Black Hole Vu+ Ultimo 1.7.6
yes the original dongle.
wlan0 unassociated nickname:"WIFI@REALTEK"
If you have a USB stick together with USB Wlan dongle in the back connectors
then some USB stick can make interference / noise to WIFI dongle.
Test without the USB stick
If the dongle is working ,Try another USB stick.
Sorry I'm a bit confused......Whats this then??
If you read the section it was post in, you will see, it is part of the drivers update package.
New drivers Vu+ drivers 20120628
- Improve vtuner performance
- Support 2 zapping mode(hold, mute)
- Optimize memory usage in demux driver
- Change dual tuner locking mode
- Support streaming interface(Remote Channel Stream Converter)
- Support H/W Graphic2D acceleration for HBBTV
- Fix incorrect VFD display(duo, uno)
As I said before, HBBTV is being worked on by Vu+ and once it is ready they will release it.
i test with tp link tl-wn722n its ok
Since the patch for the correct display of the date, the layout of the channel info and the translation of Italian texts are never added to the various packages upgraded, you place the following files:
BugFixPack_BH_from_v1.7.6_01.bh.tgz -> Package includes fixes just released updated;
Language_MeoBoot_v1.0_IT-ES-TR-RU_v1.bh.tgz -> Translation of MeoBoot;
Update_Language_IT_03.bh.tgz -> Italian translation system.
Thanks for the continued development
Diamondear
