no audio on following channel
It is not wireless access point plugin but wireless lan set up. I could not set it.it reverts back to access point not selected. When I scan for network it hangs indefinitely
i have following configuration
classic blackhole 3.0.3 image in flash
open blackhole image in multiboot
could i update classic blackhole image to 3.0.3 to 3.0.4 flash without affecting images in multiboot
I´ve tried severall times and had no problems.
  1. Remove all usb devices, as normal.
  2. Flash your STB. ( BlackHole 3.0.4 )
  3. Configure your Flash image.
  4. Upon configured and booted insert your USB pen Drive that contains Open Multiboot.
  5. Map your device that contains OpenMultiboot ( your Stb should reboot ).
  6. After reboot, go to Plugins browser and open OpenMultiboot plugin and exit.
  7. Reboot your STB.
The next time you open OpenMultiboot, you should see the images installed there.
I have copied picon in
usb/media /picon folder in classic black hole image picon work great. But not work in open Blackhole. Earlier it works well.
I have insert 2 usb device in one for multiboot(kingston) and other for (samsung )picon,recording etc.
USB device which contains multiboot is mounted
But other usb device (exfat format ) is not mountable. When rebooted it is not mapped.
Try to format ( initialize ) the samsung flash drive as EXT4 FS, and retry the mount.
It could give you this issue ( not mountable ), because it is an USB 3.0 device.
It works earlier without any issues now picon are detected only in classic black hole image. But not in open Blackhole image which is installed in multiboot.
Once I unmounted 16gb Kingston device it is possible to mount 64gb Samsung device. Then I mount Kingston 16gb device back, automatically 64gb device is not mapped state . what might cause this please.
