USB DVB-S S2 supported?
I need some infos about your device first....
Hi angelofsky1980, I came across this one on eBay Mystique Sa TiX-S2 Sky USB HDTV do you think it works on the Duo?
It says it's lynix on the description I want to buy it it's going for €35 I will wait for your approval first thanks.
It's not clear what chipset / driver this device uses.... :(
I ask the seller a question regarding the tuner this what he replied
Hello,
I assume you want to hook that device to a Linux box in addition. Basically that works, as drivers for Linux are existing, nevertheless it requires maybe compilation of your Kernel etc.
So do you think I should take a chance and buy it?
Hello,
I should have the drivers sources ... and test if they can be compiled for Mipsel arch.
And where can I get the driver sources for you do you can test them?
Or do you have them already or do I just ask the seller to email to me and pass them in to your slef,
I think drivers can be downloaded from manufacturer of the USB DVB device.
i did a Goole shearch and i can find any info about the driver for
Mystique SaTiX-S2 Sky USB, HDTV, DiseqC, USALS
if you have any luck let me know this would be a steal at EUR 39.90
opps found this info
root ~ # root ~ # dmesg | grep -i dvb
-sh: root: command not found
[ 4.070564] dvb-usb: found a 'Bestunar US6831 HD' in warm state.
root ~ # [ 4.070564] dvb-usb: found a 'Bestunar US6831 HD' in warm state.
-sh: [: missing `]'
<-usb: will pass the complete MPEG2 transport stream <-usb: will pass the complete MPEG2 transport stream to the software demuxer.
-sh: [: missing `]'
[ 4.394305] input: IR-receiver inside an USB DVB receiver as /devices/pci0000:00/0000:00:1d.7/usb1/1-4/inroot ~ # root ~ # [ 4.071060] DVB: registering new adapter (Bestunar US6831 HD)
-sh: syntax error near unexpected token `('
root ~ # [ 4.078585] dvb-usb: MAC address: ff:ff:ff:ff:ff:ff
-sh: [: missing `]'
<-usb: no frontend was attached by 'Bestunar US6831 <-usb: no frontend was attached by 'Bestunar US6831 HD'
-sh: [: missing `]'
<ut: IR-receiver inside an USB DVB receiver as /devi <USB DVB receiver as /devices/pci0000:00/0000:00:1d.7/usb1/1-4/input/input7
-sh: [: missing `]'
root ~ # [ 4.394486] dvb-usb: schedule remote query interval to 150 msecs.
-sh: [: missing `]'
<-usb: Bestunar US6831 HD successfully initialized a <-usb: Bestunar US6831 HD successfully initialized and connected.
Found this have a look when you can
Could you please post a full "dmesg" output ?
Little update: some people @ LinuxTV.org website are working to support this kind of devices :)
I don't know the state-of-the-art but I will verify shortly if there is the possibility to use it on our boxes.
Thanks for your replays, but I don't know what a dmesg" output is only the file I uploaded by doneing a lot of google shearchs
dmesg" output
Aug 17 08:33:19 openelec syslog.info syslogd started: BusyBox v1.20.2
Aug 17 08:33:19 openelec user.notice Boot: ### Starting Kernellog daemon ###
Aug 17 08:33:19 openelec user.notice kernel: klogd started: BusyBox v1.20.2 (2012-08-08 21:52:20 CEST)
Aug 17 08:33:19 openelec user.info kernel: [ 0.000000] Initializing cgroup subsys cpuset
Aug 17 08:33:19 openelec user.notice kernel: [ 0.000000] Linux version 3.2.26 (jetstream@1801-lin007) (gcc version 4.7.1 (GCC) ) #1 SMP Sun Aug 12 00:46:20 CEST 2012
Aug 17 08:33:19 openelec user.info kernel: [ 0.000000] Command line: boot=LABEL=System disk=LABEL=Storage ssh quiet BOOT_IMAGE=/KERNEL
Aug 17 08:33:19 openelec user.info kernel: [ 0.000000] KERNEL supported cpus:
Aug 17 08:33:19 openelec user.info kernel: [ 0.000000] Intel GenuineIntel
Aug 17 08:33:19 openelec user.info kernel: [ 0.000000] BIOS-provided physical RAM map:
Aug 17 08:33:19 openelec user.info kernel: [ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
Aug 17 08:33:19 openelec user.info kernel: [ 0.000000] BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
Aug 17 08:33:19 openelec user.info kernel: [ 0.000000] BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
Aug 17 08:33:19 openelec user.info kernel: [ 0.000000] BIOS-e820: 0000000000100000 - 000000007ffa0000 (usable)
Aug 17 08:33:19 openelec user.info kernel: [ 0.000000] BIOS-e820: 000000007ffa0000 - 000000007ffae000 (ACPI data)
Aug 17 08:33:19 openelec user.info kernel: [ 0.000000] BIOS-e820: 000000007ffae000 - 000000007ffe0000 (ACPI NVS)
Aug 17 08:33:19 openelec user.info kernel: [ 0.000000] BIOS-e820: 000000007ffe0000 - 0000000080000000 (reserved)
Aug 17 08:33:19 openelec user.info kernel: [ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
Aug 17 08:33:19 openelec user.info kernel: [ 0.000000] BIOS-e820: 00000000fff00000 - 0000000100000000 (reserved)
Aug 17 08:33:19 openelec user.info kernel: [ 0.000000] NX (Execute Disable) protection: active
Aug 17 08:33:19 openelec user.info kernel: [ 0.000000] DMI present.
Aug 17 08:33:19 openelec user.debug kernel: [ 0.000000] DMI: ASUSTeK Computer INC. EB1501P/EB1501P, BIOS 0601 02/03/2012
Aug 17 08:33:19 openelec user.debug kernel: [ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
Aug 17 08:33:19 openelec user.debug kernel: [ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
Aug 17 08:33:19 openelec user.info kernel: [ 0.000000] last_pfn = 0x7ffa0 max_arch_pfn = 0x400000000
Aug 17 08:33:19 openelec user.debug kernel: [ 0.000000] MTRR default type: uncachable
Aug 17 08:33:19 openelec user.debug kernel: [ 0.000000] MTRR fixed ranges enabled:
Aug 17 08:33:19 openelec user.debug kernel: [ 0.000000] 00000-9FFFF write-back
Aug 17 08:33:19 openelec user.debug kernel: [ 0.000000] A0000-BFFFF uncachable
Aug 17 08:33:19 openelec user.debug kernel: [ 0.000000] C0000-CFFFF write-protect
Aug 17 08:33:19 openelec user.debug kernel: [ 0.000000] D0000-DFFFF uncachable
Aug 17 08:33:19 openelec user.debug kernel: [ 0.000000] E0000-EFFFF write-through
Aug 17 08:33:19 openelec user.debug kernel: [ 0.000000] F0000-FFFFF write-protect
Aug 17 08:33:19 openelec user.debug kernel: [ 0.000000] MTRR variable ranges enabled:
Aug 17 08:33:19 openelec user.debug kernel: [ 0.000000] 0 base 000000000 mask F80000000 write-back
Aug 17 08:33:19 openelec user.debug kernel: [ 0.000000] 1 disabled
Aug 17 08:33:19 openelec user.debug kernel: [ 0.000000] 2 disabled
Aug 17 08:33:19 openelec user.debug kernel: [ 0.000000] 3 disabled
Aug 17 08:33:19 openelec user.debug kernel: [ 0.000000] 4 disabled
Aug 17 08:33:19 openelec user.debug kernel: [ 0.000000] 5 disabled
Aug 17 08:33:19 openelec user.debug kernel: [ 0.000000] 6 disabled
Aug 17 08:33:19 openelec user.debug kernel: [ 0.000000] 7 disabled
Aug 17 08:33:19 openelec user.info kernel: [ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
Aug 17 08:33:19 openelec user.info kernel: [ 0.000000] found SMP MP-table at [ffff8800000ff780] ff780
Aug 17 08:33:19 openelec user.debug kernel: [ 0.000000] initial memory mapped : 0 - 20000000
Aug 17 08:33:19 openelec user.debug kernel: [ 0.000000] Base memory trampoline at [ffff88000009a000] 9a000 size 20480
Aug 17 08:33:19 openelec user.info kernel: [ 0.000000] init_memory_mapping: 0000000000000000-000000007ffa0000
Aug 17 08:33:19 openelec user.debug kernel: [ 0.000000] 0000000000 - 007fe00000 page 2M
Aug 17 08:33:19 openelec user.debug kernel: [ 0.000000] 007fe00000 - 007ffa0000 page 4k
Aug 17 08:33:19 openelec user.debug kernel: [ 0.000000] kernel direct mapping tables up to 7ffa0000 @ 1fffc000-20000000
Aug 17 08:33:19 openelec user.warn kernel: [ 0.000000] ACPI: RSDP 00000000000fbb70 00024 (v02 ACPIAM)
Aug 17 08:33:19 openelec user.warn kernel: [ 0.000000] ACPI: XSDT 000000007ffa0100 0004C (v01 020312 XSDT1608 20120203 MSFT 00000097)
Aug 17 08:33:19 openelec user.warn kernel: [ 0.000000] ACPI: FACP 000000007ffa0290 000F4 (v03 020312 FACP1608 20120203 MSFT 00000097)
Aug 17 08:33:19 openelec user.warn kernel: [ 0.000000] ACPI: DSDT 000000007ffa0440 05D1C (v01 A1654 A1654000 00000000 INTL 20060113)
Aug 17 08:33:19 openelec user.warn kernel: [ 0.000000] ACPI: FACS 000000007ffae000 00040
Aug 17 08:33:19 openelec user.warn kernel: [ 0.000000] ACPI: APIC 000000007ffa0390 0006C (v01 020312 APIC1608 20120203 MSFT 00000097)
Aug 17 08:33:19 openelec user.warn kernel: [ 0.000000] ACPI: MCFG 000000007ffa0400 0003C (v01 020312 OEMMCFG 20120203 MSFT 00000097)
Aug 17 08:33:19 openelec user.warn kernel: [ 0.000000] ACPI: OEMB 000000007ffae040 00072 (v01 020312 OEMB1608 20120203 MSFT 00000097)
Aug 17 08:33:19 openelec user.warn kernel: [ 0.000000] ACPI: HPET 000000007ffaa440 00038 (v01 020312 OEMHPET 20120203 MSFT 00000097)
Aug 17 08:33:19 openelec user.debug kernel: [ 0.000000] ACPI: Local APIC address 0xfee00000
Aug 17 08:33:19 openelec user.debug kernel: [ 0.000000] [ffffea0000000000-ffffea0001bfffff] PMD -> [ffff88007d600000-ffff88007f1fffff] on node 0
Aug 17 08:33:19 openelec user.warn kernel: [ 0.000000] Zone PFN ranges:
Aug 17 08:33:19 openelec user.warn kernel: [ 0.000000] DMA 0x00000010 -> 0x00001000
Aug 17 08:33:19 openelec user.warn kernel: [ 0.000000] DMA32 0x00001000 -> 0x00100000
Aug 17 08:33:19 openelec user.warn kernel: [ 0.000000] Normal empty
Aug 17 08:33:19 openelec user.warn kernel: [ 0.000000] Movable zone start PFN for each node
Aug 17 08:33:19 openelec user.warn kernel: [ 0.000000] early_node_map[2] active PFN ranges
Aug 17 08:33:19 openelec user.warn kernel: [ 0.000000] 0: 0x00000010 -> 0x0000009f
Aug 17 08:33:19 openelec user.warn kernel: [ 0.000000] 0: 0x00000100 -> 0x0007ffa0
Aug 17 08:33:19 openelec user.debug kernel: [ 0.000000] On node 0 totalpages: 524079
Aug 17 08:33:19 openelec user.debug kernel: [ 0.000000] DMA zone: 56 pages used for memmap
Aug 17 08:33:19 openelec user.debug kernel: [ 0.000000] DMA zone: 5 pages reserved
Aug 17 08:33:19 openelec user.debug kernel: [ 0.000000] DMA zone: 3922 pages, LIFO batch:0
Aug 17 08:33:19 openelec user.debug kernel: [ 0.000000] DMA32 zone: 7111 pages used for memmap
Aug 17 08:33:19 openelec user.debug kernel: [ 0.000000] DMA32 zone: 512985 pages, LIFO batch:31
Aug 17 08:33:19 openelec user.info kernel: [ 0.000000] ACPI: PM-Timer IO Port: 0x808
Aug 17 08:33:19 openelec user.info kernel: [ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
Aug 17 08:33:19 openelec user.info kernel: [ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] enabled)
Aug 17 08:33:19 openelec user.info kernel: [ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x01] enabled)
Aug 17 08:33:19 openelec user.info kernel: [ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x03] enabled)
Aug 17 08:33:19 openelec user.info kernel: [ 0.000000] ACPI: IOAPIC (id[0x04] address[0xfec00000] gsi_base[0])
Aug 17 08:33:19 openelec user.info kernel: [ 0.000000] IOAPIC[0]: apic_id 4, version 32, address 0xfec00000, GSI 0-23
Aug 17 08:33:19 openelec user.info kernel: [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
Aug 17 08:33:19 openelec user.info kernel: [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
Aug 17 08:33:19 openelec user.debug kernel: [ 0.000000] ACPI: IRQ0 used by override.
Aug 17 08:33:19 openelec user.debug kernel: [ 0.000000] ACPI: IRQ2 used by override.
Aug 17 08:33:19 openelec user.debug kernel: [ 0.000000] ACPI: IRQ9 used by override.
Aug 17 08:33:19 openelec user.info kernel: [ 0.000000] Using ACPI (MADT) for SMP configuration information
Aug 17 08:33:19 openelec user.info kernel: [ 0.000000] ACPI: HPET id: 0xffffffff base: 0xfed00000
Aug 17 08:33:19 openelec user.info kernel: [ 0.000000] SMP: Allowing 4 CPUs, 0 hotplug CPUs
Aug 17 08:33:19 openelec user.debug kernel: [ 0.000000] nr_irqs_gsi: 40
Aug 17 08:33:19 openelec user.info kernel: [ 0.000000] Allocating PCI resources starting at 80000000 (gap: 80000000:7ee00000)
Aug 17 08:33:19 openelec user.info kernel: [ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:4 nr_node_ids:1
Aug 17 08:33:19 openelec user.info kernel: [ 0.000000] PERCPU: Embedded 25 pages/cpu @ffff88007fc00000 s70208 r8192 d24000 u524288
Aug 17 08:33:19 openelec user.debug kernel: [ 0.000000] pcpu-alloc: s70208 r8192 d24000 u524288 alloc=1*2097152
Aug 17 08:33:19 openelec user.debug kernel: [ 0.000000] pcpu-alloc: [0] 0 1 2 3
Aug 17 08:33:19 openelec user.warn kernel: [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 516907
Aug 17 08:33:19 openelec user.notice kernel: [ 0.000000] Kernel command line: fastboot root=/dev/ram0 rdinit=/init threadirqs boot=LABEL=System disk=LABEL=Storage ssh quiet BOOT_IMAGE=/KERNEL
Aug 17 08:33:19 openelec user.info kernel: [ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
Aug 17 08:33:19 openelec user.info kernel: [ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
Aug 17 08:33:19 openelec user.info kernel: [ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
Aug 17 08:33:19 openelec user.info kernel: [ 0.000000] Memory: 2050600k/2096768k available (4702k kernel code, 452k absent, 45716k reserved, 3938k data, 4364k init)
Aug 17 08:33:19 openelec user.info kernel: [ 0.000000] Hierarchical RCU implementation.
Aug 17 08:33:19 openelec user.info kernel: [ 0.000000] CONFIG_RCU_FANOUT set to non-default value of 32
Aug 17 08:33:19 openelec user.info kernel: [ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
Aug 17 08:33:19 openelec user.info kernel: [ 0.000000] NR_IRQS:4352 nr_irqs:712 16
Aug 17 08:33:19 openelec user.info kernel: [ 0.000000] Extended CMOS year: 2000
Aug 17 08:33:19 openelec user.info kernel: [ 0.000000] Console: colour VGA+ 80x25
Aug 17 08:33:19 openelec user.info kernel: [ 0.000000] console [tty0] enabled
Aug 17 08:33:19 openelec user.debug kernel: [ 0.000000] hpet clockevent registered
Aug 17 08:33:19 openelec user.warn kernel: [ 0.000000] Fast TSC calibration using PIT
Aug 17 08:33:19 openelec user.warn kernel: [ 0.000000] Detected 1795.612 MHz processor.
Aug 17 08:33:19 openelec user.info kernel: [ 0.003339] Calibrating delay loop (skipped), value calculated using timer frequency.. 3592.85 BogoMIPS (lpj=5985373)
Aug 17 08:33:19 openelec user.info kernel: [ 0.003348] pid_max: default: 32768 minimum: 301
Aug 17 08:33:19 openelec user.info kernel: [ 0.003468] Mount-cache hash table entries: 256
Aug 17 08:33:19 openelec user.info kernel: [ 0.003678] Initializing cgroup subsys cpuacct
Aug 17 08:33:19 openelec user.info kernel: [ 0.003689] Initializing cgroup subsys freezer
Aug 17 08:33:19 openelec user.info kernel: [ 0.003721] CPU: Physical Processor ID: 0
Aug 17 08:33:19 openelec user.info kernel: [ 0.003725] CPU: Processor Core ID: 0
Aug 17 08:33:19 openelec user.info kernel: [ 0.003729] using mwait in idle threads.
Aug 17 08:33:19 openelec user.info kernel: [ 0.003771] ACPI: Core revision 20111123
Aug 17 08:33:19 openelec user.info kernel: [ 0.013804] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
Aug 17 08:33:19 openelec user.info kernel: [ 0.049017] CPU0: Intel(R) Atom(TM) CPU D525 @ 1.80GHz stepping 0a
Aug 17 08:33:19 openelec user.info kernel: [ 0.049997] Performance Events: PEBS fmt0+, Atom events, Intel PMU driver.
