How to setup your Vu+ for recording on USB
I think the easiest for you is to remove the USB stick from the Vu+, connect it to your PC and create the "movie" folder.
Then simply reconnect the USB stick to your Vu+ and mount it by Devices Manager.
o
Thanks but to create the folder I have to use the normal procedure or I need to create it with an FTP software?
thanks a lot for your help much appreciated but now an error re. timeshift location popped ..the error mentioned something about ext 2 and ext 3. I think that my usb storage space is not enough. What do you think?
You can use the normal procedure.
It seems a message regarding the formatting of your USB stick.
What's exactly the message you read?
Thanks a lot for your help.
I pressed the ok button by mistake so I could not tell you what the error was exactly. I will buy a new usb stick as the one I'm using have other stuff saved on it. What is the best to buy a usb stick or a hard disk? and what is the best memory space to buy?
I think that a good solution for a Solo is an HDD with external supply and with a capability at least of 500GB.
I would like to record a film (I use the green hole panel ....1 channel) Is it possible please?
crashlog is a file automatically saved on your mounted device during enigna crash.
Do you have hdd in your box?
Have you formatted USB?
Vu+solo. I followed this path to mount USB
Blue Panel > Black Hole Settings > Devices Manager > Mountpoints ....​
When I'm at the mountpoints screen and choose to mount USB /media/usb and press the red button to save the box crashes.​
Yes I tried several usb sticks with no success​
