Black Hole Vu+ Solo2 v. 2.0.4
There is a NEW MENU to select the default subtitles.
Now, when I setup the default subtitles is not need to REselect everytime I restart my box, when I go to channels with subtitles ;)
Ah! Thanks for letting me know :)
Isnt what I expected... anyway...
I think it's not possible to customize font or else (if this is what you want), because the subtitles are a stream customized by owner...
I dont wanna be offtopic again, but you can do it with a plugin called Font Magnified. You can download that from BH server :)
As I have already said, it is only a stream, which can not be changed, but can be enlarged.
The font characters are not customized. ;)
Just upgraded from 2.0.2.
BIG Improvements on image quality!
Menus are lightning fast and a lot more classy than before!
Thank You BlackHole Team :notworthy:
i used 2.0.3 first and i remember an option to dim the vu+ solo2 lcd display
cant seem to find that anywhere in this version
did it get removed?
I tried a plugin that says its for ultimo only.... wierd
did it get removed?
No m8 it's still there. Go to menu/setup/system/display set up ...
I install just now the new image and at finish of primary settings i tried to restart the image getting green screen.
The second restarting was fine. Why that' s happen?
Also i get green screen on my first automatic search (channel search).
I don't understand why...
Generally in BH images using automatic search ( for channels), some of them are seems without signal and i cannot connect with them.
Using saved list by BH , like hotbird for instance, i get connection.
Is that a tuner fault or dish problem?
i have just flashed bh 2.0.4 and cross epg will not download i have
selected open 28.2 and pressed download it just hangs on the front
screen can anyone tell where i can re down load cross epg thanks
Beer in hand its update time! Off to do clean install and setup from scratch because I'm bored, Wish me luck!
Sent from my HTC Sensation Z710e using Tapatalk 2
I'm going to try BH for the first time as I have always used other images. Can you please tell me which folder I should be putting in USB root? Is it vuplus or solo2 (this one is in another layer in vuplus folder)?
I must it this image looks amazing.
