IPTV
IPTV-Player_90.07.14.00
-Fix alltube.tv/
-Fix fighttube.pl/
-Fix dancetrippin.tv/
-Fix requested by @ a4tech.
-Fix vidfile.net/ link extractor.
-Disable anime-centrum.net - according to "pl-pl.facebook.com/AnimeCentrum/" it is closed
-Fix season, episode and sort listing in cartoonhd.mobi/
-Fix shinden.pl/
-Fix cda.pl link extractor - thanks to the @ kedarz for the report.
-Minor fixes, polish translation and misspelling in the zalukaj.tv.
-Fix vod.tvp and anyfiles search.[/USER]
[B]#1.Post[/B]
IPTV-Player_90.07.24.00
-vod.tvp.pl/ - fix next page.
-Fix cartoonhd.mobi/ search functionality.
-Merge branch 'master' into 'master'
-Fix telewizjada.net/
-try to load player skin, only when it exists
-vod.tvp.pl/ - speed up search
-vod.tvp.pl/ - another fix for serch
-Fix search function in the vod.tvp.pl/
-Fix nextPage on vod.tvp.pl/ with 'All series' category
-Fix iptak
-Fix telewizjada.
-Fix filmovita7
#1.Post
enigma2-plugin-extensions-iptvplayer_91.00.00.00_all
whats new:
-Add ustream.tv
-Add link extractors for:
- abcast.net
- sostart.org
- theactionlive.com
- openlive.org
Fix link extractors for:
- castalba.tv
- crichd.tv
- fix all channel in the wagasworld.com/:
- fix ustream.tv (f4mdump update is needed)
- add ssh101.com and twitch.tv live stream extractor to urlparser
- fix sawlive.tv link extractor
thanx @ samsamsam
iptvplayer 93.00.00.00enigma2-plugin-extensions-iptvplayer_93.00.00.00_all
whats new:
-Add new host cinemay.com/
-Fix youtube
-New host streamcomplet.com/
-Improvements of subtitles search .
-New ru locales provided by krutoj2010
-alltube - fix last added series
-vod onet - add support for subs.
-Make "Autoplay start delay" configurable. Host TVPVod - add posibility to use more item instead of Next page.
-Fix links extraction from vevo.com
thanx @ samsamsam
IPTV-Player_94.00.02.00
-Fix videowood.tv/ links extractor.
-Remove not used code.
-Fix streamlive.to/ link extractor. Minor fixes in the hdkinomir.ru host.
#1.Post
IPTV-Player_95.00.02.01
- Cosmetic fixes.
- Add m2ts extension to the localmedia host.
- Fix playreplay.net and moevideo.net links extractors using in the h...
- New host libre-stream.com/.
- make Config screen skinable
- Remove widget name from configbase skin - change proposed and requested by zdzis…
- Fix possible GS.
- Fix possible crash when try to download sugessted subtitles from the videomega.tv
- Improve links extraction from videomega.tv service.
- Fix videowood.tv links extractor.
- Remove not used code.
- Fix streamlive.to link extractor. Minor fixes in the hdkinomir.ru host.
#1.Post
IPTV-PLayer_95.00.07.00
-Fix abcast.net/ link extractor.
-kino2016.pl - fix some links extraction
-anime-odcinki.pl - use local implementation AES_CBC instead of "from Crypto.Cipher import AES" as it is not available in some images.
-Enable gstplayer for set-top-boxes with gstreamer 1.X. Binaries compiled by @zdzislaw22 will be used.
-Fix anime-odcinki.pl/ links extraction.
-Fix last commit.
-At now the host superfilm is not working, so it will blocked until fix.
-Add validation for facebook links - remove links with like functionality.
-For test purpose.
-Cosmetic fixes.
#1.Post
-Fix last commit.
-For test purpose.
-Cosmetic fixes.
#1.Post
Happy New Year
enigma2-plugin-extensions-iptvplayer_96.00.07.00_all
whats new:
-Fix streamlive.to/
-TVP VOD - fix links extraction for some materials.
-Fix items in some ctegories: Dla dzieci, Informacje in the host looknij.tv/. Fix problem with not playing links in the same host.
-Fix categories listing in the host nocnyseans.pl
thanx @ samsamsam
enigma2-plugin-extensions-iptvplayer_96.03.00.00_all
whats new:
-New version of gstplayer v19. Show video resolution in external movie player.
-laola1.tv - add search functionality
-Host laola1.tv has been rewritten to work with new page aola1.tv/
thanx @ samsamsam
enigma2-plugin-extensions-iptvplayer_97.00.06.01_all
whats new:
-Skin prepared by @rafalcoo1 + icon for category the "Recommended by Rafalcoo1" in the host Urllist.
