HOW TO ADD THE vu uno tunner supports DVB-S2 multistream
For now the drivers are some problems ..... I must wait my Technisat Skystar HD USB before release them in any form
No problem , I prefer to wait you because BH 2.06 is very stable and performant. I am not so sure that Skystar HD USB support the Multistream feature.
It could be very interesting if BH supports also mutlistream feature via the TBS USB Tuner..
I've read something in this Board and into web about multistreaming and Skystar HD ... and seems the device support this feature after patching their drivers .... but I need the hardware and some time to investigate
SS HD USB, TBS 5980, 5925 support DVB-S2 multistream & PLS. But need compile stv090x demod driver wit MIS+PLS and add MIS+PLS support to enigma2.
See my drivers repo with stv090x mis+pls support, including 100% open-source tbs 5980, 5925 drivers - https://bitbucket.org/CrazyCat/linux-tbs-drivers
My Enigma2PC repo (based on OpenPli Enigma2) with DVB-S2 MIS+PLS support + DVB-T2 MultiPLP support - https://github.com/crazycat69/enigma2pc
If you success with device driver for SS HD USB or TBS - i can help adapt my Enigma2 MIS+PLS support to BH Enigma2 sources.
I've made some experiments this week with sources taken from updatelee repository but if the compile process goes OK all USB DVB/ATSC devices I've tested with my Vu+ boxes become unavaiable because I loose FE_GET_INFO event and I rolled back my repository to a stable point.
I'll take a look into your sources.
Thanks a lot!
With your experience, the PCTV 290e has DVB-T2 MultiPLP support ?
I've answered by myself taking a look into your code: YES.
Sorry for late reply ....
My SkyStar HD has a STV6110x .... I don't know if this IC has Multistream support or not... I suppose NO :(
I need a new device who has an IC with Multistream support
Maybe VU+ STB can t,
but is not fact for other mips (clone)boxes with enhanced tuner.
For E2-SH4 Sti7111 based,it is also done!
I've wrote MIPSEL ..... SH4 it's ANOTHER ARCHITECTURE.
To implement Multistreaming, Vu+ must implement it into box drivers.
If you're interested on this feature, write a support request directly to Vu+ (www.vuplus.com)
I don t have intensions anymore to write to Vu+ support---After 7months nothing
changed and i got no answer ,after many requests on this....for VU+ internal demods are
wrong hw for MIS and the only external STi Usb DVB-S2 boxes can
not be used,because of VU-driver issues...
But no problem,i sold my Solo2 2 weeks ago ,because a nice configured HTPC is better
than any stb.
But if we use an external usb tuner that supports MIS is it possible to implement a driver in VU+ ?
May be directly from Vu+ or by the image coders ?
DM800SE is mipsel!
In chinese there are tuner available,which can receive and demux this 2 MIS-Transponders on 88E.
With E2 Image by Ramhersat !
Vu+s nternal demods are not to use for mis,but with external tuner nox, it should be possible.
Problem are the driver issues,which VU+ are not able to fix since 7months!
So the fact is ,not possible for VU+ stb ,but on other mipsel maschine it s possible!
Don t waste your time on this,Vu+ loves to fix useless things,so enjoy that work or buy
another box or htpc!