Aug 17 08:33:19 openelec user.info kernel: [ 0.049997] ... version: 3
Aug 17 08:33:19 openelec user.info kernel: [ 0.049997] ... bit width: 40
Aug 17 08:33:19 openelec user.info kernel: [ 0.049997] ... generic registers: 2
Aug 17 08:33:19 openelec user.info kernel: [ 0.049997] ... value mask: 000000ffffffffff
Aug 17 08:33:19 openelec user.info kernel: [ 0.049997] ... max period: 000000007fffffff
Aug 17 08:33:19 openelec user.info kernel: [ 0.049997] ... fixed-purpose events: 3
Aug 17 08:33:19 openelec user.info kernel: [ 0.049997] ... event mask: 0000000700000003
Aug 17 08:33:19 openelec user.info kernel: [ 0.049997] Booting Node 0, Processors #1
Aug 17 08:33:19 openelec user.debug kernel: [ 0.049997] smpboot cpu 1: start_ip = 9a000
Aug 17 08:33:19 openelec user.notice kernel: [ 0.006666] calibrate_delay_direct() dropping min bogoMips estimate 3 = 4346079
Aug 17 08:33:19 openelec user.info kernel: [ 0.006666] Disabled fast string operations
Aug 17 08:33:19 openelec user.warn kernel: [ 0.143526] #2
Aug 17 08:33:19 openelec user.debug kernel: [ 0.143531] smpboot cpu 2: start_ip = 9a000
Aug 17 08:33:19 openelec user.warn kernel: [ 0.240224] #3 Ok.
Aug 17 08:33:19 openelec user.debug kernel: [ 0.240228] smpboot cpu 3: start_ip = 9a000
Aug 17 08:33:19 openelec user.info kernel: [ 0.336666] Brought up 4 CPUs
Aug 17 08:33:19 openelec user.info kernel: [ 0.336673] Total of 4 processors activated (14370.99 BogoMIPS).
Aug 17 08:33:19 openelec user.info kernel: [ 0.337747] devtmpfs: initialized
Aug 17 08:33:19 openelec user.info kernel: [ 0.337747] NET: Registered protocol family 16
Aug 17 08:33:19 openelec user.info kernel: [ 0.337747] ACPI: bus type pci registered
Aug 17 08:33:19 openelec user.info kernel: [ 0.337747] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
Aug 17 08:33:19 openelec user.info kernel: [ 0.337747] PCI: not using MMCONFIG
Aug 17 08:33:19 openelec user.info kernel: [ 0.337747] PCI: Using configuration type 1 for base access
Aug 17 08:33:19 openelec user.info kernel: [ 0.341806] bio: create slab <bio-0> at 0
Aug 17 08:33:19 openelec user.info kernel: [ 0.341806] ACPI: Added _OSI(Module Device)
Aug 17 08:33:19 openelec user.info kernel: [ 0.341806] ACPI: Added _OSI(Processor Device)
Aug 17 08:33:19 openelec user.info kernel: [ 0.341806] ACPI: Added _OSI(3.0 _SCP Extensions)
Aug 17 08:33:19 openelec user.info kernel: [ 0.341806] ACPI: Added _OSI(Processor Aggregator Device)
Aug 17 08:33:19 openelec user.debug kernel: [ 0.344486] ACPI: EC: Look up EC in DSDT
Aug 17 08:33:19 openelec user.warn kernel: [ 0.347005] ACPI: Executed 1 blocks of module-level executable AML code
Aug 17 08:33:19 openelec user.info kernel: [ 0.352261] ACPI: Interpreter enabled
Aug 17 08:33:19 openelec user.info kernel: [ 0.352272] ACPI: (supports S0 S1 S3 S5)
Aug 17 08:33:19 openelec user.info kernel: [ 0.352316] ACPI: Using IOAPIC for interrupt routing
Aug 17 08:33:19 openelec user.info kernel: [ 0.352383] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
Aug 17 08:33:19 openelec user.info kernel: [ 0.354231] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in ACPI motherboard resources
Aug 17 08:33:19 openelec user.info kernel: [ 0.401034] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
Aug 17 08:33:19 openelec user.info kernel: [ 0.401252] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
Aug 17 08:33:19 openelec user.info kernel: [ 0.401686] pci_root PNP0A08:00: host bridge window [io 0x0000-0x0cf7]
Aug 17 08:33:19 openelec user.info kernel: [ 0.401693] pci_root PNP0A08:00: host bridge window [io 0x0d00-0xffff]
Aug 17 08:33:19 openelec user.info kernel: [ 0.401699] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff]
Aug 17 08:33:19 openelec user.info kernel: [ 0.401705] pci_root PNP0A08:00: host bridge window [mem 0x000d0000-0x000dffff]
Aug 17 08:33:19 openelec user.info kernel: [ 0.401711] pci_root PNP0A08:00: host bridge window [mem 0x80000000-0xdfffffff]
Aug 17 08:33:19 openelec user.info kernel: [ 0.401717] pci_root PNP0A08:00: host bridge window [mem 0xf0000000-0xfed8ffff]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.401743] pci 0000:00:00.0: [8086:a000] type 0 class 0x000600
Aug 17 08:33:19 openelec user.debug kernel: [ 0.401821] pci 0000:00:1b.0: [8086:27d8] type 0 class 0x000403
Aug 17 08:33:19 openelec user.debug kernel: [ 0.401840] pci 0000:00:1b.0: reg 10: [mem 0xf9ff8000-0xf9ffbfff 64bit]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.401910] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
Aug 17 08:33:19 openelec user.debug kernel: [ 0.401917] pci 0000:00:1b.0: PME# disabled
Aug 17 08:33:19 openelec user.debug kernel: [ 0.401942] pci 0000:00:1c.0: [8086:27d0] type 1 class 0x000604
Aug 17 08:33:19 openelec user.debug kernel: [ 0.402013] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
Aug 17 08:33:19 openelec user.debug kernel: [ 0.402020] pci 0000:00:1c.0: PME# disabled
Aug 17 08:33:19 openelec user.debug kernel: [ 0.402044] pci 0000:00:1c.1: [8086:27d2] type 1 class 0x000604
Aug 17 08:33:19 openelec user.debug kernel: [ 0.402114] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
Aug 17 08:33:19 openelec user.debug kernel: [ 0.402120] pci 0000:00:1c.1: PME# disabled
Aug 17 08:33:19 openelec user.debug kernel: [ 0.402147] pci 0000:00:1c.2: [8086:27d4] type 1 class 0x000604
Aug 17 08:33:19 openelec user.debug kernel: [ 0.402216] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
Aug 17 08:33:19 openelec user.debug kernel: [ 0.402223] pci 0000:00:1c.2: PME# disabled
Aug 17 08:33:19 openelec user.debug kernel: [ 0.402247] pci 0000:00:1c.3: [8086:27d6] type 1 class 0x000604
Aug 17 08:33:19 openelec user.debug kernel: [ 0.402317] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
Aug 17 08:33:19 openelec user.debug kernel: [ 0.402323] pci 0000:00:1c.3: PME# disabled
Aug 17 08:33:19 openelec user.debug kernel: [ 0.402350] pci 0000:00:1d.0: [8086:27c8] type 0 class 0x000c03
Aug 17 08:33:19 openelec user.debug kernel: [ 0.402392] pci 0000:00:1d.0: reg 20: [io 0xb880-0xb89f]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.402429] pci 0000:00:1d.1: [8086:27c9] type 0 class 0x000c03
Aug 17 08:33:19 openelec user.debug kernel: [ 0.402470] pci 0000:00:1d.1: reg 20: [io 0xbc00-0xbc1f]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.402508] pci 0000:00:1d.2: [8086:27ca] type 0 class 0x000c03
Aug 17 08:33:19 openelec user.debug kernel: [ 0.402550] pci 0000:00:1d.2: reg 20: [io 0xc000-0xc01f]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.402587] pci 0000:00:1d.3: [8086:27cb] type 0 class 0x000c03
Aug 17 08:33:19 openelec user.debug kernel: [ 0.402627] pci 0000:00:1d.3: reg 20: [io 0xc080-0xc09f]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.402674] pci 0000:00:1d.7: [8086:27cc] type 0 class 0x000c03
Aug 17 08:33:19 openelec user.debug kernel: [ 0.402696] pci 0000:00:1d.7: reg 10: [mem 0xf9fff800-0xf9fffbff]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.402777] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
Aug 17 08:33:19 openelec user.debug kernel: [ 0.402784] pci 0000:00:1d.7: PME# disabled
Aug 17 08:33:19 openelec user.debug kernel: [ 0.402806] pci 0000:00:1e.0: [8086:2448] type 1 class 0x000604
Aug 17 08:33:19 openelec user.debug kernel: [ 0.402874] pci 0000:00:1f.0: [8086:27bc] type 0 class 0x000601
Aug 17 08:33:19 openelec user.info kernel: [ 0.402951] pci 0000:00:1f.0: [Firmware Bug]: TigerPoint LPC.BM_STS cleared
Aug 17 08:33:19 openelec user.debug kernel: [ 0.403002] pci 0000:00:1f.2: [8086:27c1] type 0 class 0x000106
Aug 17 08:33:19 openelec user.debug kernel: [ 0.403021] pci 0000:00:1f.2: reg 10: [io 0xcc00-0xcc07]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.403032] pci 0000:00:1f.2: reg 14: [io 0xc880-0xc883]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.403043] pci 0000:00:1f.2: reg 18: [io 0xc800-0xc807]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.403054] pci 0000:00:1f.2: reg 1c: [io 0xc480-0xc483]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.403065] pci 0000:00:1f.2: reg 20: [io 0xc400-0xc41f]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.403076] pci 0000:00:1f.2: reg 24: [mem 0xf9fffc00-0xf9ffffff]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.403119] pci 0000:00:1f.2: PME# supported from D3hot
Aug 17 08:33:19 openelec user.debug kernel: [ 0.403125] pci 0000:00:1f.2: PME# disabled
Aug 17 08:33:19 openelec user.debug kernel: [ 0.403148] pci 0000:00:1f.3: [8086:27da] type 0 class 0x000c05
Aug 17 08:33:19 openelec user.debug kernel: [ 0.403200] pci 0000:00:1f.3: reg 20: [io 0x0400-0x041f]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.403317] pci 0000:05:00.0: [1033:0194] type 0 class 0x000c03
Aug 17 08:33:19 openelec user.debug kernel: [ 0.403348] pci 0000:05:00.0: reg 10: [mem 0xfbffe000-0xfbffffff 64bit]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.403491] pci 0000:05:00.0: PME# supported from D0 D3hot D3cold
Aug 17 08:33:19 openelec user.debug kernel: [ 0.403500] pci 0000:05:00.0: PME# disabled
Aug 17 08:33:19 openelec user.info kernel: [ 0.409993] pci 0000:00:1c.0: PCI bridge to [bus 05-05]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.410003] pci 0000:00:1c.0: bridge window [mem 0xfbf00000-0xfbffffff]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.410031] pci 0000:04:00.0: [10ec:8168] type 0 class 0x000200
Aug 17 08:33:19 openelec user.debug kernel: [ 0.410052] pci 0000:04:00.0: reg 10: [io 0xe800-0xe8ff]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.410083] pci 0000:04:00.0: reg 18: [mem 0xf8fff000-0xf8ffffff 64bit pref]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.410104] pci 0000:04:00.0: reg 20: [mem 0xf8ff8000-0xf8ffbfff 64bit pref]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.410182] pci 0000:04:00.0: supports D1 D2
Aug 17 08:33:19 openelec user.debug kernel: [ 0.410187] pci 0000:04:00.0: PME# supported from D0 D1 D2 D3hot D3cold
Aug 17 08:33:19 openelec user.debug kernel: [ 0.410195] pci 0000:04:00.0: PME# disabled
Aug 17 08:33:19 openelec user.info kernel: [ 0.416715] pci 0000:00:1c.1: PCI bridge to [bus 04-04]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.416715] pci 0000:00:1c.1: bridge window [io 0xe000-0xefff]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.416715] pci 0000:00:1c.1: bridge window [mem 0xf8f00000-0xf8ffffff 64bit pref]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.416743] pci 0000:03:00.0: [168c:002b] type 0 class 0x000280
Aug 17 08:33:19 openelec user.debug kernel: [ 0.416769] pci 0000:03:00.0: reg 10: [mem 0xfbee0000-0xfbeeffff 64bit]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.416875] pci 0000:03:00.0: supports D1
Aug 17 08:33:19 openelec user.debug kernel: [ 0.416880] pci 0000:03:00.0: PME# supported from D0 D1 D3hot D3cold
Aug 17 08:33:19 openelec user.debug kernel: [ 0.416888] pci 0000:03:00.0: PME# disabled
Aug 17 08:33:19 openelec user.info kernel: [ 0.423322] pci 0000:00:1c.2: PCI bridge to [bus 03-03]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.423331] pci 0000:00:1c.2: bridge window [mem 0xfbe00000-0xfbefffff]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.423347] pci 0000:02:00.0: [10de:0a64] type 0 class 0x000300
Aug 17 08:33:19 openelec user.debug kernel: [ 0.423367] pci 0000:02:00.0: reg 10: [mem 0xfa000000-0xfaffffff]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.423387] pci 0000:02:00.0: reg 14: [mem 0xd0000000-0xdfffffff 64bit pref]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.423407] pci 0000:02:00.0: reg 1c: [mem 0xce000000-0xcfffffff 64bit pref]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.423422] pci 0000:02:00.0: reg 24: [io 0xdc00-0xdc7f]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.423436] pci 0000:02:00.0: reg 30: [mem 0xfbd00000-0xfbd7ffff pref]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.423534] pci 0000:02:00.1: [10de:0be3] type 0 class 0x000403
Aug 17 08:33:19 openelec user.debug kernel: [ 0.423552] pci 0000:02:00.1: reg 10: [mem 0xfbdfc000-0xfbdfffff]
Aug 17 08:33:19 openelec user.info kernel: [ 0.430047] pci 0000:00:1c.3: PCI bridge to [bus 02-02]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.430047] pci 0000:00:1c.3: bridge window [io 0xd000-0xdfff]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.430047] pci 0000:00:1c.3: bridge window [mem 0xfa000000-0xfbdfffff]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.430047] pci 0000:00:1c.3: bridge window [mem 0xce000000-0xdfffffff 64bit pref]
Aug 17 08:33:19 openelec user.info kernel: [ 0.430085] pci 0000:00:1e.0: PCI bridge to [bus 01-01] (subtractive decode)
Aug 17 08:33:19 openelec user.debug kernel: [ 0.430098] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7] (subtractive decode)
Aug 17 08:33:19 openelec user.debug kernel: [ 0.430104] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff] (subtractive decode)
Aug 17 08:33:19 openelec user.debug kernel: [ 0.430110] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
Aug 17 08:33:19 openelec user.debug kernel: [ 0.430117] pci 0000:00:1e.0: bridge window [mem 0x000d0000-0x000dffff] (subtractive decode)
Aug 17 08:33:19 openelec user.debug kernel: [ 0.430123] pci 0000:00:1e.0: bridge window [mem 0x80000000-0xdfffffff] (subtractive decode)
Aug 17 08:33:19 openelec user.debug kernel: [ 0.430129] pci 0000:00:1e.0: bridge window [mem 0xf0000000-0xfed8ffff] (subtractive decode)
Aug 17 08:33:19 openelec user.debug kernel: [ 0.430154] pci_bus 0000:00: on NUMA node 0
Aug 17 08:33:19 openelec user.debug kernel: [ 0.430163] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.430410] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P4._PRT]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.430492] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P5._PRT]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.430546] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P6._PRT]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.430600] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P7._PRT]
Aug 17 08:33:19 openelec user.info kernel: [ 0.430712] pci0000:00: Requesting ACPI _OSC control (0x1d)
Aug 17 08:33:19 openelec user.info kernel: [ 0.430720] pci0000:00: ACPI _OSC request failed (AE_NOT_FOUND), returned control mask: 0x1d
Aug 17 08:33:19 openelec user.info kernel: [ 0.430724] ACPI _OSC control for PCIe not granted, disabling ASPM
Aug 17 08:33:19 openelec user.info kernel: [ 0.443336] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 7 10 11 12 14 *15)
Aug 17 08:33:19 openelec user.info kernel: [ 0.443471] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 *5 7 10 11 12 14 15)
Aug 17 08:33:19 openelec user.info kernel: [ 0.443588] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 7 10 *11 12 14 15)
Aug 17 08:33:19 openelec user.info kernel: [ 0.443704] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 7 *10 11 12 14 15)
Aug 17 08:33:19 openelec user.info kernel: [ 0.443820] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 *4 5 7 10 11 12 14 15)
Aug 17 08:33:19 openelec user.info kernel: [ 0.443936] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 *7 10 11 12 14 15)
Aug 17 08:33:19 openelec user.info kernel: [ 0.444051] ACPI: PCI Interrupt Link [LNKG] (IRQs *3 4 5 7 10 11 12 14 15)
Aug 17 08:33:19 openelec user.info kernel: [ 0.444167] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 7 10 11 12 *14 15)
Aug 17 08:33:19 openelec user.info kernel: [ 0.444327] vgaarb: device added: PCI:0000:02:00.0,decodes=io+mem,owns=io+mem,locks=none
Aug 17 08:33:19 openelec user.info kernel: [ 0.444327] vgaarb: loaded
Aug 17 08:33:19 openelec user.info kernel: [ 0.444327] vgaarb: bridge control possible 0000:02:00.0
Aug 17 08:33:19 openelec user.notice kernel: [ 0.444327] SCSI subsystem initialized
Aug 17 08:33:19 openelec user.debug kernel: [ 0.444327] libata version 3.00 loaded.
