openBH 0.4 Vu+ Duo2
Alot need to fix if you coming from original bH 3.. No personal backup.. Plugins online not working.. Usb full backup not working .. Ftb not working I don't know why cant find ip.
How can i set secend infobar for chanel ferequency and resulation size and etc
In blackhole image i went to osd setting and set it but open blackhole i cant do it
Thank you: OBH 0.4 on Vu+ Duo2, fresh install, works great except kodi.
Kodi runs but not play anything from my NAS, mkv or ISO or m2ts....
Is my first Open BH image, very good job.
i just installed, but alot of things i can't find, like blind scan, timeshift & addons plug ...etc. I'm going back to o.1
Thanks Black hole team ...Superb image and Kodi updated. Like the idea of installing any oe/a addons to suit what you want. Also the option if you want everything already installed you can stay with the black hole image
nunigaia, ho una domanda per te, se faccio un personbal backup dalla black hole 2.1.7, e poi installo la open black hole 0,4, riesco ad avere tutti i settaggi che avevo sulla precedente immagine?
Ciao SM
1. Make the backup of your Settings using dreamset 248.
2. Make a fullbackup of BlackHole 2.1.7 to HDD or to an EXTRA USB pen Drive, than you can go back or flash this one in OpenMultiboot.
1. Eseguire il backup delle impostazioni utilizzando dreamset248.
2. Fare un fullbackup di BlackHole2.1.7 per HDD o un EXTRA USB pen Drive, che si può tornare indietro o flash questo uno in OpenMultiboot.​
Cioa SM
grazie!
Cioa SM
Dimenticavo, il personal backup mi serve per trasferire tutti i settaggi dalla prima versione alla seconda, vale a dire, dalla 2.1.7alla 0.4
