Black Hole Vu+ Solo2 v.2.0.6
Hi, I'va a brand new VU+ Solo2 but I'm not able to load the BH 2.0.6.
I place the files unzipped in a usb flash (w/o any folder) switched ON from the back main switch the decoder, the USB flash LED it blink but no reboot and the firmware is the std one.
I've formated the flash FAT and try later also FAT 32....
What I'm doing wrong?
Remove all devices usb connected to your receiver before to install the new image and follow all the advices you can find here: How to update Vu+ images
Hello, i have a problem both with 2.0.5 and 2.0.6 on vu solo 2. Wherever i go to choose flash usb, either for backup or as download location the receiver stucks and the circle spins at the upper left till i close the receiver from switch on the back. Any ideas?
Today after I have upgraded to blackhole 2.0.6 Release C, Recording function malfunctioned in my Solo2 receiver.
When I tried to record any channel, I receive the following error message.
"Couldn't record due to invalid service
1:0:1:2870:800:2:11A0000:0:0:0:"
I realised that the problem is not because of the blackhole 2.0.6 Release C. Yesterday I activated the EPG update plugin and this plugin has put some weird entries in to the timer and the recording problem was solved after I have deleted these entries.
(w/o any folder)...The files for my Duo2 are in a folder. I do not think they would load without it. Try downloading BH 2.0.6 and unzipping it. Do not remove any files from any folder(s) after unzipping the 2.0.6. EB
Hello dyilmaz
I have the same problem
Could you please tell me what exactly you did?
What entries you deleted and from where ?
Hello dyilmaz
ok :)
As dyilmaz, I found the solution...
It was an entry in the timer.
I don't remember to do by my self...
I deleted it and all now is working ok.