Aug 17 08:33:19 openelec user.info kernel: [ 0.444327] usbcore: registered new interface driver usbfs
Aug 17 08:33:19 openelec user.info kernel: [ 0.444327] usbcore: registered new interface driver hub
Aug 17 08:33:19 openelec user.info kernel: [ 0.444327] usbcore: registered new device driver usb
Aug 17 08:33:19 openelec user.info kernel: [ 0.444327] PCI: Using ACPI for IRQ routing
Aug 17 08:33:19 openelec user.debug kernel: [ 0.450460] PCI: pci_cache_line_size set to 64 bytes
Aug 17 08:33:19 openelec user.debug kernel: [ 0.450565] reserve RAM buffer: 000000000009fc00 - 000000000009ffff
Aug 17 08:33:19 openelec user.debug kernel: [ 0.450571] reserve RAM buffer: 000000007ffa0000 - 000000007fffffff
Aug 17 08:33:19 openelec user.info kernel: [ 0.450867] cfg80211: Calling CRDA to update world regulatory domain
Aug 17 08:33:19 openelec user.info kernel: [ 0.450933] HPET: 3 timers in total, 0 timers will be used for per-cpu timer
Aug 17 08:33:19 openelec user.info kernel: [ 0.460068] Switching to clocksource hpet
Aug 17 08:33:19 openelec user.info kernel: [ 0.460119] pnp: PnP ACPI init
Aug 17 08:33:19 openelec user.info kernel: [ 0.460146] ACPI: bus type pnp registered
Aug 17 08:33:19 openelec user.debug kernel: [ 0.460393] pnp 00:00: [bus 00-ff]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.460400] pnp 00:00: [io 0x0cf8-0x0cff]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.460406] pnp 00:00: [io 0x0000-0x0cf7 window]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.460411] pnp 00:00: [io 0x0d00-0xffff window]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.460417] pnp 00:00: [mem 0x000a0000-0x000bffff window]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.460422] pnp 00:00: [mem 0x000d0000-0x000dffff window]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.460428] pnp 00:00: [mem 0x80000000-0xdfffffff window]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.460433] pnp 00:00: [mem 0xf0000000-0xfed8ffff window]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.460526] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
Aug 17 08:33:19 openelec user.debug kernel: [ 0.460557] pnp 00:01: [mem 0xfed14000-0xfed19fff]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.460563] pnp 00:01: [mem 0xfed90000-0xfed93fff]
Aug 17 08:33:19 openelec user.info kernel: [ 0.460653] system 00:01: [mem 0xfed14000-0xfed19fff] has been reserved
Aug 17 08:33:19 openelec user.info kernel: [ 0.460660] system 00:01: [mem 0xfed90000-0xfed93fff] has been reserved
Aug 17 08:33:19 openelec user.debug kernel: [ 0.460668] system 00:01: Plug and Play ACPI device, IDs PNP0c01 (active)
Aug 17 08:33:19 openelec user.debug kernel: [ 0.460744] pnp 00:02: [dma 4]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.460750] pnp 00:02: [io 0x0000-0x000f]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.460755] pnp 00:02: [io 0x0081-0x0083]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.460759] pnp 00:02: [io 0x0087]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.460764] pnp 00:02: [io 0x0089-0x008b]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.460772] pnp 00:02: [io 0x008f]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.460776] pnp 00:02: [io 0x00c0-0x00df]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.460828] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
Aug 17 08:33:19 openelec user.debug kernel: [ 0.460857] pnp 00:03: [io 0x0070-0x0071]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.460874] pnp 00:03: [irq 8]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.460929] pnp 00:03: Plug and Play ACPI device, IDs PNP0b00 (active)
Aug 17 08:33:19 openelec user.debug kernel: [ 0.460953] pnp 00:04: [io 0x0061]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.461008] pnp 00:04: Plug and Play ACPI device, IDs PNP0800 (active)
Aug 17 08:33:19 openelec user.debug kernel: [ 0.461035] pnp 00:05: [io 0x00f0-0x00ff]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.461047] pnp 00:05: [irq 13]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.461102] pnp 00:05: Plug and Play ACPI device, IDs PNP0c04 (active)
Aug 17 08:33:19 openelec user.debug kernel: [ 0.461520] pnp 00:06: [io 0x0000-0xffffffffffffffff disabled]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.461526] pnp 00:06: [io 0x0a00-0x0a0f]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.461531] pnp 00:06: [io 0x0290-0x029f]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.461536] pnp 00:06: [io 0x0a20-0x0a2f]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.461541] pnp 00:06: [io 0x0a30-0x0a3f]
Aug 17 08:33:19 openelec user.info kernel: [ 0.461632] system 00:06: [io 0x0a00-0x0a0f] has been reserved
Aug 17 08:33:19 openelec user.info kernel: [ 0.461639] system 00:06: [io 0x0290-0x029f] has been reserved
Aug 17 08:33:19 openelec user.info kernel: [ 0.461645] system 00:06: [io 0x0a20-0x0a2f] has been reserved
Aug 17 08:33:19 openelec user.info kernel: [ 0.461651] system 00:06: [io 0x0a30-0x0a3f] has been reserved
Aug 17 08:33:19 openelec user.debug kernel: [ 0.461659] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
Aug 17 08:33:19 openelec user.debug kernel: [ 0.461934] pnp 00:07: [io 0x0010-0x001f]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.461940] pnp 00:07: [io 0x0022-0x003f]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.461945] pnp 00:07: [io 0x0044-0x005f]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.461950] pnp 00:07: [io 0x0062-0x0063]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.461954] pnp 00:07: [io 0x0065-0x006f]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.461959] pnp 00:07: [io 0x0072-0x007f]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.461964] pnp 00:07: [io 0x0080]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.461968] pnp 00:07: [io 0x0084-0x0086]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.461973] pnp 00:07: [io 0x0088]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.461978] pnp 00:07: [io 0x008c-0x008e]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.461982] pnp 00:07: [io 0x0090-0x009f]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.461987] pnp 00:07: [io 0x00a2-0x00bf]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.461992] pnp 00:07: [io 0x00e0-0x00ef]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.461997] pnp 00:07: [io 0x04d0-0x04d1]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.462002] pnp 00:07: [io 0x0800-0x087f]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.462007] pnp 00:07: [io 0x0400-0x03ff disabled]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.462012] pnp 00:07: [io 0x0480-0x04bf]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.462017] pnp 00:07: [mem 0xfed1c000-0xfed1ffff]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.462022] pnp 00:07: [mem 0xfed20000-0xfed8ffff]
Aug 17 08:33:19 openelec user.info kernel: [ 0.462131] system 00:07: [io 0x04d0-0x04d1] has been reserved
Aug 17 08:33:19 openelec user.info kernel: [ 0.462138] system 00:07: [io 0x0800-0x087f] has been reserved
Aug 17 08:33:19 openelec user.info kernel: [ 0.462145] system 00:07: [io 0x0480-0x04bf] has been reserved
Aug 17 08:33:19 openelec user.info kernel: [ 0.462152] system 00:07: [mem 0xfed1c000-0xfed1ffff] has been reserved
Aug 17 08:33:19 openelec user.info kernel: [ 0.462159] system 00:07: [mem 0xfed20000-0xfed8ffff] has been reserved
Aug 17 08:33:19 openelec user.debug kernel: [ 0.462166] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
Aug 17 08:33:19 openelec user.debug kernel: [ 0.462333] pnp 00:08: [mem 0xfed00000-0xfed003ff]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.462394] pnp 00:08: Plug and Play ACPI device, IDs PNP0103 (active)
Aug 17 08:33:19 openelec user.debug kernel: [ 0.462612] pnp 00:09: [io 0x0060]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.462618] pnp 00:09: [io 0x0064]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.462623] pnp 00:09: [mem 0xfec00000-0xfec00fff]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.462628] pnp 00:09: [mem 0xfee00000-0xfee00fff]
Aug 17 08:33:19 openelec user.info kernel: [ 0.462718] system 00:09: [mem 0xfec00000-0xfec00fff] could not be reserved
Aug 17 08:33:19 openelec user.info kernel: [ 0.462725] system 00:09: [mem 0xfee00000-0xfee00fff] has been reserved
Aug 17 08:33:19 openelec user.debug kernel: [ 0.462733] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
Aug 17 08:33:19 openelec user.debug kernel: [ 0.463536] pnp 00:0a: Plug and Play ACPI device, IDs ITE8713 (disabled)
Aug 17 08:33:19 openelec user.debug kernel: [ 0.463712] pnp 00:0b: [mem 0xe0000000-0xefffffff]
Aug 17 08:33:19 openelec user.info kernel: [ 0.463809] system 00:0b: [mem 0xe0000000-0xefffffff] has been reserved
Aug 17 08:33:19 openelec user.debug kernel: [ 0.463818] system 00:0b: Plug and Play ACPI device, IDs PNP0c02 (active)
Aug 17 08:33:19 openelec user.debug kernel: [ 0.464210] pnp 00:0c: [mem 0x00000000-0x0009ffff]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.464217] pnp 00:0c: [mem 0x000c0000-0x000cffff]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.464222] pnp 00:0c: [mem 0x000e0000-0x000fffff]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.464227] pnp 00:0c: [mem 0x00100000-0x7fffffff]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.464232] pnp 00:0c: [mem 0xfed90000-0xffffffff]
Aug 17 08:33:19 openelec user.info kernel: [ 0.464341] system 00:0c: [mem 0x00000000-0x0009ffff] could not be reserved
Aug 17 08:33:19 openelec user.info kernel: [ 0.464348] system 00:0c: [mem 0x000c0000-0x000cffff] could not be reserved
Aug 17 08:33:19 openelec user.info kernel: [ 0.464355] system 00:0c: [mem 0x000e0000-0x000fffff] could not be reserved
Aug 17 08:33:19 openelec user.info kernel: [ 0.464362] system 00:0c: [mem 0x00100000-0x7fffffff] could not be reserved
Aug 17 08:33:19 openelec user.info kernel: [ 0.464369] system 00:0c: [mem 0xfed90000-0xffffffff] could not be reserved
Aug 17 08:33:19 openelec user.debug kernel: [ 0.464377] system 00:0c: Plug and Play ACPI device, IDs PNP0c01 (active)
Aug 17 08:33:19 openelec user.info kernel: [ 0.464694] pnp: PnP ACPI: found 13 devices
Aug 17 08:33:19 openelec user.info kernel: [ 0.464699] ACPI: ACPI bus type pnp unregistered
Aug 17 08:33:19 openelec user.debug kernel: [ 0.474437] PCI: max bus depth: 1 pci_try_num: 2
Aug 17 08:33:19 openelec user.info kernel: [ 0.474495] pci 0000:00:1c.2: BAR 9: assigned [mem 0x80000000-0x801fffff 64bit pref]
Aug 17 08:33:19 openelec user.info kernel: [ 0.474505] pci 0000:00:1c.2: BAR 7: assigned [io 0x1000-0x1fff]
Aug 17 08:33:19 openelec user.info kernel: [ 0.474513] pci 0000:00:1c.1: BAR 8: assigned [mem 0x80200000-0x805fffff]
Aug 17 08:33:19 openelec user.info kernel: [ 0.474522] pci 0000:00:1c.0: BAR 9: assigned [mem 0x80600000-0x807fffff 64bit pref]
Aug 17 08:33:19 openelec user.info kernel: [ 0.474530] pci 0000:00:1c.0: BAR 7: assigned [io 0x2000-0x2fff]
Aug 17 08:33:19 openelec user.info kernel: [ 0.474537] pci 0000:00:1c.0: PCI bridge to [bus 05-05]
Aug 17 08:33:19 openelec user.info kernel: [ 0.474543] pci 0000:00:1c.0: bridge window [io 0x2000-0x2fff]
Aug 17 08:33:19 openelec user.info kernel: [ 0.474551] pci 0000:00:1c.0: bridge window [mem 0xfbf00000-0xfbffffff]
Aug 17 08:33:19 openelec user.info kernel: [ 0.474559] pci 0000:00:1c.0: bridge window [mem 0x80600000-0x807fffff 64bit pref]
Aug 17 08:33:19 openelec user.info kernel: [ 0.474568] pci 0000:00:1c.1: PCI bridge to [bus 04-04]
Aug 17 08:33:19 openelec user.info kernel: [ 0.474574] pci 0000:00:1c.1: bridge window [io 0xe000-0xefff]
Aug 17 08:33:19 openelec user.info kernel: [ 0.474582] pci 0000:00:1c.1: bridge window [mem 0x80200000-0x805fffff]
Aug 17 08:33:19 openelec user.info kernel: [ 0.474589] pci 0000:00:1c.1: bridge window [mem 0xf8f00000-0xf8ffffff 64bit pref]
Aug 17 08:33:19 openelec user.info kernel: [ 0.474599] pci 0000:00:1c.2: PCI bridge to [bus 03-03]
Aug 17 08:33:19 openelec user.info kernel: [ 0.474605] pci 0000:00:1c.2: bridge window [io 0x1000-0x1fff]
Aug 17 08:33:19 openelec user.info kernel: [ 0.474612] pci 0000:00:1c.2: bridge window [mem 0xfbe00000-0xfbefffff]
Aug 17 08:33:19 openelec user.info kernel: [ 0.474620] pci 0000:00:1c.2: bridge window [mem 0x80000000-0x801fffff 64bit pref]
Aug 17 08:33:19 openelec user.info kernel: [ 0.474630] pci 0000:00:1c.3: PCI bridge to [bus 02-02]
Aug 17 08:33:19 openelec user.info kernel: [ 0.474636] pci 0000:00:1c.3: bridge window [io 0xd000-0xdfff]
Aug 17 08:33:19 openelec user.info kernel: [ 0.474643] pci 0000:00:1c.3: bridge window [mem 0xfa000000-0xfbdfffff]
Aug 17 08:33:19 openelec user.info kernel: [ 0.474651] pci 0000:00:1c.3: bridge window [mem 0xce000000-0xdfffffff 64bit pref]
Aug 17 08:33:19 openelec user.info kernel: [ 0.474660] pci 0000:00:1e.0: PCI bridge to [bus 01-01]
Aug 17 08:33:19 openelec user.info kernel: [ 0.474680] pci 0000:00:1c.0: enabling device (0106 -> 0107)
Aug 17 08:33:19 openelec user.info kernel: [ 0.474708] pci 0000:00:1c.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
Aug 17 08:33:19 openelec user.debug kernel: [ 0.474717] pci 0000:00:1c.0: setting latency timer to 64
Aug 17 08:33:19 openelec user.info kernel: [ 0.474736] pci 0000:00:1c.1: PCI INT B -> GSI 17 (level, low) -> IRQ 17
Aug 17 08:33:19 openelec user.debug kernel: [ 0.474744] pci 0000:00:1c.1: setting latency timer to 64
Aug 17 08:33:19 openelec user.info kernel: [ 0.474753] pci 0000:00:1c.2: enabling device (0106 -> 0107)
Aug 17 08:33:19 openelec user.info kernel: [ 0.474768] pci 0000:00:1c.2: PCI INT C -> GSI 18 (level, low) -> IRQ 18
Aug 17 08:33:19 openelec user.debug kernel: [ 0.474775] pci 0000:00:1c.2: setting latency timer to 64
Aug 17 08:33:19 openelec user.info kernel: [ 0.474796] pci 0000:00:1c.3: PCI INT D -> GSI 19 (level, low) -> IRQ 19
Aug 17 08:33:19 openelec user.debug kernel: [ 0.474803] pci 0000:00:1c.3: setting latency timer to 64
Aug 17 08:33:19 openelec user.debug kernel: [ 0.474814] pci 0000:00:1e.0: setting latency timer to 64
Aug 17 08:33:19 openelec user.debug kernel: [ 0.474821] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.474826] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.474832] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.474838] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000dffff]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.474843] pci_bus 0000:00: resource 8 [mem 0x80000000-0xdfffffff]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.474849] pci_bus 0000:00: resource 9 [mem 0xf0000000-0xfed8ffff]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.474855] pci_bus 0000:05: resource 0 [io 0x2000-0x2fff]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.474861] pci_bus 0000:05: resource 1 [mem 0xfbf00000-0xfbffffff]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.474867] pci_bus 0000:05: resource 2 [mem 0x80600000-0x807fffff 64bit pref]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.474873] pci_bus 0000:04: resource 0 [io 0xe000-0xefff]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.474878] pci_bus 0000:04: resource 1 [mem 0x80200000-0x805fffff]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.474884] pci_bus 0000:04: resource 2 [mem 0xf8f00000-0xf8ffffff 64bit pref]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.474890] pci_bus 0000:03: resource 0 [io 0x1000-0x1fff]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.474896] pci_bus 0000:03: resource 1 [mem 0xfbe00000-0xfbefffff]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.474902] pci_bus 0000:03: resource 2 [mem 0x80000000-0x801fffff 64bit pref]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.474908] pci_bus 0000:02: resource 0 [io 0xd000-0xdfff]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.474913] pci_bus 0000:02: resource 1 [mem 0xfa000000-0xfbdfffff]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.474919] pci_bus 0000:02: resource 2 [mem 0xce000000-0xdfffffff 64bit pref]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.474926] pci_bus 0000:01: resource 4 [io 0x0000-0x0cf7]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.474931] pci_bus 0000:01: resource 5 [io 0x0d00-0xffff]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.474937] pci_bus 0000:01: resource 6 [mem 0x000a0000-0x000bffff]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.474942] pci_bus 0000:01: resource 7 [mem 0x000d0000-0x000dffff]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.474948] pci_bus 0000:01: resource 8 [mem 0x80000000-0xdfffffff]
Aug 17 08:33:19 openelec user.debug kernel: [ 0.474954] pci_bus 0000:01: resource 9 [mem 0xf0000000-0xfed8ffff]
Aug 17 08:33:19 openelec user.info kernel: [ 0.475107] NET: Registered protocol family 2
Aug 17 08:33:19 openelec user.info kernel: [ 0.475245] IP route cache hash table entries: 65536 (order: 7, 524288 bytes)
Aug 17 08:33:19 openelec user.info kernel: [ 0.475881] TCP established hash table entries: 262144 (order: 10, 4194304 bytes)
Aug 17 08:33:19 openelec user.info kernel: [ 0.478498] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
Aug 17 08:33:19 openelec user.info kernel: [ 0.479135] TCP: Hash tables configured (established 262144 bind 65536)
Aug 17 08:33:19 openelec user.info kernel: [ 0.479141] TCP reno registered
Aug 17 08:33:19 openelec user.info kernel: [ 0.479149] UDP hash table entries: 1024 (order: 3, 32768 bytes)
Aug 17 08:33:19 openelec user.info kernel: [ 0.479179] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
Aug 17 08:33:19 openelec user.info kernel: [ 0.479443] NET: Registered protocol family 1
Aug 17 08:33:19 openelec user.info kernel: [ 0.479722] RPC: Registered named UNIX socket transport module.
Aug 17 08:33:19 openelec user.info kernel: [ 0.479727] RPC: Registered udp transport module.
Aug 17 08:33:19 openelec user.info kernel: [ 0.479731] RPC: Registered tcp transport module.
