no audio on following channel
Use Dreamboxedit to download your channel list, manually enter the audio PID, then send the amended channel list back to your receiver.
Have you tried Open Blackhole?
I tried the but doesn't work audio pid is shown in information. But when yellow button is pressed no audio track to select from. No I didn't try with open Blackhole. Could I install open Blackhole over normal black hole image
You can install it in a Multi Boot option, but I'd try a fresh installation, then add Blackhole as Multi boot
Open Blackhole is better for kodi, as it use v17.3.
i installed black hole 3..0.3 q in flash .then i install open blackhole in flash should i disable openmultiboot in open blackhole,is it ok to import settings from black hole,can i update open black hole online ?
How can you disable? :)
No.
When, from plugins by using OpenMultiboot you can choose the image you want to boot:
  1. Image installed on flash
  2. Image installed on the USB pen drive ( as recommended an suggested ). At this point the severall images you have installed on OpenMultiboot.
You can upload the same settings ( used on severall images ), by using severall tools ( dreamset, dreamboxedit, etc ... ). i.e, you just don´t need to scan for services ( channels ).
Hope that it helps you, although in any case, ask for help!
thanks
No.
thanks
When I install multiboot. WiFi is disabled which i rectified. And when I try to configure wifi of open Blackhole I could not do it. Setting is not configurable. It not responded
Have you updated to the latest Open Blackhole?
Which version are you running?
Yes I did. I can't set wi fi setting.
open Blackhole is installed in multiboot. Is it necessary to set both images in flash and usb to have same network settings?
