IPTV
iptvplayer 84.03.00.00
Update:
-Add possibility to set background to the subtitles in external movie player.
-Fix webstreams-> hasbahcaiptv.com/ thanks @verlock
-http://watchwrestling.to/ - fix new links extraction
-yify.tv handle subttitles direct from yify.tv
-New host neokino.net/.
-Disable not nowrking HasBahCa
-Fix webcamera.pl
-Fix yify.tv
-watchwrestling.to/ add "LIVE 24/7"
-Add new host watchwrestling.to/
-lsdir: use readdir instead of getdents64.
-Update lsdir to use SYS_getdents64 instead SYS_getdents.
-Update uchardet to uchardet-enhanced with new language support.
-Add auto detection subtitles encoding using uchardet utility.
-Fix yify.tv/.
-exeplayer v9 for mipsel
#1.Post
iptvplayer 84.06.00.01
Update:
-Youtube subtitles use name in default E2 language.
-Add subtitles support for Youtube.
-Add possibility to set subtitles line spacing.
-Add possibility to set subtitles line height.
#1.Post
iptvplayer 84.08.00.00
Update:
-Add Copy/Cut Paste action to LocalMedia host.
-E2 distribution verification (phase 1/3).
-LocalHost add "Rename" option and confirmation for removing file.
-Fix wgrane.pl
-Add custom Action for Host interface and use it for Local Media host to give possibility to remove local file.
-Fix last commit.
-Fix alltube.tv (listing items) and neokino.tv (listing yeats categories).
#1.Post
iptvplayer 84.09.03.00
Update:
-Fix vshare.io
-External movie player - remove subtitles cache file when user load it once again manually (because file path can be the same but content can be changed).
-Fix movieshd.co.
-Fix yify.tt/ subtitles tracks attached to movie
-External movie player: load automatically the subtitle with the same name of the movie file
-Fix hasbahcaiptv.com/ (WEBstream)
#1.Post
Dear Pyromon, would you be so kind to add some Albanian channels for tomorrow's sport events.
Thank you in advance.
iptvplayer 85.00.00.00
Update:
-Add new host ekino-tv.pl/
-Fix dailymotion.com
-Fix yifytv
-Try to fix problem with parsing "Lenght" from wget output.
-yify.tv/- do not display suggested subtitles if they are not available.
#1.Post
iptvplayer 86.00.00.00
Update:
-Add new host kino2016.pl
-Fix seasons list in the host alltube.tv/
-Fix one word in german translation. Thanks to @itanium99
-Fix spryciarze.pl
-Add possibility to disable live at plugin start.
-Previous commit has been made according to information provided by @verlock. Thanks you @verlock.
-webstreams -> replace "Deutsch-Fernseher" by "Free Iptv Project".
IPTV_MIX-08.11.2015
#1.Post
enigma2-plugin-extensions-iptvplayer_87.00.00.00_all
whats new:
-Add new host vumoo.ch
-Add EPG to the ustvnow.com
-Fix links extraction from youtube.
-http://watchwrestling.to/ fix live links extraction.
-Add ustvnow.com to the webstreams host.
-Restore "Deutsch-Fernseher" subctegory in the webstreams host.
-Fix link extraction from kino2016.pl.
-Fix vod.tvp.pl in proxy mode.
-Fix filmovita.com link extraction.
-Fix openload.co/openload.io -> movieshd.eu
-External movie player - WORKAROUND for incorrectly recognized CP1250 encoding as iso-8859-2 for polish language.
-Another fix last version.
-Fix last commit.
-Delete unnecessary PlayerSelector icons during update
-External movie player - add possibility to remember last watched position by default disabled.
thanx @ samsamsam
Thanks. I ve à question. A lot of channels in iptvlistupdater dont work. Where is the problem ?
Envoyé de mon SM-G900F en utilisant Tapatalk
iptvplayer 89.01.03.00
- Remember search pattern in the subtitles downloader
- Improve subtitles searching for the TV shows.
- Fix possible GS when blue button has been pressed in very specific situation.
- Add support for new subtitle provider: napisy24.pl for polish users
#1.Post
iptvplayer 89.03.00.00
-Add file.xbmcmxtv.com/ to webstreams, and give posibility to change order and disable entries in the webstreams host. It can be done by file /etc/enigma2/iptvplayerwebstreamorder - at now only manual changing is possible.
-Fix default quality selection in host ekstraklasa.tv
-Commit merged fixes prepared by @krutoj2010 to make some text able to be translated. (part 2)
-Subtitles - try to put searched episode at top of episodes list. Season and Episode numebr will be guessed from episode title.
-Replace omdbapi.com/ which seems to be down with api.themoviedb.org
-Fix detection version using the grep utitlity (some grep return code 1 even if the pattern has been found and printed).
-Fix GST during subtitle download. Thanks @asiBenlik for the report.
-Commit merged fixes prepared by @krutoj2010 to make some text able to be translated. (part 1)
-Add pure-cast.net/ into the webstreams host.
-Remember search pattern in the subtitles downloader
-Improve subtitles searching for the TV shows.
-Fix possible GS when blue button has been pressed in very specific situation.
-Add support for new subtitle provider: napisy24.pl for polish users
-ru translation - thanks to @krutoj2010
-openload.io use standard page reciving
-Add new host movienight.ws/
-New host solarmovie.ph/has been added
#1.Post
enigma2-plugin-extensions-iptvplayer_90.00.02.00_all
whats new:
-Additional fix for ex.ua host.
-Fix ex.ua for some languages.
-Fix last commit.
-Add new host ex.ua/
-Add filmotopia - tv show title to the episode.
-Fix: wrestling-network.net -> wrestlingnetwork.tv
-Fix last added series in the host alltube.tv
thanx @ samsamsam
Dear Pyromon, thank u very much for your hard work, I am really grateful for that. The Albanian channels u sent on 18.10.2015 are still working perfectly. I have only one request, if you are able to send Albanian Super-Sports channels HD quality.
Best regards