Aug 17 08:33:19 openelec user.info kernel: [ 0.479735] RPC: Registered tcp NFSv4.1 backchannel transport module.
Aug 17 08:33:19 openelec user.info kernel: [ 0.479800] pci 0000:00:1d.0: PCI INT A -> GSI 23 (level, low) -> IRQ 23
Aug 17 08:33:19 openelec user.info kernel: [ 0.479820] pci 0000:00:1d.0: PCI INT A disabled
Aug 17 08:33:19 openelec user.info kernel: [ 0.479843] pci 0000:00:1d.1: PCI INT B -> GSI 21 (level, low) -> IRQ 21
Aug 17 08:33:19 openelec user.info kernel: [ 0.479862] pci 0000:00:1d.1: PCI INT B disabled
Aug 17 08:33:19 openelec user.info kernel: [ 0.479876] pci 0000:00:1d.2: PCI INT C -> GSI 18 (level, low) -> IRQ 18
Aug 17 08:33:19 openelec user.info kernel: [ 0.479895] pci 0000:00:1d.2: PCI INT C disabled
Aug 17 08:33:19 openelec user.info kernel: [ 0.479916] pci 0000:00:1d.3: PCI INT D -> GSI 22 (level, low) -> IRQ 22
Aug 17 08:33:19 openelec user.info kernel: [ 0.479935] pci 0000:00:1d.3: PCI INT D disabled
Aug 17 08:33:19 openelec user.info kernel: [ 0.479950] pci 0000:00:1d.7: PCI INT A -> GSI 23 (level, low) -> IRQ 23
Aug 17 08:33:19 openelec user.info kernel: [ 0.479986] pci 0000:00:1d.7: PCI INT A disabled
Aug 17 08:33:19 openelec user.info kernel: [ 0.480046] pci 0000:05:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
Aug 17 08:33:19 openelec user.info kernel: [ 0.480078] pci 0000:05:00.0: PCI INT A disabled
Aug 17 08:33:19 openelec user.debug kernel: [ 0.480112] pci 0000:02:00.0: Boot video device
Aug 17 08:33:19 openelec user.debug kernel: [ 0.480133] PCI: CLS 32 bytes, default 64
Aug 17 08:33:19 openelec user.info kernel: [ 0.487568] microcode: CPU0 sig=0x106ca, pf=0x8, revision=0x107
Aug 17 08:33:19 openelec user.info kernel: [ 0.487587] microcode: CPU1 sig=0x106ca, pf=0x8, revision=0x107
Aug 17 08:33:19 openelec user.info kernel: [ 0.487604] microcode: CPU2 sig=0x106ca, pf=0x8, revision=0x107
Aug 17 08:33:19 openelec user.info kernel: [ 0.487623] microcode: CPU3 sig=0x106ca, pf=0x8, revision=0x107
Aug 17 08:33:19 openelec user.info kernel: [ 0.487695] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
Aug 17 08:33:19 openelec user.info kernel: [ 0.489284] squashfs: version 4.0 (2009/01/31) Phillip Lougher
Aug 17 08:33:19 openelec user.info kernel: [ 0.489753] fuse init (API version 7.17)
Aug 17 08:33:19 openelec user.info kernel: [ 0.489924] JFS: nTxBlock = 8192, nTxLock = 65536
Aug 17 08:33:19 openelec user.info kernel: [ 0.494225] SGI XFS with security attributes, large block/inode numbers, no debug enabled
Aug 17 08:33:19 openelec user.info kernel: [ 0.494901] msgmni has been set to 4005
Aug 17 08:33:19 openelec user.info kernel: [ 0.495891] alg: No test for stdrng (krng)
Aug 17 08:33:19 openelec user.info kernel: [ 0.495976] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
Aug 17 08:33:19 openelec user.info kernel: [ 0.495983] io scheduler noop registered
Aug 17 08:33:19 openelec user.info kernel: [ 0.496031] io scheduler cfq registered (default)
Aug 17 08:33:19 openelec user.debug kernel: [ 0.496184] pcieport 0000:00:1c.0: setting latency timer to 64
Aug 17 08:33:19 openelec user.debug kernel: [ 0.496238] pcieport 0000:00:1c.0: irq 40 for MSI/MSI-X
Aug 17 08:33:19 openelec user.debug kernel: [ 0.496333] pcieport 0000:00:1c.1: setting latency timer to 64
Aug 17 08:33:19 openelec user.debug kernel: [ 0.496376] pcieport 0000:00:1c.1: irq 41 for MSI/MSI-X
Aug 17 08:33:19 openelec user.debug kernel: [ 0.496457] pcieport 0000:00:1c.2: setting latency timer to 64
Aug 17 08:33:19 openelec user.debug kernel: [ 0.496499] pcieport 0000:00:1c.2: irq 42 for MSI/MSI-X
Aug 17 08:33:19 openelec user.debug kernel: [ 0.496592] pcieport 0000:00:1c.3: setting latency timer to 64
Aug 17 08:33:19 openelec user.debug kernel: [ 0.496634] pcieport 0000:00:1c.3: irq 43 for MSI/MSI-X
Aug 17 08:33:19 openelec user.debug kernel: [ 0.496877] intel_idle: MWAIT substates: 0x10
Aug 17 08:33:19 openelec user.debug kernel: [ 0.496896] intel_idle: v0.4 model 0x1C
Aug 17 08:33:19 openelec user.debug kernel: [ 0.496900] intel_idle: lapic_timer_reliable_states 0x2
Aug 17 08:33:19 openelec user.info kernel: [ 0.497117] input: Power Button as /devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input0
Aug 17 08:33:19 openelec user.info kernel: [ 0.497127] ACPI: Power Button [PWRB]
Aug 17 08:33:19 openelec user.info kernel: [ 0.497259] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
Aug 17 08:33:19 openelec user.info kernel: [ 0.497267] ACPI: Power Button [PWRF]
Aug 17 08:33:19 openelec user.info kernel: [ 0.500792] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
Aug 17 08:33:19 openelec user.info kernel: [ 0.697021] Linux agpgart interface v0.103
Aug 17 08:33:19 openelec user.info kernel: [ 0.700066] brd: module loaded
Aug 17 08:33:19 openelec user.info kernel: [ 0.701629] loop: module loaded
Aug 17 08:33:19 openelec user.info kernel: [ 0.702171] nbd: registered device at major 43
Aug 17 08:33:19 openelec user.info kernel: [ 0.705057] Loading iSCSI transport class v2.0-870.
Aug 17 08:33:19 openelec user.notice kernel: [ 0.705267] iscsi: registered transport (tcp)
Aug 17 08:33:19 openelec user.debug kernel: [ 0.705429] ahci 0000:00:1f.2: version 3.0
Aug 17 08:33:19 openelec user.info kernel: [ 0.705451] ahci 0000:00:1f.2: PCI INT B -> GSI 19 (level, low) -> IRQ 19
Aug 17 08:33:19 openelec user.debug kernel: [ 0.705525] ahci 0000:00:1f.2: irq 44 for MSI/MSI-X
Aug 17 08:33:19 openelec user.info kernel: [ 0.705604] ahci 0000:00:1f.2: AHCI 0001.0100 32 slots 4 ports 3 Gbps 0x3 impl SATA mode
Aug 17 08:33:19 openelec user.info kernel: [ 0.705613] ahci 0000:00:1f.2: flags: 64bit ncq pm led clo pio slum part
Aug 17 08:33:19 openelec user.debug kernel: [ 0.705620] ahci 0000:00:1f.2: setting latency timer to 64
Aug 17 08:33:19 openelec user.info kernel: [ 0.706658] scsi0 : ahci
Aug 17 08:33:19 openelec user.info kernel: [ 0.706942] scsi1 : ahci
Aug 17 08:33:19 openelec user.info kernel: [ 0.707106] scsi2 : ahci
Aug 17 08:33:19 openelec user.info kernel: [ 0.707272] scsi3 : ahci
Aug 17 08:33:19 openelec user.info kernel: [ 0.707578] ata1: SATA max UDMA/133 abar m1024@0xf9fffc00 port 0xf9fffd00 irq 44
Aug 17 08:33:19 openelec user.info kernel: [ 0.707585] ata2: SATA max UDMA/133 abar m1024@0xf9fffc00 port 0xf9fffd80 irq 44
Aug 17 08:33:19 openelec user.info kernel: [ 0.707591] ata3: DUMMY
Aug 17 08:33:19 openelec user.info kernel: [ 0.707594] ata4: DUMMY
Aug 17 08:33:19 openelec user.info kernel: [ 0.707948] tun: Universal TUN/TAP device driver, 1.6
Aug 17 08:33:19 openelec user.info kernel: [ 0.707953] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
Aug 17 08:33:19 openelec user.info kernel: [ 0.708091] e100: Intel(R) PRO/100 Network Driver, 3.5.24-k2-NAPI
Aug 17 08:33:19 openelec user.info kernel: [ 0.708096] e100: Copyright(c) 1999-2006 Intel Corporation
Aug 17 08:33:19 openelec user.info kernel: [ 0.708138] e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI
Aug 17 08:33:19 openelec user.info kernel: [ 0.708143] e1000: Copyright (c) 1999-2006 Intel Corporation.
Aug 17 08:33:19 openelec user.info kernel: [ 0.708184] e1000e: Intel(R) PRO/1000 Network Driver - 1.5.1-k
Aug 17 08:33:19 openelec user.info kernel: [ 0.708188] e1000e: Copyright(c) 1999 - 2011 Intel Corporation.
Aug 17 08:33:19 openelec user.info kernel: [ 0.708264] jme: JMicron JMC2XX ethernet driver version 1.0.8
Aug 17 08:33:19 openelec user.info kernel: [ 0.708377] r8168 Gigabit Ethernet driver 8.029.00-NAPI loaded
Aug 17 08:33:19 openelec user.info kernel: [ 0.708421] r8168 0000:04:00.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
Aug 17 08:33:19 openelec user.debug kernel: [ 0.708448] r8168 0000:04:00.0: setting latency timer to 64
Aug 17 08:33:19 openelec user.debug kernel: [ 0.708525] r8168 0000:04:00.0: irq 45 for MSI/MSI-X
Aug 17 08:33:19 openelec user.info kernel: [ 0.708758] eth%d: RTL8168E/8111E at 0xffffc9000001e000, c8:60:00:42:a5:57, IRQ 45
Aug 17 08:33:19 openelec user.info kernel: [ 0.852818] r8168: This product is covered by one or more of the following patents: US5,307,459, US5,434,872, US5,732,094, US6,570,884, US6,115,776, and US6,327,625.
Aug 17 08:33:19 openelec user.debug kernel: [ 0.852825] eth0: Identified chip type is 'RTL8168E/8111E'.
Aug 17 08:33:19 openelec user.warn kernel: [ 0.852831] r8168 Copyright (C) 2012 Realtek NIC software team <nicfae@realtek.com>
Aug 17 08:33:19 openelec user.warn kernel: [ 0.852834] This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
Aug 17 08:33:19 openelec user.warn kernel: [ 0.852837] This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
Aug 17 08:33:19 openelec user.info kernel: [ 0.852901] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Aug 17 08:33:19 openelec user.info kernel: [ 0.852940] ehci_hcd 0000:00:1d.7: PCI INT A -> GSI 23 (level, low) -> IRQ 23
Aug 17 08:33:19 openelec user.debug kernel: [ 0.852965] ehci_hcd 0000:00:1d.7: setting latency timer to 64
Aug 17 08:33:19 openelec user.info kernel: [ 0.852971] ehci_hcd 0000:00:1d.7: EHCI Host Controller
Aug 17 08:33:19 openelec user.info kernel: [ 0.852985] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 1
Aug 17 08:33:19 openelec user.info kernel: [ 0.853027] ehci_hcd 0000:00:1d.7: using broken periodic workaround
Aug 17 08:33:19 openelec user.info kernel: [ 0.853041] ehci_hcd 0000:00:1d.7: debug port 1
Aug 17 08:33:19 openelec user.debug kernel: [ 0.856925] ehci_hcd 0000:00:1d.7: cache line size of 32 is not supported
Aug 17 08:33:19 openelec user.info kernel: [ 0.857053] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xf9fff800
Aug 17 08:33:19 openelec user.info kernel: [ 0.870033] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
Aug 17 08:33:19 openelec user.info kernel: [ 0.870323] hub 1-0:1.0: USB hub found
Aug 17 08:33:19 openelec user.info kernel: [ 0.870334] hub 1-0:1.0: 8 ports detected
Aug 17 08:33:19 openelec user.info kernel: [ 0.870505] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Aug 17 08:33:19 openelec user.info kernel: [ 0.870539] uhci_hcd: USB Universal Host Controller Interface driver
Aug 17 08:33:19 openelec user.info kernel: [ 0.870613] uhci_hcd 0000:00:1d.0: PCI INT A -> GSI 23 (level, low) -> IRQ 23
Aug 17 08:33:19 openelec user.debug kernel: [ 0.870627] uhci_hcd 0000:00:1d.0: setting latency timer to 64
Aug 17 08:33:19 openelec user.info kernel: [ 0.870633] uhci_hcd 0000:00:1d.0: UHCI Host Controller
Aug 17 08:33:19 openelec user.info kernel: [ 0.870646] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
Aug 17 08:33:19 openelec user.info kernel: [ 0.870754] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000b880
Aug 17 08:33:19 openelec user.info kernel: [ 0.871050] hub 2-0:1.0: USB hub found
Aug 17 08:33:19 openelec user.info kernel: [ 0.871060] hub 2-0:1.0: 2 ports detected
Aug 17 08:33:19 openelec user.info kernel: [ 0.871188] uhci_hcd 0000:00:1d.1: PCI INT B -> GSI 21 (level, low) -> IRQ 21
Aug 17 08:33:19 openelec user.debug kernel: [ 0.871205] uhci_hcd 0000:00:1d.1: setting latency timer to 64
Aug 17 08:33:19 openelec user.info kernel: [ 0.871211] uhci_hcd 0000:00:1d.1: UHCI Host Controller
Aug 17 08:33:19 openelec user.info kernel: [ 0.871226] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
Aug 17 08:33:19 openelec user.info kernel: [ 0.871347] uhci_hcd 0000:00:1d.1: irq 21, io base 0x0000bc00
Aug 17 08:33:19 openelec user.info kernel: [ 0.871635] hub 3-0:1.0: USB hub found
Aug 17 08:33:19 openelec user.info kernel: [ 0.871645] hub 3-0:1.0: 2 ports detected
Aug 17 08:33:19 openelec user.info kernel: [ 0.871770] uhci_hcd 0000:00:1d.2: PCI INT C -> GSI 18 (level, low) -> IRQ 18
Aug 17 08:33:19 openelec user.debug kernel: [ 0.871782] uhci_hcd 0000:00:1d.2: setting latency timer to 64
Aug 17 08:33:19 openelec user.info kernel: [ 0.871788] uhci_hcd 0000:00:1d.2: UHCI Host Controller
Aug 17 08:33:19 openelec user.info kernel: [ 0.871801] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
Aug 17 08:33:19 openelec user.info kernel: [ 0.871914] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000c000
Aug 17 08:33:19 openelec user.info kernel: [ 0.872205] hub 4-0:1.0: USB hub found
Aug 17 08:33:19 openelec user.info kernel: [ 0.872215] hub 4-0:1.0: 2 ports detected
Aug 17 08:33:19 openelec user.info kernel: [ 0.872338] uhci_hcd 0000:00:1d.3: PCI INT D -> GSI 22 (level, low) -> IRQ 22
Aug 17 08:33:19 openelec user.debug kernel: [ 0.872351] uhci_hcd 0000:00:1d.3: setting latency timer to 64
Aug 17 08:33:19 openelec user.info kernel: [ 0.872356] uhci_hcd 0000:00:1d.3: UHCI Host Controller
Aug 17 08:33:19 openelec user.info kernel: [ 0.872369] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
Aug 17 08:33:19 openelec user.info kernel: [ 0.872482] uhci_hcd 0000:00:1d.3: irq 22, io base 0x0000c080
Aug 17 08:33:19 openelec user.info kernel: [ 0.872767] hub 5-0:1.0: USB hub found
Aug 17 08:33:19 openelec user.info kernel: [ 0.872777] hub 5-0:1.0: 2 ports detected
Aug 17 08:33:19 openelec user.info kernel: [ 0.872916] Initializing USB Mass Storage driver...
Aug 17 08:33:19 openelec user.info kernel: [ 0.872981] usbcore: registered new interface driver usb-storage
Aug 17 08:33:19 openelec user.info kernel: [ 0.872985] USB Mass Storage support registered.
Aug 17 08:33:19 openelec user.info kernel: [ 0.873093] i8042: PNP: No PS/2 controller found. Probing ports directly.
Aug 17 08:33:19 openelec user.info kernel: [ 0.873745] serio: i8042 KBD port at 0x60,0x64 irq 1
Aug 17 08:33:19 openelec user.info kernel: [ 0.873765] serio: i8042 AUX port at 0x60,0x64 irq 12
Aug 17 08:33:19 openelec user.info kernel: [ 0.873990] mousedev: PS/2 mouse device common for all mice
Aug 17 08:33:19 openelec user.info kernel: [ 0.874441] rtc_cmos 00:03: RTC can wake from S4
Aug 17 08:33:19 openelec user.info kernel: [ 0.874626] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0
Aug 17 08:33:19 openelec user.info kernel: [ 0.874718] rtc0: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
Aug 17 08:33:19 openelec user.info kernel: [ 0.874750] i2c /dev entries driver
Aug 17 08:33:19 openelec user.info kernel: [ 0.874825] i801_smbus 0000:00:1f.3: PCI INT B -> GSI 19 (level, low) -> IRQ 19
Aug 17 08:33:19 openelec user.warn kernel: [ 0.874834] ACPI: resource 0000:00:1f.3 [io 0x0400-0x041f] conflicts with ACPI region SMRG [io 0x400-0x40f]
Aug 17 08:33:19 openelec user.info kernel: [ 0.874839] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
Aug 17 08:33:19 openelec user.info kernel: [ 0.875017] lirc_dev: IR Remote Control driver registered, major 252
Aug 17 08:33:19 openelec user.info kernel: [ 0.875022] IR NEC protocol handler initialized
Aug 17 08:33:19 openelec user.info kernel: [ 0.875025] IR RC5(x) protocol handler initialized
Aug 17 08:33:19 openelec user.info kernel: [ 0.875029] IR RC6 protocol handler initialized
Aug 17 08:33:19 openelec user.info kernel: [ 0.875032] IR JVC protocol handler initialized
Aug 17 08:33:19 openelec user.info kernel: [ 0.875035] IR Sony protocol handler initialized
Aug 17 08:33:19 openelec user.info kernel: [ 0.875039] IR RC5 (streamzap) protocol handler initialized
Aug 17 08:33:19 openelec user.info kernel: [ 0.875042] IR MCE Keyboard/mouse protocol handler initialized
Aug 17 08:33:19 openelec user.info kernel: [ 0.875238] cpuidle: using governor ladder
Aug 17 08:33:19 openelec user.info kernel: [ 0.875514] cpuidle: using governor menu
Aug 17 08:33:19 openelec user.info kernel: [ 0.875519] EFI Variables Facility v0.08 2004-May-17
Aug 17 08:33:19 openelec user.info kernel: [ 0.875524] No iBFT detected.
