BlackHole Vu+ Duo 1.6.6
Is possible but you will not have fix for remote plugin.
You can install first Rihanna5 V3 with fix and after any other skin.
Thanks Matrix10.
Where can I find the old Beyonce 14 skin from 1.6.5?
P.S.: sorry for the double post.
Great Job, 1000x thanks
But still my CEC does not work in the picture on this site i see current CEC address 1.0.0.0 on my Vu+ it is f.f.f.f. ????
Try again
Try to get the correct address of the CEC for your TV
restart image and in your HDMI TV setup
(In mu sony I have Device List Update and HDMI Device List search option
MY Sony bravia have find VUUNO)
When you have good code
Use a fixed address in the CEC Setup
(For sony bravia i use also Wakeup signal from the TV set to OSD name request
so I can use remote from sony and from VUuno for Standby and wakeup)
With yellow Button ( Internet Browser ) open the virtual Keyboard = works ?
Is working I have test on VU Uno i think is the same with VUduo.
Of course you have to be on the field that requires text.
Or not im not sure for VUduo
I have test now with VUDuo and is working
Still not working, TV is a Samsung Ue40C6000 Anynet installed as described Anynet = on
Automatic switch of f->yes
Device list : nothing found renew it and still nothing found.
current CEC address in VU still f.f.f.f.
Hi:
after update boot it shows me this:
dev: size erasesize name
mtd0: 07600000 00020000 "rootfs"
mtd1: 00400000 00020000 "kernel"
mtd2: 00400000 00020000 "boot"
mtd3: 00100000 00020000 "cfe"
mtd4: 00080000 00020000 "mac"
mtd5: 00080000 00020000 "env"
mtd6: 00100000 00020000 "nvm"
but after update image it puts:
mtd2: 00200000 00020000 "boot"
it´s normal the value of mtd2??or i have to do anything more...
thanks in advance..
so then everything is fine with this value of mtd2?
thanks...
thanks...
Yes, before update the values are:
mtd1: 00200000 00020000 "kernel"
And after update the values are:
After image update the Bootloader Rev. 3.0 is like this:
- Increase the update usb file size to 128M Bytes
- Change the flash memory map(kernel size : 4M, /boot : 2M)
thanks biscamax for your reply...
but my question was little diferent,after update boot the stb shows me this and i know it´s ok for other posts:
but when i update the image after update boot it puts this:
is it fine this mtd2 value when i have updated BH 1.6.6??
i hope it is the size of the new image thats change that value but i would want a confirmation of it´s ok...
regards...
I have a same values after I flashed Image and I would like to know too !!!
