External player in XBMC
Juste tried with some files on UPnP server and it looks good. Image and sound work fine now.
Now is time to change the subtitles font size, about 56 llooks good on 55" TV SET, you can do it on Subpport by pressing the Subtitles key on the remote control.
@nunigaia , thank you very much for your kind supports. I seem still have some confusion.
1. What is the relationship between the EMC and the mediaplayer (default Mediaplayer)? Independ or the mediaplayer is a part of the EMC?
2. According my understood, the mediaplayer 2 is an independed plugin which can replace the default mediaplayer. Is my understanding correct?
has been posted twice
1 ) - Mediaplayer ( that i named classic ), is included on image by default. They are independent, you can perfectly uninstall ( by hand ) MEDIAPLAYER and install Enhanced Movie Center as your Default Player
1.1) - I have uninstalled Mediaplayer ( Classic ), installed MEDIAPLAYER2 and Subssupport, for XBMC and the same Subssuport for EMC that i have installed too ( to play local files on Vuplus Duo2 ).
2 . Yes, indeed!
MEDIAPLAYER2 ( v. 059 ) and SubsSupport ( v. 1.52 ) Upgrade
Upgraded to Versions:
MediaPlayer2 v0.59 ( 20-03-2015 )
    • removed subtitles sync function(TV button)
    • added subtitles status function(TV button)
Subssupport v1.5.2 ( 25-03-2015 )
    • added Subssupport DVB player - possibility to select and playback subtitle while watching DVB broadcast
      • added in plugins menu
      • added in extensions menu (blue button)
      • possible auto sync subtitles to current event time (yellow button)
      • possible to change subtitles fps (blue button)
      • possible to show help menu (help button)
      • possible to show subtitles/event status (ok button)
        • shows current subtitle, subtitles time, position, fps
        • shows current event, event name, event time and duration
      • possible to resume/pause subtitles playback (pause/resume button)
      • possible to jump between subtitles
        • jump to next/previous subtitle (right/left button)
        • jump to next/previous minute subtitle (next,fastforward/previous,fast backwards button)
        • relative jump to custom position (long press of next,fastforward/previous/fastbackwards button)
        • jump to start of current subtitle (up/down button)
    • added Subssupport settings - possibility to change global subssupport settings
      • general settings
      • external subtitles settings
      • embedded subtitles settings
      • dvb player settings
    • Subssupport downloader
      • added event now and event next title for suggestions
    • updated font selection routine
      • all fonts are now retrieved for selection from standard enigma2 fonts location - typically /usr/share/fonts directory
      • removed Subssupport local fonts directory for font selection
      • removed Ubuntu fonts from package
        • Openpli based images have nice alternative (Liberationsans fonts), which is selected as default if available
    • External Subtitles Settings
      • removed "Subtitles Parsing/Rendering" option
        • it defaults to "new block renderer", all other renderers are removed
      • every type of external subtitle [regular/italic/bold] can be now rendered with different font and different color
        • added "Font type (Regular)" option
        • added "Font color (Regular)" option
        • added "Font transparency (Regular)" option
        • added "Font type (Italic)" option
        • added "Font color (Italic)" option
        • added "Font transparency (Italic)" option
        • added "Font type (Bold)" option
        • added "Font color (Bold)" option
        • added "Font transparency (Bold)" option
    • Embedded Subtitles Settings (non-pli)
      • added Font type selection for every subtitle style (not tested)
Link for tutorial: How to install MediaPlayer2 and Subssupport
Note: If you have installed MEDIAPLAYER2 V.059 from the How to Guide above, you only need to install SubsSupport v. 1.5.2 from 2015-03-25
Best regards
Repost
imsohappy said:
well installed Twitch, on xbmc. stream plays no problem but video freezes after around 2mins
Now on BH 2.1.5 image and the same is happening, also installed MediaPlayer2, and the same
Help meeeeeeeee
Thanks
Richard
Re-posted in the right thread, sorry guys
I´ve installed twitch and tested severall streams ... works flawless.
Can you tell me the name the stream to test ?
I will reply in a minute if you do the same!
What Mediaplayer do you use on XBMC?
Asks and answers in this section, please! ---> http://www.vuplus-community.net/board/threads/external-player-in-xbmc.21286/
Best regards
Best regards
Hello nunigaia
it's on world of tanks (ENG || Braincage || Cruiser, Destroyers, Ya) on this now. stream is fine but video freeze
And on (Kateclick) kate russell) BBC technology programme Click
Vuplus Duo2
Backup By master G
Sorry
Just seen link to post
can you remove other posts please
Thanks
Richard
Repost
Help meeeeeeeee
Thanks
Richard
Best regards
Best regards
Hello nunigaia
Vuplus Duo2
Backup By master G
Sorry
Thanks
Richard
Beeing testing for about 15 minutes ... and all is fine ... no freezes at all ... the video was playing flawless!