Aug 17 08:33:19 openelec user.info kernel: [ 0.876196] usbcore: registered new interface driver usbhid
Aug 17 08:33:19 openelec user.info kernel: [ 0.876200] usbhid: USB HID core driver
Aug 17 08:33:19 openelec user.info kernel: [ 0.876322] Netfilter messages via NETLINK v0.30.
Aug 17 08:33:19 openelec user.info kernel: [ 0.876758] ip_tables: (C) 2000-2006 Netfilter Core Team
Aug 17 08:33:19 openelec user.info kernel: [ 0.876800] TCP cubic registered
Aug 17 08:33:19 openelec user.info kernel: [ 0.876950] NET: Registered protocol family 10
Aug 17 08:33:19 openelec user.info kernel: [ 0.878103] ip6_tables: (C) 2000-2006 Netfilter Core Team
Aug 17 08:33:19 openelec user.info kernel: [ 0.878135] NET: Registered protocol family 17
Aug 17 08:33:19 openelec user.info kernel: [ 0.878163] lib80211: common routines for IEEE802.11 drivers
Aug 17 08:33:19 openelec user.debug kernel: [ 0.878168] lib80211_crypt: registered algorithm 'NULL'
Aug 17 08:33:19 openelec user.notice kernel: [ 0.878172] Registering the dns_resolver key type
Aug 17 08:33:19 openelec user.info kernel: [ 0.879172] rtc_cmos 00:03: setting system clock to 2012-08-17 08:33:17 UTC (1345192397)
Aug 17 08:33:19 openelec user.info kernel: [ 1.026710] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Aug 17 08:33:19 openelec user.info kernel: [ 1.026739] ata2: SATA link down (SStatus 0 SControl 300)
Aug 17 08:33:19 openelec user.info kernel: [ 1.072866] ata1.00: ATA-8: TOSHIBA MK3259GSXP, GN003J, max UDMA/100
Aug 17 08:33:19 openelec user.info kernel: [ 1.072873] ata1.00: 625142448 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
Aug 17 08:33:19 openelec user.info kernel: [ 1.073738] ata1.00: configured for UDMA/100
Aug 17 08:33:19 openelec user.notice kernel: [ 1.073991] scsi 0:0:0:0: Direct-Access ATA TOSHIBA MK3259GS GN00 PQ: 0 ANSI: 5
Aug 17 08:33:19 openelec user.notice kernel: [ 1.074409] sd 0:0:0:0: Attached scsi generic sg0 type 0
Aug 17 08:33:19 openelec user.notice kernel: [ 1.074448] sd 0:0:0:0: [sda] 625142448 512-byte logical blocks: (320 GB/298 GiB)
Aug 17 08:33:19 openelec user.notice kernel: [ 1.074455] sd 0:0:0:0: [sda] 4096-byte physical blocks
Aug 17 08:33:19 openelec user.notice kernel: [ 1.074647] sd 0:0:0:0: [sda] Write Protect is off
Aug 17 08:33:19 openelec user.debug kernel: [ 1.074654] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
Aug 17 08:33:19 openelec user.notice kernel: [ 1.074730] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Aug 17 08:33:19 openelec user.info kernel: [ 1.122760] sda: sda1 sda2
Aug 17 08:33:19 openelec user.notice kernel: [ 1.123461] sd 0:0:0:0: [sda] Attached SCSI disk
Aug 17 08:33:19 openelec user.info kernel: [ 1.133191] Freeing unused kernel memory: 4364k freed
Aug 17 08:33:19 openelec user.info kernel: [ 1.136050] Write protecting the kernel read-only data: 8192k
Aug 17 08:33:19 openelec user.info kernel: [ 1.147731] Freeing unused kernel memory: 1432k freed
Aug 17 08:33:19 openelec user.info kernel: [ 1.151815] Freeing unused kernel memory: 384k freed
Aug 17 08:33:19 openelec user.info kernel: [ 1.230051] usb 1-4: new high-speed USB device number 3 using ehci_hcd
Aug 17 08:33:19 openelec user.info kernel: [ 1.256567] uvesafb: NVIDIA Corporation, GT218 Board - 06930002, Chip Rev , OEM: NVIDIA, VBE v3.0
Aug 17 08:33:19 openelec user.info kernel: [ 1.347804] uvesafb: VBIOS/hardware doesn't support DDC transfers
Aug 17 08:33:19 openelec user.info kernel: [ 1.347812] uvesafb: no monitor limits have been set, default refresh rate will be used
Aug 17 08:33:19 openelec user.info kernel: [ 1.348516] uvesafb: scrolling: redraw
Aug 17 08:33:19 openelec user.info kernel: [ 1.466708] usb 1-6: new high-speed USB device number 4 using ehci_hcd
Aug 17 08:33:19 openelec user.info kernel: [ 1.486725] Refined TSC clocksource calibration: 1795.563 MHz.
Aug 17 08:33:19 openelec user.info kernel: [ 1.486735] Switching to clocksource tsc
Aug 17 08:33:19 openelec user.info kernel: [ 1.501461] Console: switching to colour frame buffer device 80x30
Aug 17 08:33:19 openelec user.info kernel: [ 1.504765] uvesafb: framebuffer at 0xcf000000, mapped to 0xffffc90010680000, using 10240k, total 14336k
Aug 17 08:33:19 openelec user.info kernel: [ 1.504771] fb0: VESA VGA frame buffer device
Aug 17 08:33:19 openelec user.info kernel: [ 1.507387] xhci_hcd 0000:05:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
Aug 17 08:33:19 openelec user.debug kernel: [ 1.507421] xhci_hcd 0000:05:00.0: setting latency timer to 64
Aug 17 08:33:19 openelec user.info kernel: [ 1.507428] xhci_hcd 0000:05:00.0: xHCI Host Controller
Aug 17 08:33:19 openelec user.info kernel: [ 1.507443] xhci_hcd 0000:05:00.0: new USB bus registered, assigned bus number 6
Aug 17 08:33:19 openelec user.info kernel: [ 1.507734] xhci_hcd 0000:05:00.0: irq 16, io mem 0xfbffe000
Aug 17 08:33:19 openelec user.debug kernel: [ 1.507847] xhci_hcd 0000:05:00.0: irq 46 for MSI/MSI-X
Aug 17 08:33:19 openelec user.debug kernel: [ 1.507861] xhci_hcd 0000:05:00.0: irq 47 for MSI/MSI-X
Aug 17 08:33:19 openelec user.debug kernel: [ 1.507874] xhci_hcd 0000:05:00.0: irq 48 for MSI/MSI-X
Aug 17 08:33:19 openelec user.debug kernel: [ 1.507887] xhci_hcd 0000:05:00.0: irq 49 for MSI/MSI-X
Aug 17 08:33:19 openelec user.debug kernel: [ 1.507900] xhci_hcd 0000:05:00.0: irq 50 for MSI/MSI-X
Aug 17 08:33:19 openelec user.debug kernel: [ 1.508515] xHCI xhci_add_endpoint called for root hub
Aug 17 08:33:19 openelec user.debug kernel: [ 1.508521] xHCI xhci_check_bandwidth called for root hub
Aug 17 08:33:19 openelec user.info kernel: [ 1.508590] hub 6-0:1.0: USB hub found
Aug 17 08:33:19 openelec user.info kernel: [ 1.508604] hub 6-0:1.0: 2 ports detected
Aug 17 08:33:19 openelec user.info kernel: [ 1.508725] xhci_hcd 0000:05:00.0: xHCI Host Controller
Aug 17 08:33:19 openelec user.info kernel: [ 1.508736] xhci_hcd 0000:05:00.0: new USB bus registered, assigned bus number 7
Aug 17 08:33:19 openelec user.debug kernel: [ 1.511237] xHCI xhci_add_endpoint called for root hub
Aug 17 08:33:19 openelec user.debug kernel: [ 1.511242] xHCI xhci_check_bandwidth called for root hub
Aug 17 08:33:19 openelec user.info kernel: [ 1.511307] hub 7-0:1.0: USB hub found
Aug 17 08:33:19 openelec user.info kernel: [ 1.511320] hub 7-0:1.0: 2 ports detected
Aug 17 08:33:19 openelec user.info kernel: [ 1.595548] scsi4 : usb-storage 1-6:1.0
Aug 17 08:33:19 openelec user.info kernel: [ 1.700033] usb 1-8: new high-speed USB device number 5 using ehci_hcd
Aug 17 08:33:19 openelec user.err kernel: [ 1.706942] EXT4-fs (sda1): couldn't mount as ext3 due to feature incompatibilities
Aug 17 08:33:19 openelec user.err kernel: [ 1.726908] EXT4-fs (sda1): couldn't mount as ext2 due to feature incompatibilities
Aug 17 08:33:19 openelec user.info kernel: [ 1.789323] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
Aug 17 08:33:19 openelec user.info kernel: [ 1.826184] scsi5 : usb-storage 1-8:1.0
Aug 17 08:33:19 openelec user.info kernel: [ 2.050032] usb 2-1: new low-speed USB device number 2 using uhci_hcd
Aug 17 08:33:19 openelec user.err kernel: [ 2.190276] EXT4-fs (sda2): couldn't mount as ext3 due to feature incompatibilities
Aug 17 08:33:19 openelec user.err kernel: [ 2.213626] EXT4-fs (sda2): couldn't mount as ext2 due to feature incompatibilities
Aug 17 08:33:19 openelec user.info kernel: [ 2.344248] input: USB Keyboard as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1:1.0/input/input2
Aug 17 08:33:19 openelec user.info kernel: [ 2.344468] generic-usb 0003:04D9:1503.0001: input,hidraw0: USB HID v1.10 Keyboard [ USB Keyboard] on usb-0000:00:1d.0-1/input0
Aug 17 08:33:19 openelec user.info kernel: [ 2.433944] input: USB Keyboard as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1:1.1/input/input3
Aug 17 08:33:19 openelec user.info kernel: [ 2.434158] generic-usb 0003:04D9:1503.0002: input,hidraw1: USB HID v1.10 Device [ USB Keyboard] on usb-0000:00:1d.0-1/input1
Aug 17 08:33:19 openelec user.notice kernel: [ 2.598242] scsi 4:0:0:0: Direct-Access Generic STORAGE DEVICE 0206 PQ: 0 ANSI: 0
Aug 17 08:33:19 openelec user.notice kernel: [ 2.599590] sd 4:0:0:0: Attached scsi generic sg1 type 0
Aug 17 08:33:19 openelec user.notice kernel: [ 2.600967] sd 4:0:0:0: [sdb] Attached SCSI removable disk
Aug 17 08:33:19 openelec user.info kernel: [ 2.670179] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
Aug 17 08:33:19 openelec user.notice kernel: [ 2.828228] scsi 5:0:0:0: CD-ROM Optiarc DVD RW AD-7690H 1.00 PQ: 0 ANSI: 0
Aug 17 08:33:19 openelec user.warn kernel: [ 2.833204] sr0: scsi3-mmc drive: 10x/24x writer dvd-ram cd/rw xa/form2 cdda caddy
Aug 17 08:33:19 openelec user.info kernel: [ 2.833210] cdrom: Uniform CD-ROM driver Revision: 3.20
Aug 17 08:33:19 openelec user.debug kernel: [ 2.833487] sr 5:0:0:0: Attached scsi CD-ROM sr0
Aug 17 08:33:19 openelec user.notice kernel: [ 2.833902] sr 5:0:0:0: Attached scsi generic sg2 type 5
Aug 17 08:33:20 openelec user.err kernel: 0>[ 3.411743] systemd-udevd[234]: starting version 187
Aug 17 08:33:20 openelec user.notice Boot: ### monitoring udev events ###
Aug 17 08:33:20 openelec user.notice Boot: ### request udev events from the kernel (type: subsystems) ###
Aug 17 08:33:20 openelec user.notice Boot: ### request udev events from the kernel (type: devices) ###
Aug 17 08:33:20 openelec user.notice Boot: ### watching udev event queue from the kernel ###
Aug 17 08:33:20 openelec user.notice Boot: ### Starting D-BUS ###
Aug 17 08:33:20 openelec user.notice Boot: ### Starting Fuse ###
Aug 17 08:33:20 openelec user.notice Boot: ### loading kernel modules ###
Aug 17 08:33:20 openelec user.notice Boot: ### starting Connection manager ###
Aug 17 08:33:20 openelec user.notice Boot: ### creating system settings ###
Aug 17 08:33:20 openelec user.notice Boot: ### start rpcbind daemon ###
Aug 17 08:33:20 openelec user.notice Boot: ### Setup hostname ###
Aug 17 08:33:20 openelec user.debug kernel: [ 3.600881] ite-cir 00:0a: [io 0x02f8-0x02ff]
Aug 17 08:33:20 openelec user.debug kernel: [ 3.603131] ite-cir 00:0a: [irq 5]
Aug 17 08:33:20 openelec user.info kernel: [ 3.606624] ite-cir 00:0a: activated
Aug 17 08:33:20 openelec user.notice kernel: [ 3.606646] ite_cir: Auto-detected model: ITE8713 CIR transceiver
Aug 17 08:33:20 openelec user.notice kernel: [ 3.606652] ite_cir: Using model: ITE8713 CIR transceiver
Aug 17 08:33:20 openelec user.notice kernel: [ 3.606659] ite_cir: TX-capable: 1
Aug 17 08:33:20 openelec user.notice kernel: [ 3.606663] ite_cir: Sample period (ns): 8680
Aug 17 08:33:20 openelec user.notice kernel: [ 3.606709] ite_cir: TX carrier frequency (Hz): 38000
Aug 17 08:33:20 openelec user.notice kernel: [ 3.606715] ite_cir: TX duty cycle (%): 33
Aug 17 08:33:20 openelec user.notice kernel: [ 3.606719] ite_cir: RX low carrier frequency (Hz): 0
Aug 17 08:33:20 openelec user.notice kernel: [ 3.606725] ite_cir: RX high carrier frequency (Hz): 0
Aug 17 08:33:20 openelec user.info kernel: [ 3.606913] Registered IR keymap rc-rc6-mce
Aug 17 08:33:20 openelec user.notice Boot: ### creating /etc/hosts ###
Aug 17 08:33:20 openelec user.info kernel: [ 3.607238] input: ITE8713 CIR transceiver as /devices/virtual/rc/rc0/input4
Aug 17 08:33:20 openelec user.info kernel: [ 3.607439] rc0: ITE8713 CIR transceiver as /devices/virtual/rc/rc0
Aug 17 08:33:20 openelec user.info kernel: [ 3.610481] input: MCE IR Keyboard/Mouse (ite-cir) as /devices/virtual/input/input5
Aug 17 08:33:20 openelec user.notice kernel: [ 3.611522] ite_cir: driver has been successfully loaded
Aug 17 08:33:20 openelec user.warn kernel: [ 3.659434] coretemp coretemp.0: Using relative temperature scale!
Aug 17 08:33:20 openelec user.warn kernel: [ 3.659473] coretemp coretemp.0: Using relative temperature scale!
