Black Hole Vu+ Ultimo 2.0.3 Hyperspace
but i mounte it to /universe.
blue blue Device Manager, choose usb and mount to /universe by pressing right till mount and then press ok. then it reboots and when i press red long, nothing.
If the mount is not ok it is not mounted.
check the device panel and be sure that the device is linux ext4 formatted and mounted.
Yes i checked Device Manager, it was formated ext4 and mounted to /universe.
After several times it works. i don´t know why, but it works. Thank you for your help.
this is a newbie question the ram is allocated to speed up the system. Not busy.
I posted many times about.
Ppl that don't understand ram managment under linux use script to free ram, but this slow down performances.
Oh sorry, i am a newbieeeee.
sorry i was not nice, it is not a newbie question, many expert users too fall in confusion between ram in use and ram cached/buffered.
it is only that this was disucssed many times and i posted a dedicated thred about memory managment.
There is an issue with some C-Band signals. For instance 3960 H DVB-S2 30000 8PSK 5/6 on Asiasat 5 will not scan, either will 3920 V DVB-S2 29720 8PSK 5/6 on Measat 3. Since 1.77 these transponders and most likely more DVB-S2 8PSK signals on C-Band no longer work. I have had to revert to 1.76 Black Hole for these transponders to work again. Before you ask, there is heaps of signal on both transponders, I am using a 3m dish.
Fresh Install BH 2.0.3, cant get the green button to work.. no green panel. Any hints?
Edit: I was too fast here, i used a Ultimo with orginal image... :p Upgrading now..
bonjour je suis nouveau et il met impossible de mettre ts media ou ts panel ou ts onlinetv
This is International section and only English language is allowed. Panels like TS are not supported in this Board: read Board rules please!