-Another try to fix fs.to/ for Russian users.
-Try to fix fs.to/ for Russian users.
-Fix nextPage in the host TVP VOD. Additional logs for fs.to host.
-Fix gstplayer crash (new version v20)
thanx @ samsamsam
enigma2-plugin-extensions-iptvplayer_98.00.05.00_all
whats new:
-New version v1.1.0 of the gst-ifdsrc plugin.
-New gstplayer version v10021 for gstreamer 1.X with fix for possible crash.
-New version of exteplayer3 v20 for MIPSEL platform with minor fixes.
-Fix start exteplayer3 on SH4 platform. exteplayer3 for sh4 is in old version and it do not known parameter -w which as default is set by extmovieplayer.py
thanx @ samsamsam
enigma2-plugin-extensions-iptvplayer_98.04.02.00_all
whats new:
-Add zerocast.tv/ resolver.
-Fix seek on some streams in exteplayer3.
-Fix wrong info.
-exteplayer3 v21 add support for separate audio and video uri. FULL HD for youtube should works now without buffering.
-Fix possible host movie4k.to/ crash.
-Fix looknij.tv link extraction.
-Fix cda.pl parser.
-Add live-stream.tv/ to the webstream host.
-New parameter "iptv_m3u8_skip_seg" has been added, to be able to skip fragments from beginning of the m3u8 list.
-Fix last commit.
-Improve HLS downloader.
-Fix M3U8 downloader - take in comparision only last part of the segment url.
-External movie player - fix wrong format of headers for exteplayer3.
-Fix plwwecom host crash.
-Add possibility to run refresh cmd to external movie player. This is needed for playing streams from
www.live-stream.tv/
-purecastnet make compatible with new api for kodi plugin
-Fix possible crash of the host dancetrippin
-Commit missing file from last commit.
-Several fixes:-
- block host yousee not working
- fix possible crash in hosts kino2016, vumooch, movieshdco (info on history search item), zdfmediathek, zalukajtv, webstream, myvideode,
hdkinomir (in search), librestream(in search), musicbox
- add info in crash that hosts 'freeod', 'xxx', 'ytlist', 'rafalcool1' are not part of IPTVPlayer
-New rewritten host wp.tv/, additional fix for fighttube
Several fixes:-
- add link extractor for hosting live-stream.tv/
- fix Videoweed links extractor
- solarmovie, fighttube, neokino, plwwecom, movie4kto, naszekino fix host crash
-Fix last commit.
-Add exteplayer3 for STB based on ARMv7 (for test purpose only)
-Fix links extractions from telewizjada.net/
thanx @ samsamsam
enigma2-plugin-extensions-iptvplayer_102.03.01.00_all
whats new:
-Improving playlist randomization.
-Add new functionality to randomize of the playable list.
-Fix issue "Language correction for host panel header".
-Fix issue "Language correction in Settings".
-Block not working hosts: serialeonline.org.pl/, iplex.pl/
-Fix kino2016.pl/ -> kwejk.tv/
thanx @ samsamsam
I have an IPTV subscription but the interface only works on Android. Is there a plugin/add-on for IPTV where I can customise by inputting my HOST, Username and Pwd? Using IPTV 102.03.05.00
Thanks in advance. :)
enigma2-plugin-extensions-iptvplayer_102.03.05.01_all
whats new:
-Commit ru locales provided by @krutoj2010
-Fix links extractor for openload.co/
-Additional fix for links extraction from hqq.tv/.
-Add support for other qualities for hostings ok.ru/. Fix links extractor from hqq.ru/
-Fix live-stream.tv/.
thanx @ samsamsam
enigma2-plugin-extensions-iptvplayer_103.00.01.00_all
whats new:
-hdfilmstreaming.com/ - minor fixes
-New host hdfilmstreaming.com/.
-Another try to fix videomega.tv buffering mode.
-Fix p2pcast.tech/ links extractor.
-Fix last commit.
-Commit missing change from last commit.
-Try to fix videomega.tv downloading timeout.
-Fix LocalMedia listing items "m3u".
-Add edem.tv/ to the host webstreams.
-Fix youtube links extraction for live streams.
-Add pin authentication to the directory item.Some minor fixes in:
- telewizjada.net - add categorization, adult category locked with pin
- looknij.tv - remove categorization
- localmedia - add support for flac extension (requested by @Zdzislaw)
- vidtv.pl - fix channels names
-Speed up links extraction from the Youtube.
thanx @ samsamsam