Aug 17 08:33:20 openelec user.notice Boot: ### Setup networking 1 LAN ###
Aug 17 08:33:20 openelec user.notice Connman: ### [1] found /sys/class/net/eth0/address, continue ###
Aug 17 08:33:19 openelec user.notice Boot: ### automount internal disks ###
Aug 17 08:33:19 openelec user.notice Boot: ### starting ConsoleKit daemon ###
Aug 17 08:33:19 openelec user.info kernel: [ 4.181037] ath9k 0000:03:00.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
Aug 17 08:33:19 openelec user.debug kernel: [ 4.181058] ath9k 0000:03:00.0: setting latency timer to 64
Aug 17 08:33:19 openelec user.debug kernel: [ 4.230929] ath: EEPROM regdomain: 0x60
Aug 17 08:33:19 openelec user.debug kernel: [ 4.230937] ath: EEPROM indicates we should expect a direct regpair map
Aug 17 08:33:19 openelec user.debug kernel: [ 4.230949] ath: Country alpha2 being used: 00
Aug 17 08:33:19 openelec user.debug kernel: [ 4.230953] ath: Regpair used: 0x60
Aug 17 08:33:19 openelec user.info kernel: [ 4.235320] snd_hda_intel 0000:00:1b.0: PCI INT A -> GSI 20 (level, low) -> IRQ 20
Aug 17 08:33:19 openelec user.debug kernel: [ 4.235416] snd_hda_intel 0000:00:1b.0: irq 51 for MSI/MSI-X
Aug 17 08:33:19 openelec user.debug kernel: [ 4.236021] ieee80211 phy0: Selected rate control algorithm 'ath9k_rate_control'
Aug 17 08:33:19 openelec user.debug kernel: [ 4.236583] snd_hda_intel 0000:00:1b.0: setting latency timer to 64
Aug 17 08:33:19 openelec user.debug kernel: [ 4.238156] Registered led device: ath9k-phy0
Aug 17 08:33:19 openelec user.info kernel: [ 4.238178] ieee80211 phy0: Atheros AR9285 Rev:2 mem=0xffffc900121c0000, irq=18
Aug 17 08:33:19 openelec user.info kernel: [ 4.326326] input: HDA Intel Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input6
Aug 17 08:33:19 openelec user.info kernel: [ 4.332502] snd_hda_intel 0000:02:00.1: PCI INT B -> GSI 16 (level, low) -> IRQ 16
Aug 17 08:33:19 openelec user.info kernel: [ 4.332512] hda_intel: Disabling MSI
Aug 17 08:33:19 openelec user.debug kernel: [ 4.333747] snd_hda_intel 0000:02:00.1: setting latency timer to 64
Aug 17 08:33:19 openelec daemon.info connmand[373]: Connection Manager version 1.4
Aug 17 08:33:19 openelec daemon.notice dbus[466]: [system] Activating service name='org.freedesktop.UDisks' (using servicehelper)
Aug 17 08:33:19 openelec user.notice Boot: ### SSH: generating SSH1 RSA key ###
Aug 17 08:33:19 openelec user.notice Boot: ### Setting up sound card ###
Aug 17 08:33:19 openelec user.notice Boot: ### Starting Avahi Daemon ###
Aug 17 08:33:19 openelec user.notice Boot: ### starting eventlircd ###
Aug 17 08:33:19 openelec daemon.notice dbus[466]: [system] Activating service name='org.freedesktop.PolicyKit1' (using servicehelper)
Aug 17 08:33:19 openelec daemon.info connmand[373]: Checking loopback interface settings
Aug 17 08:33:19 openelec daemon.info connmand[373]: System hostname is openelec
Aug 17 08:33:19 openelec daemon.info connmand[373]: lo {newlink} index 1 operstate 0 <UNKNOWN>
Aug 17 08:33:19 openelec daemon.notice dbus[466]: [system] Activating service name='fi.w1.wpa_supplicant1' (using servicehelper)
Aug 17 08:33:19 openelec daemon.info connmand[373]: eth0 {create} index 2 type 1 <ETHER>
Aug 17 08:33:19 openelec daemon.info connmand[373]: eth0 {update} flags 4098 <DOWN>
Aug 17 08:33:19 openelec daemon.info connmand[373]: eth0 {newlink} index 2 address C8:60:00:42:A5:57 mtu 1500
Aug 17 08:33:19 openelec daemon.info connmand[373]: eth0 {newlink} index 2 operstate 2 <DOWN>
Aug 17 08:33:19 openelec daemon.info connmand[373]: Adding interface eth0 [ ethernet ]
Aug 17 08:33:19 openelec user.notice Boot: ### starting Windowmanager ###
Aug 17 08:33:19 openelec user.notice Boot: ### clean up log files ###
Aug 17 08:33:19 openelec daemon.info connmand[373]: wlan0 {create} index 3 type 1 <ETHER>
Aug 17 08:33:19 openelec daemon.info connmand[373]: wlan0 {update} flags 4098 <DOWN>
Aug 17 08:33:19 openelec daemon.info connmand[373]: wlan0 {newlink} index 3 address 94:DB:C9:38:63:06 mtu 1500
Aug 17 08:33:19 openelec daemon.info connmand[373]: wlan0 {newlink} index 3 operstate 2 <DOWN>
Aug 17 08:33:19 openelec daemon.info connmand[373]: Adding interface wlan0 [ wifi ]
Aug 17 08:33:19 openelec daemon.info connmand[373]: eth0 {update} flags 4163 <UP,RUNNING>
Aug 17 08:33:19 openelec daemon.info connmand[373]: eth0 {newlink} index 2 operstate 0 <UNKNOWN>
Aug 17 08:33:19 openelec user.info kernel: [ 4.567971] r8168: eth0: link down
Aug 17 08:33:19 openelec user.info kernel: [ 4.568772] ADDRCONF(NETDEV_UP): eth0: link is not ready
Aug 17 08:33:19 openelec daemon.info connmand[373]: eth0 {update} flags 4099 <UP>
Aug 17 08:33:19 openelec user.notice Boot: ### setup XBMC ###
Aug 17 08:33:19 openelec daemon.info avahi-daemon[688]: Found user 'avahi' (UID 495) and group 'avahi' (GID 495).
Aug 17 08:33:19 openelec daemon.info avahi-daemon[688]: Successfully dropped root privileges.
Aug 17 08:33:19 openelec daemon.info avahi-daemon[688]: avahi-daemon 0.6.31 starting up.
Aug 17 08:33:19 openelec daemon.warn avahi-daemon[688]: WARNING: No NSS support for mDNS detected, consider installing nss-mdns!
Aug 17 08:33:19 openelec daemon.info avahi-daemon[688]: Loading service file /etc/avahi/services/http.service.
Aug 17 08:33:19 openelec daemon.info avahi-daemon[688]: Loading service file /etc/avahi/services/sftp-ssh.service.
Aug 17 08:33:19 openelec daemon.info avahi-daemon[688]: Loading service file /etc/avahi/services/ssh.service.
Aug 17 08:33:19 openelec daemon.info avahi-daemon[688]: Network interface enumeration completed.
Aug 17 08:33:19 openelec daemon.info avahi-daemon[688]: Registering HINFO record with values 'X86_64'/'LINUX'.
Aug 17 08:33:19 openelec daemon.info avahi-daemon[688]: Server startup complete. Host name is openelec.local. Local service cookie is 3533856410.
Aug 17 08:33:19 openelec daemon.info avahi-daemon[688]: Service "openelec" (/etc/avahi/services/ssh.service) successfully established.
Aug 17 08:33:19 openelec daemon.info avahi-daemon[688]: Service "openelec" (/etc/avahi/services/sftp-ssh.service) successfully established.
Aug 17 08:33:19 openelec daemon.info avahi-daemon[688]: Service "Web Server on openelec" (/etc/avahi/services/http.service) successfully established.
Aug 17 08:33:19 openelec daemon.info polkitd[671]: started daemon version 0.104 using authority implementation `local' version `0.104'
Aug 17 08:33:19 openelec daemon.notice dbus[466]: [system] Successfully activated service 'org.freedesktop.PolicyKit1'
Aug 17 08:33:20 openelec daemon.notice dbus[466]: [system] Successfully activated service 'org.freedesktop.UDisks'
Aug 17 08:33:20 openelec user.notice Boot: ### starting XBMC ###
Aug 17 08:33:20 openelec daemon.notice dbus[466]: [system] Successfully activated service 'fi.w1.wpa_supplicant1'
Aug 17 08:33:20 openelec user.info kernel: [ 5.000081] HDMI status: Codec=0 Pin=5 Presence_Detect=0 ELD_Valid=0
Aug 17 08:33:20 openelec user.info kernel: [ 5.026734] HDMI status: Codec=1 Pin=5 Presence_Detect=0 ELD_Valid=0
Aug 17 08:33:20 openelec user.info kernel: [ 5.053410] HDMI status: Codec=2 Pin=5 Presence_Detect=0 ELD_Valid=0
Aug 17 08:33:20 openelec daemon.info connmand[373]: wlan0 {update} flags 4163 <UP,RUNNING>
Aug 17 08:33:20 openelec daemon.info connmand[373]: wlan0 {newlink} index 3 address 94:DB:C9:38:63:06 mtu 1500
Aug 17 08:33:20 openelec daemon.info connmand[373]: wlan0 {newlink} index 3 operstate 0 <UNKNOWN>
Aug 17 08:33:20 openelec user.info kernel: [ 5.080149] HDMI status: Codec=3 Pin=5 Presence_Detect=0 ELD_Valid=0
Aug 17 08:33:20 openelec daemon.info connmand[373]: wlan0 {update} flags 4099 <UP>
Aug 17 08:33:20 openelec daemon.info connmand[373]: wlan0 {newlink} index 3 operstate 5 <DORMANT>
Aug 17 08:33:20 openelec user.info kernel: [ 5.084004] ADDRCONF(NETDEV_UP): wlan0: link is not ready
Aug 17 08:33:20 openelec user.info kernel: [ 5.093696] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1c.3/0000:02:00.1/sound/card1/input7
Aug 17 08:33:20 openelec user.info kernel: [ 5.094031] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1c.3/0000:02:00.1/sound/card1/input8
Aug 17 08:33:20 openelec user.info kernel: [ 5.094340] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1c.3/0000:02:00.1/sound/card1/input9
Aug 17 08:33:20 openelec user.info kernel: [ 5.094663] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1c.3/0000:02:00.1/sound/card1/input10
Aug 17 08:33:20 openelec user.notice Boot: ### SSH: generating SSH2 RSA key ###
Aug 17 08:33:20 openelec user.notice Boot: ### Setting up sound card ###
Aug 17 08:33:20 openelec user.warn kernel: [ 5.299856] nvidia: module license 'NVIDIA' taints kernel.
Aug 17 08:33:20 openelec user.warn kernel: [ 5.299865] Disabling lock debugging due to kernel taint
Aug 17 08:33:21 openelec user.info kernel: [ 6.106946] r8168: eth0: link up
Aug 17 08:33:21 openelec daemon.info connmand[373]: wlan0 {newlink} index 3 address 94:DB:C9:38:63:06 mtu 1500
Aug 17 08:33:21 openelec daemon.info connmand[373]: wlan0 {newlink} index 3 operstate 2 <DOWN>
Aug 17 08:33:21 openelec daemon.info connmand[373]: eth0 {add} route ff00:: gw :: scope 0 <UNIVERSE>
Aug 17 08:33:21 openelec daemon.info connmand[373]: eth0 {add} route fe80:: gw :: scope 0 <UNIVERSE>
Aug 17 08:33:21 openelec daemon.info connmand[373]: eth0 {update} flags 69699 <UP,RUNNING,LOWER_UP>
Aug 17 08:33:21 openelec daemon.info connmand[373]: eth0 {newlink} index 2 address C8:60:00:42:A5:57 mtu 1500
Aug 17 08:33:21 openelec daemon.info connmand[373]: eth0 {newlink} index 2 operstate 6 <UP>
Aug 17 08:33:21 openelec user.info kernel: [ 6.345379] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Aug 17 08:33:21 openelec daemon.info connmand[373]: eth0 {del} route fe80:: gw :: scope 0 <UNIVERSE>
Aug 17 08:33:21 openelec daemon.info connmand[373]: eth0 {del} route ff00:: gw :: scope 0 <UNIVERSE>
Aug 17 08:33:21 openelec user.info kernel: [ 6.348421] nvidia 0000:02:00.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
Aug 17 08:33:21 openelec user.debug kernel: [ 6.348445] nvidia 0000:02:00.0: setting latency timer to 64
Aug 17 08:33:21 openelec user.info kernel: [ 6.348457] vgaarb: device changed decodes: PCI:0000:02:00.0,olddecodes=io+mem,decodes=none:owns=io+mem
Aug 17 08:33:21 openelec user.warn kernel: [ 6.350603] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 295.71 Thu Aug 2 19:22:08 PDT 2012
Aug 17 08:33:21 openelec user.notice Boot: ### SSH: generating SSH2 DSA key ###
Aug 17 08:33:21 openelec user.notice Boot: ### Starting Samba server ###
Aug 17 08:33:21 openelec user.notice Xorg: ### starting Xorg with driver nvidia ###
Aug 17 08:33:21 openelec user.notice Xorg: ### setup xorg.conf paths ###
Aug 17 08:33:21 openelec user.notice Xorg: ### creating start options ###
Aug 17 08:33:21 openelec user.notice Xorg: ### creating needed directories and symlinks ###
Aug 17 08:33:21 openelec user.notice Xorg: ### starting Xorg with ':0.0 vt01 -s 0 -noreset -allowMouseOpenFail -config /etc/X11/xorg-nvidia.conf -ignoreABI' ###
Aug 17 08:33:21 openelec user.info kernel: [ 6.573425] r8168: eth0: link up
Aug 17 08:33:22 openelec daemon.warn connmand[373]: Skipping disconnect of carrier, network is connecting.
Aug 17 08:33:22 openelec daemon.info connmand[373]: eth0 {add} route ff00:: gw :: scope 0 <UNIVERSE>
Aug 17 08:33:22 openelec daemon.info connmand[373]: eth0 {add} route fe80:: gw :: scope 0 <UNIVERSE>
Aug 17 08:33:22 openelec daemon.err smbd[1195]: [2012/08/17 08:33:22.413256, 0] passdb/pdb_smbpasswd.c:248(startsmbfilepwent)
Aug 17 08:33:22 openelec daemon.err smbd[1195]: startsmbfilepwent_internal: file /var/run/smbpasswd did not exist. File successfully created.
Aug 17 08:33:23 openelec daemon.info connmand[373]: Setting domainname to fritz.box
Aug 17 08:33:23 openelec daemon.info avahi-daemon[688]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.178.44.
Aug 17 08:33:23 openelec daemon.err connmand[373]: Deleting host route failed (No such process)
Aug 17 08:33:23 openelec daemon.info avahi-daemon[688]: New relevant interface eth0.IPv4 for mDNS.
Aug 17 08:33:23 openelec daemon.info avahi-daemon[688]: Registering new address record for 192.168.178.44 on eth0.IPv4.
Aug 17 08:33:23 openelec daemon.info connmand[373]: eth0 {add} address 192.168.178.44/24 label eth0 family 2
Aug 17 08:33:23 openelec daemon.info connmand[373]: eth0 {add} route 192.168.178.0 gw 0.0.0.0 scope 253 <LINK>
Aug 17 08:33:23 openelec daemon.info connmand[373]: eth0 {add} route 192.168.178.1 gw 0.0.0.0 scope 253 <LINK>
Aug 17 08:33:23 openelec daemon.info connmand[373]: eth0 {add} route 0.0.0.0 gw 192.168.178.1 scope 0 <UNIVERSE>
Aug 17 08:33:23 openelec daemon.err connmand[373]: Setting default gateway route failed (File exists)
Aug 17 08:33:23 openelec daemon.info connmand[373]: eth0 {add} route 81.169.141.235 gw 192.168.178.1 scope 0 <UNIVERSE>
Aug 17 08:33:23 openelec daemon.info connmand[373]: Client-IP: 93.222.126.152
Aug 17 08:33:23 openelec daemon.info connmand[373]: Client-Country: DE
Aug 17 08:33:23 openelec daemon.info connmand[373]: eth0 {del} route 81.169.141.235 gw 192.168.178.1 scope 0 <UNIVERSE>
Aug 17 08:33:23 openelec user.notice Boot: ### Starting SSH Server ###
Aug 17 08:33:23 openelec daemon.info avahi-daemon[688]: Registering new address record for fe80::ca60:ff:fe42:a557 on eth0.*.
Aug 17 08:33:26 openelec daemon.notice dbus[466]: [system] Activating service name='org.freedesktop.UPower' (using servicehelper)
Aug 17 08:33:26 openelec daemon.notice dbus[466]: [system] Successfully activated service 'org.freedesktop.UPower'
Aug 17 08:33:26 openelec user.info kernel: [ 11.016958] EXT4-fs (sda1): re-mounted. Opts: barrier=1,stripe=4,data=ordered,commit=0
Aug 17 08:33:26 openelec user.info kernel: [ 11.684688] EXT4-fs (sda2): re-mounted. Opts: barrier=1,data=ordered,commit=0
Aug 17 08:33:31 openelec daemon.info connmand[373]: ntp: time slew +1.041418 s
Aug 17 08:33:33 openelec user.debug kernel: [ 17.416700] eth0: no IPv6 routers present
Aug 17 08:33:38 openelec user.notice Boot: ### set cpu's to 'conservative' ###
Aug 17 08:33:50 openelec user.notice Boot: ### syncing hardware clock with system clock ###
sorry here is dmesg" output
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.2.26 (jetstream@1801-lin007) (gcc version 4.7.1 (GCC) ) #1 SMP Sun Aug 12 00:34:15 CEST 2012
[ 0.000000] Command line: boot=LABEL=System disk=LABEL=Storage ssh quiet BOOT_IMAGE=/KERNEL
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
[ 0.000000] BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000007ffa0000 (usable)
[ 0.000000] BIOS-e820: 000000007ffa0000 - 000000007ffae000 (ACPI data)
[ 0.000000] BIOS-e820: 000000007ffae000 - 000000007ffe0000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000007ffe0000 - 0000000080000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
[ 0.000000] BIOS-e820: 00000000fff00000 - 0000000100000000 (reserved)
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] DMI present.
[ 0.000000] DMI: ASUSTeK Computer INC. EB1501P/EB1501P, BIOS 0601 02/03/2012
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0x7ffa0 max_arch_pfn = 0x400000000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-CFFFF write-protect
[ 0.000000] D0000-DFFFF uncachable
[ 0.000000] E0000-EFFFF write-through
[ 0.000000] F0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask F80000000 write-back
[ 0.000000] 1 disabled
[ 0.000000] 2 disabled
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] found SMP MP-table at [ffff8800000ff780] ff780
[ 0.000000] initial memory mapped : 0 - 20000000
[ 0.000000] Base memory trampoline at [ffff88000009a000] 9a000 size 20480
[ 0.000000] init_memory_mapping: 0000000000000000-000000007ffa0000
[ 0.000000] 0000000000 - 007fe00000 page 2M
[ 0.000000] 007fe00000 - 007ffa0000 page 4k
[ 0.000000] kernel direct mapping tables up to 7ffa0000 @ 1fffc000-20000000
[ 0.000000] ACPI: RSDP 00000000000fbb70 00024 (v02 ACPIAM)
[ 0.000000] ACPI: XSDT 000000007ffa0100 0004C (v01 020312 XSDT1608 20120203 MSFT 00000097)
[ 0.000000] ACPI: FACP 000000007ffa0290 000F4 (v03 020312 FACP1608 20120203 MSFT 00000097)
[ 0.000000] ACPI: DSDT 000000007ffa0440 05D1C (v01 A1654 A1654000 00000000 INTL 20060113)
[ 0.000000] ACPI: FACS 000000007ffae000 00040
[ 0.000000] ACPI: APIC 000000007ffa0390 0006C (v01 020312 APIC1608 20120203 MSFT 00000097)
[ 0.000000] ACPI: MCFG 000000007ffa0400 0003C (v01 020312 OEMMCFG 20120203 MSFT 00000097)
[ 0.000000] ACPI: OEMB 000000007ffae040 00072 (v01 020312 OEMB1608 20120203 MSFT 00000097)
[ 0.000000] ACPI: HPET 000000007ffaa440 00038 (v01 020312 OEMHPET 20120203 MSFT 00000097)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] [ffffea0000000000-ffffea0001bfffff] PMD -> [ffff88007d600000-ffff88007f1fffff] on node 0
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] DMA32 0x00001000 -> 0x00100000
[ 0.000000] Normal empty
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[2] active PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x0007ffa0
[ 0.000000] On node 0 totalpages: 524079
[ 0.000000] DMA zone: 56 pages used for memmap
[ 0.000000] DMA zone: 5 pages reserved
[ 0.000000] DMA zone: 3922 pages, LIFO batch:0
[ 0.000000] DMA32 zone: 7111 pages used for memmap
[ 0.000000] DMA32 zone: 512985 pages, LIFO batch:31
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x03] enabled)
[ 0.000000] ACPI: IOAPIC (id[0x04] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 4, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0xffffffff base: 0xfed00000
[ 0.000000] SMP: Allowing 4 CPUs, 0 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] Allocating PCI resources starting at 80000000 (gap: 80000000:7ee00000)
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:4 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 25 pages/cpu @ffff88007fc00000 s70208 r8192 d24000 u524288
[ 0.000000] pcpu-alloc: s70208 r8192 d24000 u524288 alloc=1*2097152
[ 0.000000] pcpu-alloc: [0] 0 1 2 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 516907
[ 0.000000] Kernel command line: fastboot root=/dev/ram0 rdinit=/init threadirqs boot=LABEL=System disk=LABEL=Storage ssh quiet BOOT_IMAGE=/KERNEL
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.000000] Memory: 2050600k/2096768k available (4702k kernel code, 452k absent, 45716k reserved, 3938k data, 4364k init)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] CONFIG_RCU_FANOUT set to non-default value of 32
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:4352 nr_irqs:712 16
[ 0.000000] Extended CMOS year: 2000
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] hpet clockevent registered
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 1795.358 MHz processor.