Hello again nunigaia
No luck for me my-friend
it happens on all twitch streams
He he he you couldn't post your image with the right settings and updated media players could you :eek:
I'm only a 4 week noob at this
i will keep going at it :cool:
Virgin 50Mg
Thanks
Richard
Virgin 50Mg
Thanks
Richard
Streams could be problematic regarding bandwith, and of course the number of users viewing the stream!
I´ve 120 Mb bandwith, mate. This could be why i´ve not freezing, or dued minus users connected, when i tested.
hello and thanks for your help.
1 what is twitch or is that not allowed
2 xbmc works ok with or without mediaplayer ( as i learnt today )
3 without mediaplayer installed and just using mediaplayer2 i still get a lot of buffering. but when playing same thing on pc and android everything works. but not solo2 bh 2.1.5 thank you.
1) It´s for viewing game´s streaming. you can google for it and watch, don´t need to install, i´m not a lover of online games ( not for my age, lol ).
2) Xmbc works, but there is severall misses, like pvr addon ( as i know ). Better with Mediaplayer2, with it you´ll have support to subtitles ).
3) nothing at all. You are :welcome::thanks:
See you
bye
      • general settings
Best regards
Update2 version SubsSupport ver 1.5.2 ( Upgrade Subssupport version 1.5.2 from 30-03-2015 ) - Update 2 of this Beta Version
- Minor bugs fix
Note: At a time you can use this file, for Subssupport, use the others mediaplayer2 v. 0.59, python, and plugin.py file ( from 20-03-2015 ) attached on post #47 above in this section, except this plugin attached!
MEDIAPLAYER2 ( v. 059 ) and SubsSupport ( v. 1.52 ) Upgrade Beta 3 ( 07-04-2015)
Note: If you have installed MEDIAPLAYER2 V.059 from the How to Guide above, you only need to install SubsSupport v. 1.5.2 from 2015-04-07
main
  • added Subssupport DVB player - possibility to select and playback subtitles while watching DVB broadcast
    • general settings
  • fixed timing when custom subtitles fps is provided
search
  • Subssearch screen
    • fixed GS on cancelling choice dialog which is open when there are multiple subtitles available
    • don't show save "Next to video" option, when there is no video available
      • Subssupport DVB player
    • fix download error in Subssupport downloader/player when "Save to" option is set to "Next to video"
    • keep the order of search langs
  • Subssearch settings
    • fixed some skin issues
    • added jumping between providers and search config (yellow/pageUp/pageDown) button
    • added "Save as (fallback)" option
      • in case we have no filepath set and "Save as" is set to "video", "Save as (fallback)" option is used to determine download location
  • Searchparams screen
    • cache suggestion dialogs
  • History screen
    • change "settings" button color from yellow to blue
  • added titlovi provider
  • fixed subscene provider
  • fixed podnapisi provider
Best regards
thank you nunigaia for your work i already have mp2 installed. can i just install the Upgrade Beta 3 ( 07-04-2015) file or all of them. thank you.
sorry what is the
ttf-ubuntu-sans_0.80-r1_all.ipk
does that need to go in the stb vu bh 2.1.5.
1) -> Yes you can ... install to both python ( files ). the Mediaplayer plugin don´t need to install, cause is the same version from 20-03-2015 ( v.059)
2) -> ttf-ubuntu-sans ... are fonts for handling subtitles, the subssuport plugin use this fonts --> if not installed ... i´t will regular fonts!
Thanks @nunigaia for your kind supports and tutorial. I just miss a few days from this community and sorry for the delaying of reply. I will certainly to try the new player
Hi, @nunigaia , I just ready to install the Mediaplayer 2. I have read your tutorial about the installation. However, I still have some questions.
1. If I install the Mediaplayer 2, Can I still keep the EMC in my receiver without uninstall it?
2. I plan to install the latest version Mediaplayer 2( Ver 0.59) and Sub ssupport (Ver 1.52, beta 3) (the 5 ipk files). Do I need to install (copy) the plugin.py to the folder of XBMC as your mentioned in the tutorial? What the python-difflib ..... is?
3. Regarding to un-install the default classic mediaplayer, you use Dream control tool, when selected the mediaplayer folder, press the delete button to un-install the classic mediaplayer. What it means? It means 'delete the folder' or 'The dream tool will run a procedure to un-install the classic mediaplayer and modify related settings? Because I use a different FTP tool access my receiver, only can do delete.
4. Regarding the SSH/Telnet in your Fig 2 in the tutorial, the instuction says we should run 3 commands, opkg remove .... , What they are for? I have not install any mediaplayer2 yet, why I need to remove ? or The 3 commands just clean the file list of the package registration? Do I have to run them?
Sorry for so many questions.
