Language translators
i can helpwith polish
one question, what will be happend when i will work on my po file , and somebady add some new word in new relase ?
There are already many people translating into polish, if you wnat to heklp you can ask bogdanm
Hi Tamaki! Is there an easy method to have multiple persons working on the same file? I mean, can we work an multiple copies of the same file and then merge them at the end for example?
Who is going to decide whict translation will be used , if several persons are translating the very same language simulteniously ?
I will do the Norwegian translation as well :)
I'm putting in the first post the first person that is available to make translations.
Only who is going to tell here his availability is official BH translator.
PS. i thought you were spanish. Do i have to add also you helping for norvegian language?
@all translator
First post is updated with all translators at the moment.
When you have the file ready, please tell me.
I'll make i new thread for each language.
@all translators.
Please, for all languages already assigned, post in the language thread in sticky.
There are few problems with translation :
Black Hole SpeedUp:
The message "Please disable ALL the plugins you don't need to use.\n"
"This will speed up Image Performance." cannot be translated (even with italian file)....was fine with BH 2.0.0
Same for RemoteChannelStreamConverter. (may be because sign " is used instead of ')
I have a complete French translation already made; complying with both Black Pole and Black Hole 2.01. Do you want I post it ?
Black Hole SpeedUp:
Post it in http://www.vuplus-community.net/board/threads/bh-official-french-translation.11343/
Did you test it?
Translated just fine in Greek, on BH 2.0.1
