Black Hole Vu+ Ultimo 1.7.6
Hi since the latest blackhole 1.76 image , icant use the pause, forward, fast forward buttons (3,6,9) on my Nstreamplayer plugin (nvod) someone any idea?
Regards,
Alex
Regards,
Alex
I also have this problem. Cannot pause, rewind, forward streaming content on bh 1.76
All I've tried avi files have the same problem. I have the same problem as emortal friend.
But everything else the firmware is going well.:rolleyes:
I cant add in timer recording for radio channels i have stored in my V+ ultimo favorite list. See attached. How i can add timers for Radio channels in webinterface? There is only TV channels in timer list if i press add timer in html browser. I added in radio mode 10 channels to radio favorite list. They are not showing up if i want to add radio. TV timer recording is not a problem. I speak to developer team because i really need that option to record radio channels. And i think many users will thank for that. Please answer!!!!
Ich habe auch screen problem. alles ist nach rechts geschiftet. In AV optionen helfen nicht.
Hi guys, I was wondering if anyone could help as I am trying to get my ultimo to mimic a sly UI for my other half and have been having trouble with timeshift not working properly or at all from the add on menu. Any help to being able to create an easy to use format that would appeal to the technically challenged would be much appreciated.
PS on BH 1.7.6
Hi!
I have 4 tuners in my Ultimo. 3 * T tuners and one T2 tuner (USB, 290e)
Problem is that I would want to have use specific tuner on specific channel. T2 tuner on HD channels and T tuners regular channells.
HD channels on Terrastial network need to have T2 tuner. I can find those channels with manual search but when I try to change on that channel, nothing happens. Black screen. Seems that ultimo tries to show this channel with basic T tuner and that won't work.
So is there anything you can do with following releases?
Hi!
Set the tuner priority on T2 tuner prior to anything other tuner.
Sent from my iPad using Tapatalk
Yes I know that but problem is when record from regular channel is launch and T2 tuner is 1. priority. T2 tuner is then reserved for regular channel.
If same time record from HD channel is started, Ultimo will try to use regular T tuner for that. It won't work.
Did I make myself clear :)
Brilliant Image.... so many aspects work great.
But i've started having issues with Timezone and TP sync.
Not sure if this has happened after i Backed Up the image on USB stick, then re-flashed it... or if it had been this way the entire time.
Vu+ Ultimo
2 x DVB-S / 1 x DVB-T
Blackhole 1.7.6
Build July 8th 2012
Time is incorrect on OSD, as such, the wrong programs are being displayed on Channel List, when i channel is selected however, it quickly updates/syncs from the TP and the correct program in Now/Next is shown... Yet OSD clock is still incorrect.
Have tried selecting another TimeZone from menu to get OSD time near to correct, yet channel list is still incorrect.
This happens on DVB-S and DVB-T in exactly the same way.
In my case, it is showing programs that are 4.5 hours in advance.
sorry, hope this is the right place to ask?
