Black Hole Vu+ Ultimo 1.7.9
Anyone know if this contains or builds on the drivers from the latest official image? Is it a case of simply installing the official image and then the new BH image?
Cheers
No need to install the latest offical image first, as it would be erased when you flash to Bh image anyway.
The current Bh image has the latest drivers already installed.
If you have an old image installed at the moment, then you would need to do an FPGA update first (do a search on the board for how to do that).
Hi
When go into "manage extensions" it says there is at least 33 updates available.
When I press update (yellow button) it says " following tasks will be done after you press OK" but the update list is empty.
Can anybody help?
Hi
Can anybody help?
If you use BH images you should NOT execute "Online updates".
Thanks!
So I should not update between Black hole realeases?
What about plugins updates?
Update from one revision to another of BH images are done via full reflash.
You can do Personal Backup and transfer your settings and your things from one image to another.
i miss the delete option when i have seen a recorded show.. is this some things i can add myself? the rest of it is fine :>
Open the recordings list, select the one you want to delete, press the Menu button and select Delete.
