Black Hole Vu+ Ultimo 1.7.9
lorenzo64
Black Hole 1.7.9
What's new?
  • Vu+ drivers: 20121025
  • Enigma2 ver: 20121202
  • New skin: Army Touch HD
  • New: Support to 32 bit png
  • New MyTube fix
  • Update: HbbTv
  • New New New: Black Hole Speed Up
About Black Hole Speed Up:
As you know a large number of plugins are installed by default in our images.
During startup Enigma2 has to scan and check all the installed plugins.
Many of us don't use all of these plugins.
The new Black Hole Speed Up feature allows you to disable/enable the default plugins without having to completely remove the plugin.
By disabling all the plugins we are not using without having to remove them enables you to reinstate them at any time.
This will speed up the image performance.
WARNING: This Image is not compatible with the previous skins
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Time Shift
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Red Panel
Black Hole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
  • BlackHole-1.7.9-vuultimo_usb.zip
scoot1690
fantastic image guys and hbb tv working fine best image yet by far well done for your hard work have a very happy chrismas and happy new year when it comes
scouser
Hi, has anyone tried this image yet ? I downloaded on friday and just installed comes up with version 1.7.7 so I re downloaded just 15 mins ago and installed again and checked version number and is still 1.7.7
Basil
Mine says...
Image:
Firmware: BlackHole 1.7.9
Build: Dec 6 2012
I think you didn't download the new version.
Check again.
Sent from my GT-I9100 using Tapatalk 2
