HOW TO ADD THE vu uno tunner supports DVB-S2 multistream
I got finally the TBS USB Box :)
On Turbosight official site the Linux drivers with Sources released:
http://www.tbsdtv.com/download/document/common/tbs-linux-sources_v141225.zip
I copied the dvb-usb-tbsqbox-id5980.fw file to /lib/firmware but there is your help needed :help::help:
Hello
I have not been on this forum for ages and thought I had forgotten my login but luckily not.
I wonder can anyone here check the following
Astra 28.2 East
Frequency: 11.009 V
SR 22500
8PSK
DVB-S2 Multistream
At least I understand this mux IS a multistream mux but don't know the Multistream ID. I have a PCTV 461e stick. Am I right in thinking this stick will not lock onto a multistream mux?
If anyone can check what is on 11.009 V n 28 East, what are the Multistream IDs and what is on each one?
Thanks for your help. BTW anyone know of any USB sticks that will recognise DVB-S2 Multistream?
And, are there any linux STBs that can be modified to enable DVB-S2 multistream reception - ie a Technomate TM Twin or Venton Unibox? What software would I need to add and into which folders on the STB itslef?
Thank for your help
but I've read this:
To build drivers for your TBS card
  • download the driver source from tbsdtv.com
  • extract the arhive
  • enter the tbs direcory contained in the archive
# cd tbs
  • extract the contained tar.bz
# tar jxvf linux-tbs-drivers.tar.bz2
  • fix the permissions (someone messed up the permissions in the tar)
# find linux-tbs-drivers -type d -exec chmod 755 {} ';'
  • follow the instructions in the README_TBS#### file where #### matches your card model number
but I've read this:
# cd tbs
I've checked the sources avaiable from TBS website and there are no chances: the drivers avaiable from the manufacturer ARE ONLY FOR X86 and X64 arch. No MIPS arch avaiable. No full source code drivers avaiable ... so IMPOSSIBLE support for MIPS platform.
I do not speak Russian but maybe someone else is successful.. hope
wxx.forum.free-x.de/wbb/index.php?page=Thread&threadID=1612&pageNo=1
It's another story.
The thread you posted is known by me and talks about Multistream.
My previous post talks about TBS cards taht are TWO DIFFERENT THINGS.
sorry if I write in Italian..
allora se no no capito male enigma2 con una scheda appropiata el pc decodifica i multistrem .. cioè ACM, VCM, 16APSK, 32APSK, ciò che fa il tbs5925?
you know if there is a version of enigma2 for windows..es: smartdvb, DVBViewer, DVBDream ..
sai se cè una versione di enigma2 per windows..es:smartdvb,dvbviewer,dvbdream..?
