Black Hole Vu+ Ultimo 2.0.3 Hyperspace
thanks
on my way to install new BH image
current image is 1.7.9
can you recommend a way to not loss my settings and configurations,
thanks
thanks
thanks
This will be hard to doing becouse new Bh 2,0,3 no will be see personal backup made in older image.
Maybe Try copy your setting ; etc ny ftp and next past in new image.
But best will be made all friom begined becouse image from 2.0.0 based on new OE 2.0
Just when you think it can´t be topped you turn around and drop a better and more stable image than your master piece. I really appreciate all your work, many thanks to you and yours. Peace.
hello
Disk my book 4Tb (NTFS) with a Black Hole Vu+ultimo 2.0.3 Hyperspace does not work (with the Black Hole 2.0.2 rev. E worked fine)
what's the probleme???:(
I connect my external HDD western digital , when I go into mediaplayer, it is recognized but when I get inside it shows nothing!
What kind of media files do you have on your HDD?
What kind of filesystem use?
Have you mounted the HDD correctly with Device Manager?
