Black Hole Vu+ Solo2 v.2.0.6
Another question guys. On BH 2.0.6 and 2.0.5 too, i can't use PiP from two different Transopoders. I have a motorized dish and the cable is connected to Tuner B. Whatever choice i use for Tuner A like loop throught or same tuner or.... i can't use PiP from two different TPs at the same time and in addition if i want to transcode one channel to another Device, i can't use the second tuner to do this, so if i watch tv on laptop through streaming, the receiver's picture get black on the TV.
What am i doing wrong?
You need two indipendent tuners to do all you write.
With a single cable and the second tuner configured as "loopback ..." you can see/transcode only channels from same TP and/or same band (H/V)
Is it the same thing as if i put an LNB with two outputs and every output to each receiver's tuners?
Can an LNB that has two outputs sychronize two different tp's at the same time?
As I mentioned above, I have a motorized dish and I like searching the feeds of satelliweb.com
When I search dvb-s feed I can choose auto in fec. When I have a dvb-s2 feed,there is no choice of auto! I must search between qpsk and 8psk all the fec fractions to find where do I have signal... Can you add auto choice for dvb-s2 too? Can you add search button on the signal checking menu so when I find the feed I can search the tp at the same time? Thank you!
I'm almost certain that issue has got nothing to do with BH images which are based on VU+ original ones. Ask VU+ to change that if at all possible ....
I`am new to BH 2.0.6. After installation I do not have access to my box VU+ uno by FTP and DLNA (can`t see on my computer). I use windows 8.1. Please advice.
