BlackHole Vu+ Duo 1.6.6
ok guys...i cant seem to get ****** 1.35a or 1.37 to work...***** works fine....i edited the newcamd.list with my N line and entered and save dthe following
CWS= 123.165.456.21 12345 test test 01 02 03 04 05 06 07 08 09 10 11 12 13 14 ..picture dont clear....however when i switch to ***** everything works fine...ive edited the line for obvious reasons..any ideas.ta
NO CAM SUPPORT OR TALK HERE !!!! RESPECT RULES !!!!!!
ANOTHER POST LIKE YOUR QUOTED HERE AND YOU ARE OUT. THIS IS A WARNING.
Very serious warning
We do not tolerate the EMU discussion on this forum.
Read forum rules.
Thanks
Hi guys, thank you for such a great job again. However, I has trouble using this 1.6.6 Version ... had to roll back to 1.6.5 due to "black screen" problem after reflashing. I flashed twice & using 2 different sticks but got no results, so rolled back.
Of course i did the duo_cfe_3_0_usb required update first, as my /proc/mtd files shows.
root@bm750:/proc# cat mtd
dev: size erasesize name
mtd0: 07600000 00020000 "rootfs"
mtd1: 00200000 00020000 "kernel"
mtd2: 00400000 00020000 "boot"
mtd3: 00100000 00020000 "cfe"
mtd4: 00080000 00020000 "mac"
mtd5: 00080000 00020000 "env"
mtd6: 00100000 00020000 "nvm"
Any idea about the cause? Thanks again and keep it up!
mtd1 should have a different value after the Boot Loader upgrade:
mtd1: 00400000 00020000 "kernel"
Try to upgrade again the Boot Loader.
bootloader update and image install
very easy
you need to make update/install twice
bootloader first and after bootloader update image update/image install.
USB procedure is the same .
Format USB stick
1. Unzip the duo_cfe_3_0_usb.zip to USB stick.(There should be /vuplus/duo/cfe_cfe_auto.bin)
2. Insert USB stick into the USB port of duo and power on the box.
3. It takes just a few secs to update.
4. If Duo displays the message "Finished..reboot", remove the USB stick and restart box.
5. Format USB stick again.
6. Unzip BH image and copy to USB stick (standard procedure)
7. Insert USB stick into the USB port of duo and power on the box.
(standard procedure).
8.If Duo displays the message "Finished..reboot", remove the USB stick and restart box.
http://archive.vuplus.com/image/2011/6.0/duo_cfe_3_0_usb.zip
Opps ... I see i've followed a misleading after-install boot checking indication. Gonna try it again, will check it using those parameters. Thanks for your ultra-prompt assistance ;)
Great Image Like Always Thanks a Lot guys , hopping also for Anaglyph request for next update also :evil:
Hi:
after update boot it shows me this:
but after update image it puts:
mtd2: 00200000 00020000 "boot"
it´s normal the value of mtd2??or i have to do anything more...
thanks for advance..
