but now fan not off anymore in standby....
any sugestions ?
is it a joke?
what are you trying to say?
I've lost the plot - your single post denying next one..
Please review your point of view :)
summary.
fan work in standby when hdd work/not sleep, even when we set in manual fan controll "turnoff in stanby" to yes. When hdd go to sleep fan is stopped.
end transmission ;)
I was wondering if anyone could tell me if there is an option for changing the position of the smaller picture in PIP(picture in picture) and if I can change it's size.
Hello all!!
Thanks for this nice image, only one small issue, just tell me why is it:
Diseqc actuator,
-setting: SIMPLE
-Position .given the proper geo data
-The motor NOT move, not even have a signal at any sat-
If the setting is : Advanced
every sat is cofigurated each by each it works.
-The thing is that the simple setting worked, and it works with other enigmas..
what can be?
Hello all!!
Diseqc actuator,
-setting: SIMPLE
what can be?
what motor you have?
Its a diseqc hh actuator, the type is not relevant, i tested it at many types, amiko, moteck, .... Works only when advanced,
Oh yes, i went bact on 179 and works smootly as it should ... Simple settings and the coordinates..... This is faild on 201
I do use motor, not actuator, and don't have any problems with usals. Not sure how your actuator can work with usals without vbox because these kind of motors are compatible with diseqC 1.2, not usals.
That's why I asked about your motor type. But you know what you have and it has worked before with usals then should work with new image as well.
I see, but its works perfectly now with 179 i told u. thanks you care, this issue its not a big problem, becouse it can work in advanced mode, but maybe the swf writers can do fix it in 201 too...
Amiko DM3800 this is what i used last,and im using it now .. but ,how to explain: its not about the motor, im tellin you again. Here is the other place of mine:
-V box vith 18" regular jack and the remote control, manual positioning,
-Set the same : simple and usal positioner coordinates.. manually moving the actuator, NO SIGNAL.. so ,conclusion: no signal with these setting.
-Same hardware, same everything- but ADNANCED mode, every choosen sat configured ... works Good..
The thing is:
-simple settings-usals is GOOD in 179-- wondering what i need to set, or is this a bug.. but no any bad feelings, just curiosity..
