IPTV
iptvplayer_90.00.04.02
-new version 10 of exteplaer3 for MIPSEL has been deployed; handle of the AAC codec has been improved (on some materials with AAC codec there was a problem with no audio it should be fixed now)
At now exteplayer3 supports the following codecs:
AUDIO:
- AAC
- AC3
- MP3
VIDEO:
- H264
thx @ samsamsam
@Pyromon
Dear Pyromon, with all due respect, but there were no Albanian channels on 21st and 22nd list of channels.
Once more thank you very much for your hard work and dedication. :)
iptvplayer 90.00.05.00
- External movie player: fix lastposition in the buffering mode.
- Fix some translation.
- New logo for Thanks to krutoj
- New version 10 of the exteplayer3 for MIPSEL. Fixed problem with AA...
- Add audio to the http://
#1.Post
iptvplayer 90.00.09.01
- New version of the exteplayer3 (11) for MIPSEL platforms.
- Merge youtube_dl code to fix extraction links to the vevo videos.
- Fix videomega.tv
- Fix hasbahcaiptv.com
#1.Post
iptvplayer 90.00.10.00
-Fix watchwrestling.to/
-Accept wav file extension in the local media host.
-New version of the exteplayer3 (11) for MIPSEL platforms.Fix problem with AAC code on platform MIRACLE BOX.
-Merge youtube_dl code to fix extraction links to the vevo videos.
-Fix videomega.tv/
-Fix hasbahcaiptv.com/
-External movie player: fix lastposition in the buffering mode.
-Fix some translation.
-New logo for ex.ua/ host. Thanks to krutoj
-New version 10 of the exteplayer3 for MIPSEL. Fixed problem with AAC codec in some stream.
-Add audio to the ex.ua/ host.
#1.Post
Dear Pyromon,
I have a small problem, the list of Albanian channels you sent me some time ago worked perfectly until yesterday. Two of the channels from the list are not working, namely KTV and Klan Kosova HD, the rest of the channels work just fine. I will attach the list of the channels so you remember.
Thank you in advance.
iptvplayer 90.02.00.00
- Merge change request "Add support for Arm V7".
- Add support for Arm V7
- videomega better detection not working links
- Ext Movie player - add possibility to set AAC, AC3 downmix option.
- Fix last commit which cause the GS in external movie player
#1.Post
enigma2-plugin-extensions-iptvplayer_90.05.00.00_allwhats new:
-Add telewizjada.net to the webstreams host.
-Commit missing file from the last commit.
-Deploy new version of the exteplayer3 (v13) for the MIPSEL platform - added XVID and DIVIX handlers.-
-exteplayer3 for MIPSEL - add support for software decoding of the audio codecs.
-License modification.
-Update info - new developer
-Fix rtmp live stream links extraction from sportdeutschland.tv/
-Fix error timestamp out of range for platform time_t in the gametrailers.com/
-Merge change request "Add support for Arm V7".
-Merge branch 'master' into 'master' ...Add support for Arm V7 See merge request !3
-Fix typo
-Add support for Arm V7
- videomega better detection not working links- fix link extraction from -sportdeutschland.tv/,
- fix logo serialenet
- fix link extraction from spryciarze.pl/
- fix host gametrailers.com/
-Fix last commit which cause the GS in external movie player.
-Ext Movie player - add possibility to set AAC, AC3 downmix option.
thanx @ samsamsam
Hallo,
Wollte kurz mal fragen, kann man IPTV auch mit dem VTI-Image 5.0.1 noch nutzen ???
Funktioniert nur Blackhole oder auch VTI...?
Vielen dank für die Antwort :-)
ZHCIP
enigma2-plugin-extensions-iptvplayer_90.06.00.00_all
whats new:
-Add DTS support to the exteplayer3 (v14) for the MIPSEL platforms.
-ex.ua try to fix search with diffrent language
-Add global search for the host ex.ua
-New portion of translation prepared and suggested by @krutoj2010 - thanks
-exteplaer3 for SH4 for ffmpeg versions: '2.8.1', '2.8.2'
-Host filmy3d.eu - fix next page listing.
thanx @ samsamsam
iptvplayer_90.07.00.00
-Youtube - add support for the dash format (only for download) - for test purpose only.
-Fix last commit.
-Commit RU locales provided by @ krutoj2010
#1.Post
iptvplayer_90.07.02.01
-Enable Wrap Around for lists components as requested by krutoj2010
-Remove tmp merge downloader files, handle version 2.8.3 of the ffmpeg by the IPTVPlayer.
-Fix kino2016.pl/ link extraction.
thx @ samsamsam
#1.Post
enigma2-plugin-extensions-iptvplayer_90.07.05.01_all
whats new:
-Commit correction of polish translation prepared by @Mariusz1970
-Fix youtube links in the host urllist player.
-Fix link extraction from cartoonhd.mobi/
-Add links extractors:
- sendvid.com
- wholecloud.net
-Fix links extractors:
- rutube.ru
- videoweed.es
- novamov.com
- nowvideo.sx
- youwatch.org
- movshare.net
-Fix hosts:
- MusicBox
thanx @ samsamsam