[ 0.003339] Calibrating delay loop (skipped), value calculated using timer frequency.. 3592.32 BogoMIPS (lpj=5984526)
[ 0.003348] pid_max: default: 32768 minimum: 301
[ 0.006729] Mount-cache hash table entries: 256
[ 0.006943] Initializing cgroup subsys cpuacct
[ 0.006953] Initializing cgroup subsys freezer
[ 0.006985] CPU: Physical Processor ID: 0
[ 0.006988] CPU: Processor Core ID: 0
[ 0.006992] using mwait in idle threads.
[ 0.007035] ACPI: Core revision 20111123
[ 0.017139] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.052145] CPU0: Intel(R) Atom(TM) CPU D525 @ 1.80GHz stepping 0a
[ 0.053330] APIC calibration not consistent with PM-Timer: 156ms instead of 100ms
[ 0.053330] APIC delta adjusted to PM-Timer: 1246917 (1953502)
[ 0.053330] Performance Events: PEBS fmt0+, Atom events, Intel PMU driver.
[ 0.053330] ... version: 3
[ 0.053330] ... bit width: 40
[ 0.053330] ... generic registers: 2
[ 0.053330] ... value mask: 000000ffffffffff
[ 0.053330] ... max period: 000000007fffffff
[ 0.053330] ... fixed-purpose events: 3
[ 0.053330] ... event mask: 0000000700000003
[ 0.053330] Booting Node 0, Processors #1
[ 0.053330] smpboot cpu 1: start_ip = 9a000
[ 0.006666] Disabled fast string operations
[ 0.146857] #2
[ 0.146862] smpboot cpu 2: start_ip = 9a000
[ 0.243557] #3 Ok.
[ 0.243562] smpboot cpu 3: start_ip = 9a000
[ 0.339999] Brought up 4 CPUs
[ 0.340007] Total of 4 processors activated (14369.51 BogoMIPS).
[ 0.341227] devtmpfs: initialized
[ 0.341227] NET: Registered protocol family 16
[ 0.341227] ACPI: bus type pci registered
[ 0.341227] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.341227] PCI: not using MMCONFIG
[ 0.341227] PCI: Using configuration type 1 for base access
[ 0.345226] bio: create slab <bio-0> at 0
[ 0.345226] ACPI: Added _OSI(Module Device)
[ 0.345226] ACPI: Added _OSI(Processor Device)
[ 0.345226] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.345226] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.347900] ACPI: EC: Look up EC in DSDT
[ 0.350419] ACPI: Executed 1 blocks of module-level executable AML code
[ 0.355673] ACPI: Interpreter enabled
[ 0.355684] ACPI: (supports S0 S1 S3 S5)
[ 0.355729] ACPI: Using IOAPIC for interrupt routing
[ 0.355795] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.357640] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in ACPI motherboard resources
[ 0.404711] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.404930] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.405363] pci_root PNP0A08:00: host bridge window [io 0x0000-0x0cf7]
[ 0.405370] pci_root PNP0A08:00: host bridge window [io 0x0d00-0xffff]
[ 0.405376] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff]
[ 0.405382] pci_root PNP0A08:00: host bridge window [mem 0x000d0000-0x000dffff]
[ 0.405388] pci_root PNP0A08:00: host bridge window [mem 0x80000000-0xdfffffff]
[ 0.405394] pci_root PNP0A08:00: host bridge window [mem 0xf0000000-0xfed8ffff]
[ 0.405420] pci 0000:00:00.0: [8086:a000] type 0 class 0x000600
[ 0.405498] pci 0000:00:1b.0: [8086:27d8] type 0 class 0x000403
[ 0.405517] pci 0000:00:1b.0: reg 10: [mem 0xf9ff8000-0xf9ffbfff 64bit]
[ 0.405587] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.405595] pci 0000:00:1b.0: PME# disabled
[ 0.405620] pci 0000:00:1c.0: [8086:27d0] type 1 class 0x000604
[ 0.405691] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.405697] pci 0000:00:1c.0: PME# disabled
[ 0.405722] pci 0000:00:1c.1: [8086:27d2] type 1 class 0x000604
[ 0.405792] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[ 0.405799] pci 0000:00:1c.1: PME# disabled
[ 0.405825] pci 0000:00:1c.2: [8086:27d4] type 1 class 0x000604
[ 0.405895] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[ 0.405901] pci 0000:00:1c.2: PME# disabled
[ 0.405926] pci 0000:00:1c.3: [8086:27d6] type 1 class 0x000604
[ 0.405996] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[ 0.406002] pci 0000:00:1c.3: PME# disabled
[ 0.406029] pci 0000:00:1d.0: [8086:27c8] type 0 class 0x000c03
[ 0.406071] pci 0000:00:1d.0: reg 20: [io 0xb880-0xb89f]
[ 0.406108] pci 0000:00:1d.1: [8086:27c9] type 0 class 0x000c03
[ 0.406149] pci 0000:00:1d.1: reg 20: [io 0xbc00-0xbc1f]
[ 0.406187] pci 0000:00:1d.2: [8086:27ca] type 0 class 0x000c03
[ 0.406228] pci 0000:00:1d.2: reg 20: [io 0xc000-0xc01f]
[ 0.406265] pci 0000:00:1d.3: [8086:27cb] type 0 class 0x000c03
[ 0.406306] pci 0000:00:1d.3: reg 20: [io 0xc080-0xc09f]
[ 0.406353] pci 0000:00:1d.7: [8086:27cc] type 0 class 0x000c03
[ 0.406375] pci 0000:00:1d.7: reg 10: [mem 0xf9fff800-0xf9fffbff]
[ 0.406456] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.406463] pci 0000:00:1d.7: PME# disabled
[ 0.406485] pci 0000:00:1e.0: [8086:2448] type 1 class 0x000604
[ 0.406554] pci 0000:00:1f.0: [8086:27bc] type 0 class 0x000601
[ 0.406631] pci 0000:00:1f.0: [Firmware Bug]: TigerPoint LPC.BM_STS cleared
[ 0.406695] pci 0000:00:1f.2: [8086:27c1] type 0 class 0x000106
[ 0.406715] pci 0000:00:1f.2: reg 10: [io 0xcc00-0xcc07]
[ 0.406726] pci 0000:00:1f.2: reg 14: [io 0xc880-0xc883]
[ 0.406737] pci 0000:00:1f.2: reg 18: [io 0xc800-0xc807]
[ 0.406748] pci 0000:00:1f.2: reg 1c: [io 0xc480-0xc483]
[ 0.406759] pci 0000:00:1f.2: reg 20: [io 0xc400-0xc41f]
[ 0.406775] pci 0000:00:1f.2: reg 24: [mem 0xf9fffc00-0xf9ffffff]
[ 0.406824] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.406831] pci 0000:00:1f.2: PME# disabled
[ 0.406855] pci 0000:00:1f.3: [8086:27da] type 0 class 0x000c05
[ 0.406908] pci 0000:00:1f.3: reg 20: [io 0x0400-0x041f]
[ 0.407011] pci 0000:05:00.0: [1033:0194] type 0 class 0x000c03
[ 0.407042] pci 0000:05:00.0: reg 10: [mem 0xfbffe000-0xfbffffff 64bit]
[ 0.407178] pci 0000:05:00.0: PME# supported from D0 D3hot D3cold
[ 0.407187] pci 0000:05:00.0: PME# disabled
[ 0.413327] pci 0000:00:1c.0: PCI bridge to [bus 05-05]
[ 0.413337] pci 0000:00:1c.0: bridge window [mem 0xfbf00000-0xfbffffff]
[ 0.413412] pci 0000:04:00.0: [10ec:8168] type 0 class 0x000200
[ 0.413412] pci 0000:04:00.0: reg 10: [io 0xe800-0xe8ff]
[ 0.413412] pci 0000:04:00.0: reg 18: [mem 0xf8fff000-0xf8ffffff 64bit pref]
[ 0.413412] pci 0000:04:00.0: reg 20: [mem 0xf8ff8000-0xf8ffbfff 64bit pref]
[ 0.413455] pci 0000:04:00.0: supports D1 D2
[ 0.413460] pci 0000:04:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.413468] pci 0000:04:00.0: PME# disabled
[ 0.420109] pci 0000:00:1c.1: PCI bridge to [bus 04-04]
[ 0.420109] pci 0000:00:1c.1: bridge window [io 0xe000-0xefff]
[ 0.420109] pci 0000:00:1c.1: bridge window [mem 0xf8f00000-0xf8ffffff 64bit pref]
[ 0.420109] pci 0000:03:00.0: [168c:002b] type 0 class 0x000280
[ 0.420109] pci 0000:03:00.0: reg 10: [mem 0xfbee0000-0xfbeeffff 64bit]
[ 0.420209] pci 0000:03:00.0: supports D1
[ 0.420214] pci 0000:03:00.0: PME# supported from D0 D1 D3hot D3cold
[ 0.420222] pci 0000:03:00.0: PME# disabled
[ 0.426655] pci 0000:00:1c.2: PCI bridge to [bus 03-03]
[ 0.426665] pci 0000:00:1c.2: bridge window [mem 0xfbe00000-0xfbefffff]
[ 0.426732] pci 0000:02:00.0: [10de:0a64] type 0 class 0x000300
[ 0.426751] pci 0000:02:00.0: reg 10: [mem 0xfa000000-0xfaffffff]
[ 0.426751] pci 0000:02:00.0: reg 14: [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.426751] pci 0000:02:00.0: reg 1c: [mem 0xce000000-0xcfffffff 64bit pref]
[ 0.426751] pci 0000:02:00.0: reg 24: [io 0xdc00-0xdc7f]
[ 0.426751] pci 0000:02:00.0: reg 30: [mem 0xfbd00000-0xfbd7ffff pref]
[ 0.426807] pci 0000:02:00.1: [10de:0be3] type 0 class 0x000403
[ 0.426826] pci 0000:02:00.1: reg 10: [mem 0xfbdfc000-0xfbdfffff]
[ 0.433441] pci 0000:00:1c.3: PCI bridge to [bus 02-02]
[ 0.433441] pci 0000:00:1c.3: bridge window [io 0xd000-0xdfff]
[ 0.433441] pci 0000:00:1c.3: bridge window [mem 0xfa000000-0xfbdfffff]
[ 0.433441] pci 0000:00:1c.3: bridge window [mem 0xce000000-0xdfffffff 64bit pref]
[ 0.433441] pci 0000:00:1e.0: PCI bridge to [bus 01-01] (subtractive decode)
[ 0.433441] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7] (subtractive decode)
[ 0.433441] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff] (subtractive decode)
[ 0.433444] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
[ 0.433450] pci 0000:00:1e.0: bridge window [mem 0x000d0000-0x000dffff] (subtractive decode)
[ 0.433457] pci 0000:00:1e.0: bridge window [mem 0x80000000-0xdfffffff] (subtractive decode)
[ 0.433463] pci 0000:00:1e.0: bridge window [mem 0xf0000000-0xfed8ffff] (subtractive decode)
[ 0.433488] pci_bus 0000:00: on NUMA node 0
[ 0.433497] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.433744] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P4._PRT]
[ 0.433826] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P5._PRT]
[ 0.433880] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P6._PRT]
[ 0.433934] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P7._PRT]
[ 0.434045] pci0000:00: Requesting ACPI _OSC control (0x1d)
[ 0.434054] pci0000:00: ACPI _OSC request failed (AE_NOT_FOUND), returned control mask: 0x1d
[ 0.434058] ACPI _OSC control for PCIe not granted, disabling ASPM
[ 0.446750] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 7 10 11 12 14 *15)
[ 0.446884] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 *5 7 10 11 12 14 15)
[ 0.447001] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 7 10 *11 12 14 15)
[ 0.447117] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 7 *10 11 12 14 15)
[ 0.447234] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 *4 5 7 10 11 12 14 15)
[ 0.447349] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 *7 10 11 12 14 15)
[ 0.447465] ACPI: PCI Interrupt Link [LNKG] (IRQs *3 4 5 7 10 11 12 14 15)
[ 0.447582] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 7 10 11 12 *14 15)
[ 0.447741] vgaarb: device added: PCI:0000:02:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.447741] vgaarb: loaded
[ 0.447741] vgaarb: bridge control possible 0000:02:00.0
[ 0.447741] SCSI subsystem initialized
[ 0.447741] libata version 3.00 loaded.
