Diesqc problems
You can see your receivers technical details here:
http://www.vuplus.com/sub/sub0108.php
Results of my scanning in of 10773 Horizontal 23000 DVB-S2 8PSK 3/4:
I'm running OpenBh, so the menu is probably slightly different.
Mick, she actually went back Into your original post and there it was. Buts it's not other forwarded post's. I'll attach the photos of my settings. I set both Tuners the same and did a channel search but nothing was found
You've got it set to DVB-S, you need to set it to DVB-S2, where it states System, by scrolling to it and hitting the right/left hand button, on the centre control.
In settings, tuner, or other settings.
You could check if this is a Horizontal proble, by trying a vertical option.
10818 Vertical DVB-S2 8PSK 23000 3/4
Try both Tuner A, and Tuner B, if that fails try a non HD transponder:
11344 Vertical 27500 DVB-S, both Tuner A, and tuner B, this should bring up Legend, amongst other channels.
The photo shows no signal. It says the file is too big to upload. It was just showing All the transponder details. The dish was set up today by a sattelite engineer and he also checked my sky dish. Both are spot on
At least we now know Tuner A is getting a signal, now try the frequencies, I've posted, including the DVB-s channels.
I see one photo, showing Tuner A has a 69% SNR, which is your signal quality.
Why didn't the engineer try scanning in any HD channels?
