Black Hole Vu+ Ultimo 1.7.6
lorenzo64
What's New
New Green Panel Setup
- Customize the plugin list. You can now assign a progressive position number to plugins.
New drivers Vu+ drivers 20120628
- Improve vtuner performance
- Support 2 zapping mode(hold, mute)
- Optimize memory usage in demux driver
- Change dual tuner locking mode
- Support streaming interface(Remote Channel Stream Converter)
- Support H/W Graphic2D acceleration for HBBTV
- Fix incorrect VFD display(duo, uno)
New Skin Army TranSpaRency HD
- Awesome skin with low graphic impact. Another little masterpiece of our master Army.
New Plugin AddStreamUrl
New Plugin ZappingModeSelection
Add support http ts stream.(client)
Disable hdmicec plugin' for default
Load Bouquets' support for non dvb services.
adjust kernel config for size reduction
WirelessLanSetup : fix bug (AP's protocol info is None)
StreamTv plugin: fix bug.
WirelessLanSetup : If wireless lan module is activated, do checkIfaceMode
WARNING: This Image is not compatible with the previous skins
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Time Shift
Button Red = Red Panel (Parallel Universes Teleportation)
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Red Panel
Black Hole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
  • BlackHole-1.7.6-vuultimo_usb.zip
Matrix10
info about adding link in to SAT bouquets with edit (not remote)
working examples :
#NAME Favourites (TV)
#SERVICE 4097:0:0:0:0:0:0:0:0:0:rtsp%3a//hdimages.cdnvideo.ru/rr/HDextremeCDN
#DESCRIPTION HDextreme
#SERVICE 4097:0:0:0:0:0:0:0:0:0:rtsp%3a//hdimages.cdnvideo.ru/rr/HDprocessCDN
#DESCRIPTION HDprocess
#SERVICE 4097:0:0:0:0:0:0:0:0:0:rtsp%3a//hdimages.cdnvideo.ru/rr/HDtravelCDN
#DESCRIPTION HDtravel
#SERVICE 4097:0:0:0:0:0:0:0:0:0:http%3a//93.95.98.28%3a8100
#DESCRIPTION HD MEDIA (RUS)
#SERVICE 4097:0:0:0:0:0:0:0:0:0:http%3a//109.238.237.194%3a8084
#DESCRIPTION VOICE OF ABKHAZIA HD (RUS)
#SERVICE 4097:0:0:0:0:0:0:0:0:0:rtsp%3a//fms.zulu.mk/zulu/mtv1_1
#DESCRIPTION MTV
#SERVICE 4097:0:0:0:0:0:0:0:0:0:rtsp%3a//fms.zulu.mk/zulu/a2_1
#DESCRIPTION A2
#SERVICE 4097:0:0:0:0:0:0:0:0:0:rtsp%3a//fms.zulu.mk/zulu/sitel_1
#DESCRIPTION SITEL
#SERVICE 4097:0:0:0:0:0:0:0:0:0:rtsp%3a//fms.zulu.mk/zulu/kanal5_1
#DESCRIPTION KANAL 5
#SERVICE 4097:0:0:0:0:0:0:0:0:0:rtsp%3a//fms.zulu.mk/zulu/telma_1
#DESCRIPTION TELMA
#SERVICE 4097:0:0:0:0:0:0:0:0:0:rtsp%3a//fms.zulu.mk/zulu/nasatv_1
#DESCRIPTION NASA TV
#SERVICE 4097:0:0:0:0:0:0:0:0:0:rtsp%3a//fms.zulu.mk/zulu/alsat_1
#DESCRIPTION ALSAT
#SERVICE 4097:0:0:0:0:0:0:0:0:0:rtsp%3a//fms.zulu.mk/zulu/sitel3_1
#DESCRIPTION SITEL 3
#SERVICE 4097:0:0:0:0:0:0:0:0:0:rtsp%3a//fms.zulu.mk/zulu/kanal5plus_1
#DESCRIPTION KANAL 5 PLUS
#SERVICE 4097:0:0:0:0:0:0:0:0:0:rtsp%3a//fms.zulu.mk/zulu/jungle_1
#DESCRIPTION JUNGLE
#SERVICE 4097:0:0:0:0:0:0:0:0:0:rtsp%3a//fms.zulu.mk/zulu/btr_1
#DESCRIPTION BTR
Yo can also add channel name like this :
#SERVICE 4097:0:0:0:0:0:0:0:0:0:rtsp%3a//hdimages.cdnvideo.ru/rr/HDextremeCDN:HDextreme
or like this
Pay attention
You have to replace : in link with %3a
example :
http://109.238.237.19:8084
Bouquet :
drfox
fantastic job from black hole team thanks again for year's support from you for our stb you are best of the best
koyote_0942
I have BH 1.7.6 in flash and so 17.6 in multiboot with meoboot,but in my imagen 1.7.6 multiboot I can not mountpoints my hard disk only media/meoboot
ziir
thank you for this great image black hole but i just wanted to inform that i have a slow internet if i use wirless connection ,
my old image was good but this one i f i use ftp need to send files short file it takes long and this is bad
Matrix10
Totally unnecessary to have a double image .
Better use UNIVERSE
because all you installed in the UNIVERSE (not in BlackHole universe) goes to the USB stick.
Univerese is ideal
because you can install and test on the USB stick (In Universes Avalon,Chaos,Ghost) plugins as much as you like
without effect on base image in flash (Black Hole Universe)
and without risk to gone wrong with flash image BASE Black Hole UNIVERSE
Matrix10
Tested,
For me there is no difference Im using orginal VU+ USB dongle. (144Mb/s)shot3.jpg
I think that's a problem with your local connections ??
Matrix10
i dont know i have also the original ;usb dongle i dont know why it is slow
Is your USB wlan dongle near the USB stick
if so move it wlan to the front USB connector
and try to restart Router
(Of course the question is what is the speed of your router )
The truth is mine network is also faster with wire network
But USB is fast enough ..
Stream HD with my network drive goes perfectly with both connections.
