HOW TO ADD THE vu uno tunner supports DVB-S2 multistream
But if we use an external usb tuner that supports MIS is it possible to implement a driver in VU+ ?
May be directly from Vu+ or by the image coders ?
The first implementation must be made by Vu+ in the VTuner component of box drivers and next will be avaiable to implemented in the USB DVB side.
DM800SE is mipsel!
In chinese there are tuner available,which can receive and demux this 2 MIS-Transponders on 88E.
With E2 Image by Ramhersat !
Vu+s nternal demods are not to use for mis,but with external tuner nox, it should be possible.
Problem are the driver issues,which VU+ are not able to fix since 7months!
So the fact is ,not possible for VU+ stb ,but on other mipsel maschine it s possible!
Don t waste your time on this,Vu+ loves to fix useless things,so enjoy that work or buy
another box or htpc!
If you prefer a clone-fuck box .... this is not the Board for you.
When Vu+ implement the MIS part, will be avaiable for USB part.
I prefer nothing anymore.
This is only to show you,that your information is wrong,mipsel can do MIS but Vu+ not
But it is insane that clone fuckers are able todo and the "super company" Vu+ not
If Vu+ implement(what ever they meant with it) so this part can only work for external
usb boxes,internal hw demod (Broadcom or Availink)can t do!
Next problem,is the usb box.... Skystar USB HD isn t available anymore and STi based
TBS boxes needs a driver to mipsel export.This will not happen next time.as before,so
i think,then you can also wait on new boxes ,which have ready implemented MIS including
4k and Hevc support,lol!
There would be an easier way for VU+ or maybe devs with HW experience...
Take the Vu+ DVB-S2 plugin tuner card,desolder tuner can,SP2237 and
replace it,with Sp2236 or 2246...all build files to make drivers are available
on request by serit....it was easy for me to get a sample with all confidential
build files and i m not a company!...not like others were you first have to
order an amount of 1k pieces,before you get infos!
At today what is the state of the art ?
Is it possible to implement a driver or plugin to connect the TBS 5925 to VU+Duo2 and receiver the MIS ?
Multistream is not yet supported and needs Vu+ Dev Team work to add it to VTuner supported features
About TBS, I don't know but without a FULL open source drive, there is no chance to support it
What current kernel used in BH images ?
I have patches for 3.10 kernel (support TBS 5910, 5920, 5928, 5925, 5980, 5880). Used for current OpnWRT.
Vu+ boxes uses these kernels:
Vu+Duo - Vu+Solo - Vu+Ultimo - Vu+Uno: 3.1.1
Vu+Duo2 - Vu+Solo2: 3.3.8
Thanks for these links and for your work of course!
maybe,not useful for those people who allways make bla,bla about driver-fixes?...but helpful for people who want receive multistream with regular receiver.
There is no "bla bla bla" but "ask the manufacturer to add the wanted feature". When / if will be implemented, the manufacturer releases the corresponding driver.
Here there is no space for other brands like the one you point to.
End of story.
I excuse me for the same redundant question...
Any news about TBS 5925 and Duo2 ? New drivers and images can support it ?
