Sorry, we support only Vu+ receivers.Hello from Bosnia,
I've let my Dreambox 800HD PVR receiver to format the USB stick, and saw during formatting the message about it being done in Linux format. After succesfuly completing the setting up to record on USB stick and recording my first programme - I can play it via recorder's Media Player, but not on my laptop or PC at work (both running Windows 7). Both say that the USB stick is not formatted. I suppose the same problem would occur if I used the external HDD connected via USB cable. So my question is - how to record on USB stick AND external HDD, and that the files can be later copied to the PC or laptop? And how big are these files? How many minutes or hrs can be saved on a 8 Gb or 16 Gb USB stick?
Hi,
I have used your (easy to follow!) instructions to setup recording through USB for my Vu+ Zero. The good news is that the external harddisk is recognized, when doing the test I get an OK, I could create the directory, etc. etc. When I record though (regardless if I use timer or endless or any other option) and want to playback the recorded programm, it shows the title in the directory and the program description, but the file size is 0 MB and when pressing play the screen stays black and then it stops after a few seconds. I have tried to connect another device (USB stick), but get the same result. Do you have any idea what I might have missed in setting it up or what I could be doing wrong? Thanks in advance for your support!
Did you enabled expert mode in Customize menu?Hi
i used PLI before but just installed the black hole img.
Made a network mount to my Qnap Nas using the mount manager this works .
but i cannot set the recording paths as they are not there Menu>setup>system>recording path
how can is set this somehow ?
thanks in advance
Thank you i will try both options,
I am sure its a great image but add ons are hard to find ( most likely because i am not used to it yet )
Like cam stuf to to use indoors of course.
is there some kind of a user manual ? to find out what all in e.g te setup menu is ?
This worked out, Thanks a lot.
But i have no idea how to get my O.cam to work.Strugling with this for over 3 weeks now without any result.
it shows up under the Blue menu but tas about it.
within pli i just filled out. O.cam.server but tis doesnt work for the version thats available for BH.
I am willing to make some kind of donation if somebody can help me to get this up and runneing ::
This is a great tutorial,works 100%.Thank you very much for that!!
I am running the Vu+ Uno 4k.
Im just wondering,as the files .ts are in hd quality,is there an option somwhere hidden,where i could possibly setup lets say instead oh 1080p resoultion only 720p for my recordings?
No, there is no parameter to set the video quality.
Also i noticed it saves into the .ts file all audio tracks available for that channels (sometimes is even 5 tracks).As this is not really necessary and its only pumping up the size of the files,can this parameter be specified too??
No and, by the way, audio weighs in a not significant way compared to video.
Thanks a lot again!
