USB DVB-S S2 supported?
Sorry for the late the device are hauppauge WinTV NOVA-T (RTE 2 HD very glitchy when it did work) and your Excelent recommend Tevii DVB-S/S2 TV Tuner for PC.
I hope to recover my TeVii S660 power supply to make me the possibility to test both devices on the same box.
Hi again just a little my Duo won't reconise at all my Win Tv-T stick now is there a way to telnet a command to see that it's mounted right.
Was work bit glitchy with the HD channel RTE2HD stopped all together when I got a DVB-S2 USB device, but now even with S2 device unplugged it does not see the USB T Stick!
We are working on a new set of DVB USB drivers based on latest 3.9 kernel .... Latest tests seems promising ....
I have a working 660 including psu. I don't use it since I got my solo1,so you can borrow it. Specs on Psu:7,5V ; 2Amp
I can do some testing too if relevant.
Arived Mystique SaTiX-S2
root@vuultimo:~# /usr/bin/usbtuner -V
UsbTuner v0.3.12
root@vuultimo:~# dmesg | grep usb
usb 1-2: USB disconnect, device number 3
usb 1-2: new high speed USB device number 4 using ehci-brcm
usb 1-2: USB disconnect, device number 4
usb 1-2: new high speed USB device number 5 using ehci-brcm
@gobi2000
Until angelofsky1980 will release a driver, try to find on web dvb-fe-ds300x.fw file and FTP it to /lib/firmware/ folder
Warning! Do it only for testing, it's a linuxtv driver, not BH one! Do a full backup before testing!
Hello,
i've a vu+ solo, can i ask you which is the cheapest dvb-s usb dongle that works with my stb running BH 2.0.1? I'd like to add a second tuner, especially to stream a different channel (from the one playing on tv) to the vu+ app.
Thanks in advance!
Hello,
Thanks in advance!
Here http://www.linuxtv.org/wiki/index.php/Hardware_Device_Information you can find some informations about Linux supported devices (not all are listed). After choosing those, which are supported by Linux, search for their compatibility with BH (all should be supported). Next you can look at web for prices.
You can try, but the support is not guarantee ...
If you have that device, follow instructions in THIS thread to send some debug infos.
Alright man just a quick request or question I have a tevii S2 USB tuner working great.
The only thing is now on my Duo is that my motorised won't move unless I unconfiger said tuner because there is no option for a third cable form LNB.
Tuner A is USALS and tuner B is second cable fro
Motorised LNB, tuner C Nova-T Stick enabled, tuner D ( tevii S2 usb tuner) at the moment is equal to tuner A but I have tried all config for it and i have disable it in order for the sat to move.any surgestion how to get the option third cable from LNB for the duo.
I am the latest BH 2.02.rev B
Hi,
I have a tuner SOLO2, and whether it is possible to connect three DVB-S/S2 head using a USB port? and so, what model you have tested? (I know that the heads are DVB-T, which works without problem)
REG.
What is currently the compatibility for the USB S2 tuner
"Mystique SaTix S2 V2" and its clone "DVBSKY S960"?
Thanks!
Thanks Angelo, I found this information on LinuxTV:
http://www.linuxtv.org/wiki/index.php/DVBSKY_S960
Thanks but seems there is a manufacturer driver and not a linux kernel driver but it's a step forward in the right direction.