[ 0.447741] usbcore: registered new interface driver usbfs
[ 0.447741] usbcore: registered new interface driver hub
[ 0.447741] usbcore: registered new device driver usb
[ 0.447741] PCI: Using ACPI for IRQ routing
[ 0.453899] PCI: pci_cache_line_size set to 64 bytes
[ 0.454003] reserve RAM buffer: 000000000009fc00 - 000000000009ffff
[ 0.454009] reserve RAM buffer: 000000007ffa0000 - 000000007fffffff
[ 0.454305] cfg80211: Calling CRDA to update world regulatory domain
[ 0.454371] HPET: 3 timers in total, 0 timers will be used for per-cpu timer
[ 0.463459] Switching to clocksource hpet
[ 0.463459] pnp: PnP ACPI init
[ 0.463479] ACPI: bus type pnp registered
[ 0.463728] pnp 00:00: [bus 00-ff]
[ 0.463734] pnp 00:00: [io 0x0cf8-0x0cff]
[ 0.463740] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 0.463745] pnp 00:00: [io 0x0d00-0xffff window]
[ 0.463751] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 0.463756] pnp 00:00: [mem 0x000d0000-0x000dffff window]
[ 0.463762] pnp 00:00: [mem 0x80000000-0xdfffffff window]
[ 0.463768] pnp 00:00: [mem 0xf0000000-0xfed8ffff window]
[ 0.463860] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
[ 0.463891] pnp 00:01: [mem 0xfed14000-0xfed19fff]
[ 0.463896] pnp 00:01: [mem 0xfed90000-0xfed93fff]
[ 0.463986] system 00:01: [mem 0xfed14000-0xfed19fff] has been reserved
[ 0.463993] system 00:01: [mem 0xfed90000-0xfed93fff] has been reserved
[ 0.464001] system 00:01: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.464077] pnp 00:02: [dma 4]
[ 0.464083] pnp 00:02: [io 0x0000-0x000f]
[ 0.464088] pnp 00:02: [io 0x0081-0x0083]
[ 0.464092] pnp 00:02: [io 0x0087]
[ 0.464097] pnp 00:02: [io 0x0089-0x008b]
[ 0.464105] pnp 00:02: [io 0x008f]
[ 0.464109] pnp 00:02: [io 0x00c0-0x00df]
[ 0.464161] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.464190] pnp 00:03: [io 0x0070-0x0071]
[ 0.464207] pnp 00:03: [irq 8]
[ 0.464262] pnp 00:03: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.464286] pnp 00:04: [io 0x0061]
[ 0.464340] pnp 00:04: Plug and Play ACPI device, IDs PNP0800 (active)
[ 0.464367] pnp 00:05: [io 0x00f0-0x00ff]
[ 0.464379] pnp 00:05: [irq 13]
[ 0.464434] pnp 00:05: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.464849] pnp 00:06: [io 0x0000-0xffffffffffffffff disabled]
[ 0.464856] pnp 00:06: [io 0x0a00-0x0a0f]
[ 0.464861] pnp 00:06: [io 0x0290-0x029f]
[ 0.464866] pnp 00:06: [io 0x0a20-0x0a2f]
[ 0.464870] pnp 00:06: [io 0x0a30-0x0a3f]
[ 0.464963] system 00:06: [io 0x0a00-0x0a0f] has been reserved
[ 0.464970] system 00:06: [io 0x0290-0x029f] has been reserved
[ 0.464976] system 00:06: [io 0x0a20-0x0a2f] has been reserved
[ 0.464982] system 00:06: [io 0x0a30-0x0a3f] has been reserved
[ 0.464989] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.465262] pnp 00:07: [io 0x0010-0x001f]
[ 0.465268] pnp 00:07: [io 0x0022-0x003f]
[ 0.465273] pnp 00:07: [io 0x0044-0x005f]
[ 0.465278] pnp 00:07: [io 0x0062-0x0063]
[ 0.465282] pnp 00:07: [io 0x0065-0x006f]
[ 0.465287] pnp 00:07: [io 0x0072-0x007f]
[ 0.465292] pnp 00:07: [io 0x0080]
[ 0.465296] pnp 00:07: [io 0x0084-0x0086]
[ 0.465301] pnp 00:07: [io 0x0088]
[ 0.465306] pnp 00:07: [io 0x008c-0x008e]
[ 0.465311] pnp 00:07: [io 0x0090-0x009f]
[ 0.465315] pnp 00:07: [io 0x00a2-0x00bf]
[ 0.465320] pnp 00:07: [io 0x00e0-0x00ef]
[ 0.465325] pnp 00:07: [io 0x04d0-0x04d1]
[ 0.465330] pnp 00:07: [io 0x0800-0x087f]
[ 0.465335] pnp 00:07: [io 0x0400-0x03ff disabled]
[ 0.465340] pnp 00:07: [io 0x0480-0x04bf]
[ 0.465345] pnp 00:07: [mem 0xfed1c000-0xfed1ffff]
[ 0.465350] pnp 00:07: [mem 0xfed20000-0xfed8ffff]
[ 0.465459] system 00:07: [io 0x04d0-0x04d1] has been reserved
[ 0.465466] system 00:07: [io 0x0800-0x087f] has been reserved
[ 0.465472] system 00:07: [io 0x0480-0x04bf] has been reserved
[ 0.465480] system 00:07: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.465487] system 00:07: [mem 0xfed20000-0xfed8ffff] has been reserved
[ 0.465494] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.465662] pnp 00:08: [mem 0xfed00000-0xfed003ff]
[ 0.465723] pnp 00:08: Plug and Play ACPI device, IDs PNP0103 (active)
[ 0.465942] pnp 00:09: [io 0x0060]
[ 0.465947] pnp 00:09: [io 0x0064]
[ 0.465953] pnp 00:09: [mem 0xfec00000-0xfec00fff]
[ 0.465958] pnp 00:09: [mem 0xfee00000-0xfee00fff]
[ 0.466048] system 00:09: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.466055] system 00:09: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.466063] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.466869] pnp 00:0a: Plug and Play ACPI device, IDs ITE8713 (disabled)
[ 0.467046] pnp 00:0b: [mem 0xe0000000-0xefffffff]
[ 0.467141] system 00:0b: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.467150] system 00:0b: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.467542] pnp 00:0c: [mem 0x00000000-0x0009ffff]
[ 0.467549] pnp 00:0c: [mem 0x000c0000-0x000cffff]
[ 0.467554] pnp 00:0c: [mem 0x000e0000-0x000fffff]
[ 0.467559] pnp 00:0c: [mem 0x00100000-0x7fffffff]
[ 0.467565] pnp 00:0c: [mem 0xfed90000-0xffffffff]
[ 0.467674] system 00:0c: [mem 0x00000000-0x0009ffff] could not be reserved
[ 0.467681] system 00:0c: [mem 0x000c0000-0x000cffff] could not be reserved
[ 0.467688] system 00:0c: [mem 0x000e0000-0x000fffff] could not be reserved
[ 0.467695] system 00:0c: [mem 0x00100000-0x7fffffff] could not be reserved
[ 0.467702] system 00:0c: [mem 0xfed90000-0xffffffff] could not be reserved
[ 0.467709] system 00:0c: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.468028] pnp: PnP ACPI: found 13 devices
[ 0.468032] ACPI: ACPI bus type pnp unregistered
[ 0.477773] PCI: max bus depth: 1 pci_try_num: 2
[ 0.477831] pci 0000:00:1c.2: BAR 9: assigned [mem 0x80000000-0x801fffff 64bit pref]
[ 0.477841] pci 0000:00:1c.2: BAR 7: assigned [io 0x1000-0x1fff]
[ 0.477849] pci 0000:00:1c.1: BAR 8: assigned [mem 0x80200000-0x805fffff]
[ 0.477858] pci 0000:00:1c.0: BAR 9: assigned [mem 0x80600000-0x807fffff 64bit pref]
[ 0.477866] pci 0000:00:1c.0: BAR 7: assigned [io 0x2000-0x2fff]
[ 0.477873] pci 0000:00:1c.0: PCI bridge to [bus 05-05]
[ 0.477879] pci 0000:00:1c.0: bridge window [io 0x2000-0x2fff]
[ 0.477887] pci 0000:00:1c.0: bridge window [mem 0xfbf00000-0xfbffffff]
[ 0.477895] pci 0000:00:1c.0: bridge window [mem 0x80600000-0x807fffff 64bit pref]
[ 0.477904] pci 0000:00:1c.1: PCI bridge to [bus 04-04]
[ 0.477910] pci 0000:00:1c.1: bridge window [io 0xe000-0xefff]
[ 0.477918] pci 0000:00:1c.1: bridge window [mem 0x80200000-0x805fffff]
[ 0.477925] pci 0000:00:1c.1: bridge window [mem 0xf8f00000-0xf8ffffff 64bit pref]
[ 0.477935] pci 0000:00:1c.2: PCI bridge to [bus 03-03]
[ 0.477940] pci 0000:00:1c.2: bridge window [io 0x1000-0x1fff]
[ 0.477948] pci 0000:00:1c.2: bridge window [mem 0xfbe00000-0xfbefffff]
[ 0.477956] pci 0000:00:1c.2: bridge window [mem 0x80000000-0x801fffff 64bit pref]
[ 0.477965] pci 0000:00:1c.3: PCI bridge to [bus 02-02]
[ 0.477971] pci 0000:00:1c.3: bridge window [io 0xd000-0xdfff]
[ 0.477979] pci 0000:00:1c.3: bridge window [mem 0xfa000000-0xfbdfffff]
[ 0.477987] pci 0000:00:1c.3: bridge window [mem 0xce000000-0xdfffffff 64bit pref]
[ 0.477996] pci 0000:00:1e.0: PCI bridge to [bus 01-01]
[ 0.478016] pci 0000:00:1c.0: enabling device (0106 -> 0107)
[ 0.478044] pci 0000:00:1c.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 0.478052] pci 0000:00:1c.0: setting latency timer to 64
[ 0.478072] pci 0000:00:1c.1: PCI INT B -> GSI 17 (level, low) -> IRQ 17
[ 0.478079] pci 0000:00:1c.1: setting latency timer to 64
[ 0.478089] pci 0000:00:1c.2: enabling device (0106 -> 0107)
[ 0.478103] pci 0000:00:1c.2: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[ 0.478111] pci 0000:00:1c.2: setting latency timer to 64
[ 0.478132] pci 0000:00:1c.3: PCI INT D -> GSI 19 (level, low) -> IRQ 19
[ 0.478139] pci 0000:00:1c.3: setting latency timer to 64
[ 0.478150] pci 0000:00:1e.0: setting latency timer to 64
[ 0.478157] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
[ 0.478162] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff]
[ 0.478168] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.478174] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000dffff]
[ 0.478179] pci_bus 0000:00: resource 8 [mem 0x80000000-0xdfffffff]
[ 0.478185] pci_bus 0000:00: resource 9 [mem 0xf0000000-0xfed8ffff]
[ 0.478191] pci_bus 0000:05: resource 0 [io 0x2000-0x2fff]
[ 0.478197] pci_bus 0000:05: resource 1 [mem 0xfbf00000-0xfbffffff]
[ 0.478203] pci_bus 0000:05: resource 2 [mem 0x80600000-0x807fffff 64bit pref]
[ 0.478209] pci_bus 0000:04: resource 0 [io 0xe000-0xefff]
[ 0.478214] pci_bus 0000:04: resource 1 [mem 0x80200000-0x805fffff]
[ 0.478220] pci_bus 0000:04: resource 2 [mem 0xf8f00000-0xf8ffffff 64bit pref]
[ 0.478226] pci_bus 0000:03: resource 0 [io 0x1000-0x1fff]
[ 0.478232] pci_bus 0000:03: resource 1 [mem 0xfbe00000-0xfbefffff]
[ 0.478238] pci_bus 0000:03: resource 2 [mem 0x80000000-0x801fffff 64bit pref]
[ 0.478244] pci_bus 0000:02: resource 0 [io 0xd000-0xdfff]
[ 0.478249] pci_bus 0000:02: resource 1 [mem 0xfa000000-0xfbdfffff]
[ 0.478255] pci_bus 0000:02: resource 2 [mem 0xce000000-0xdfffffff 64bit pref]
[ 0.478262] pci_bus 0000:01: resource 4 [io 0x0000-0x0cf7]
[ 0.478267] pci_bus 0000:01: resource 5 [io 0x0d00-0xffff]
[ 0.478273] pci_bus 0000:01: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.478278] pci_bus 0000:01: resource 7 [mem 0x000d0000-0x000dffff]
[ 0.478284] pci_bus 0000:01: resource 8 [mem 0x80000000-0xdfffffff]
[ 0.478290] pci_bus 0000:01: resource 9 [mem 0xf0000000-0xfed8ffff]
[ 0.478444] NET: Registered protocol family 2
[ 0.478582] IP route cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.479216] TCP established hash table entries: 262144 (order: 10, 4194304 bytes)
[ 0.481840] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.482473] TCP: Hash tables configured (established 262144 bind 65536)
[ 0.482479] TCP reno registered
[ 0.482488] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.482518] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.482782] NET: Registered protocol family 1
[ 0.483063] RPC: Registered named UNIX socket transport module.
[ 0.483068] RPC: Registered udp transport module.
[ 0.483072] RPC: Registered tcp transport module.
[ 0.483076] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.483141] pci 0000:00:1d.0: PCI INT A -> GSI 23 (level, low) -> IRQ 23
[ 0.483162] pci 0000:00:1d.0: PCI INT A disabled
[ 0.483184] pci 0000:00:1d.1: PCI INT B -> GSI 21 (level, low) -> IRQ 21
[ 0.483203] pci 0000:00:1d.1: PCI INT B disabled
[ 0.483218] pci 0000:00:1d.2: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[ 0.483236] pci 0000:00:1d.2: PCI INT C disabled
[ 0.483257] pci 0000:00:1d.3: PCI INT D -> GSI 22 (level, low) -> IRQ 22
[ 0.483276] pci 0000:00:1d.3: PCI INT D disabled
[ 0.483292] pci 0000:00:1d.7: PCI INT A -> GSI 23 (level, low) -> IRQ 23
[ 0.483328] pci 0000:00:1d.7: PCI INT A disabled
[ 0.483387] pci 0000:05:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 0.483419] pci 0000:05:00.0: PCI INT A disabled
[ 0.483453] pci 0000:02:00.0: Boot video device
[ 0.483473] PCI: CLS 32 bytes, default 64
[ 0.490500] microcode: CPU0 sig=0x106ca, pf=0x8, revision=0x107
[ 0.490520] microcode: CPU1 sig=0x106ca, pf=0x8, revision=0x107
[ 0.490538] microcode: CPU2 sig=0x106ca, pf=0x8, revision=0x107
[ 0.490557] microcode: CPU3 sig=0x106ca, pf=0x8, revision=0x107
[ 0.490628] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 0.492215] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.492687] fuse init (API version 7.17)
[ 0.492854] JFS: nTxBlock = 8192, nTxLock = 65536
[ 0.497141] SGI XFS with security attributes, large block/inode numbers, no debug enabled
[ 0.497815] msgmni has been set to 4005
[ 0.498806] alg: No test for stdrng (krng)
[ 0.498891] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.498898] io scheduler noop registered
[ 0.498946] io scheduler cfq registered (default)
[ 0.499100] pcieport 0000:00:1c.0: setting latency timer to 64
[ 0.499154] pcieport 0000:00:1c.0: irq 40 for MSI/MSI-X
[ 0.499247] pcieport 0000:00:1c.1: setting latency timer to 64
[ 0.499291] pcieport 0000:00:1c.1: irq 41 for MSI/MSI-X
[ 0.499371] pcieport 0000:00:1c.2: setting latency timer to 64
[ 0.499414] pcieport 0000:00:1c.2: irq 42 for MSI/MSI-X
[ 0.499506] pcieport 0000:00:1c.3: setting latency timer to 64
[ 0.499549] pcieport 0000:00:1c.3: irq 43 for MSI/MSI-X
[ 0.499753] intel_idle: MWAIT substates: 0x10
[ 0.499772] intel_idle: v0.4 model 0x1C
[ 0.499776] intel_idle: lapic_timer_reliable_states 0x2
[ 0.499992] input: Power Button as /devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input0
[ 0.500041] ACPI: Power Button [PWRB]
[ 0.500176] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 0.500184] ACPI: Power Button [PWRF]
[ 0.503712] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.677037] Linux agpgart interface v0.103
[ 0.680099] brd: module loaded
[ 0.681660] loop: module loaded
[ 0.682201] nbd: registered device at major 43
[ 0.685079] Loading iSCSI transport class v2.0-870.
[ 0.685287] iscsi: registered transport (tcp)
[ 0.685448] ahci 0000:00:1f.2: version 3.0
[ 0.685471] ahci 0000:00:1f.2: PCI INT B -> GSI 19 (level, low) -> IRQ 19
[ 0.685546] ahci 0000:00:1f.2: irq 44 for MSI/MSI-X
[ 0.685625] ahci 0000:00:1f.2: AHCI 0001.0100 32 slots 4 ports 3 Gbps 0x3 impl SATA mode
[ 0.685633] ahci 0000:00:1f.2: flags: 64bit ncq pm led clo pio slum part
[ 0.685641] ahci 0000:00:1f.2: setting latency timer to 64
[ 0.686684] scsi0 : ahci
[ 0.686937] scsi1 : ahci
[ 0.687102] scsi2 : ahci
[ 0.687267] scsi3 : ahci
[ 0.687573] ata1: SATA max UDMA/133 abar m1024@0xf9fffc00 port 0xf9fffd00 irq 44
[ 0.687581] ata2: SATA max UDMA/133 abar m1024@0xf9fffc00 port 0xf9fffd80 irq 44
[ 0.687586] ata3: DUMMY
[ 0.687590] ata4: DUMMY
[ 0.687945] tun: Universal TUN/TAP device driver, 1.6
[ 0.687950] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 0.688088] e100: Intel(R) PRO/100 Network Driver, 3.5.24-k2-NAPI
[ 0.688093] e100: Copyright(c) 1999-2006 Intel Corporation
[ 0.688135] e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI
[ 0.688140] e1000: Copyright (c) 1999-2006 Intel Corporation.
[ 0.688180] e1000e: Intel(R) PRO/1000 Network Driver - 1.5.1-k
[ 0.688184] e1000e: Copyright(c) 1999 - 2011 Intel Corporation.
[ 0.688261] jme: JMicron JMC2XX ethernet driver version 1.0.8
[ 0.688374] r8168 Gigabit Ethernet driver 8.029.00-NAPI loaded
[ 0.688417] r8168 0000:04:00.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 0.688444] r8168 0000:04:00.0: setting latency timer to 64
[ 0.688521] r8168 0000:04:00.0: irq 45 for MSI/MSI-X
[ 0.688755] eth%d: RTL8168E/8111E at 0xffffc9000001e000, c8:60:00:42:a5:57, IRQ 45
[ 0.832797] r8168: This product is covered by one or more of the following patents: US5,307,459, US5,434,872, US5,732,094, US6,570,884, US6,115,776, and US6,327,625.
[ 0.832805] eth0: Identified chip type is 'RTL8168E/8111E'.
[ 0.832810] r8168 Copyright (C) 2012 Realtek NIC software team <nicfae@realtek.com>
[ 0.832813] This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
[ 0.832816] This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[ 0.832874] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.832914] ehci_hcd 0000:00:1d.7: PCI INT A -> GSI 23 (level, low) -> IRQ 23
[ 0.832937] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[ 0.832944] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 0.832958] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 1
[ 0.832993] ehci_hcd 0000:00:1d.7: using broken periodic workaround
[ 0.833006] ehci_hcd 0000:00:1d.7: debug port 1
[ 0.836902] ehci_hcd 0000:00:1d.7: cache line size of 32 is not supported
[ 0.837015] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xf9fff800
[ 0.850037] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 0.850344] hub 1-0:1.0: USB hub found
[ 0.850355] hub 1-0:1.0: 8 ports detected
[ 0.850535] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.850573] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.850651] uhci_hcd 0000:00:1d.0: PCI INT A -> GSI 23 (level, low) -> IRQ 23
[ 0.850666] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 0.850673] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 0.850686] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 0.850795] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000b880
[ 0.851104] hub 2-0:1.0: USB hub found
[ 0.851115] hub 2-0:1.0: 2 ports detected
[ 0.851248] uhci_hcd 0000:00:1d.1: PCI INT B -> GSI 21 (level, low) -> IRQ 21
[ 0.851261] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 0.851267] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 0.851282] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[ 0.851405] uhci_hcd 0000:00:1d.1: irq 21, io base 0x0000bc00
[ 0.851708] hub 3-0:1.0: USB hub found
[ 0.851719] hub 3-0:1.0: 2 ports detected
[ 0.851844] uhci_hcd 0000:00:1d.2: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[ 0.851857] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 0.851863] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 0.851876] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[ 0.851992] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000c000
[ 0.852302] hub 4-0:1.0: USB hub found
[ 0.852312] hub 4-0:1.0: 2 ports detected
[ 0.852438] uhci_hcd 0000:00:1d.3: PCI INT D -> GSI 22 (level, low) -> IRQ 22
[ 0.852451] uhci_hcd 0000:00:1d.3: setting latency timer to 64
[ 0.852457] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[ 0.852470] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
[ 0.852591] uhci_hcd 0000:00:1d.3: irq 22, io base 0x0000c080
[ 0.852893] hub 5-0:1.0: USB hub found
[ 0.852903] hub 5-0:1.0: 2 ports detected
[ 0.853050] Initializing USB Mass Storage driver...
[ 0.853121] usbcore: registered new interface driver usb-storage
[ 0.853125] USB Mass Storage support registered.
[ 0.853240] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 0.853897] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.853917] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.854140] mousedev: PS/2 mouse device common for all mice
[ 0.854592] rtc_cmos 00:03: RTC can wake from S4
[ 0.854777] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0
[ 0.854866] rtc0: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[ 0.854898] i2c /dev entries driver
[ 0.854972] i801_smbus 0000:00:1f.3: PCI INT B -> GSI 19 (level, low) -> IRQ 19
[ 0.854981] ACPI: resource 0000:00:1f.3 [io 0x0400-0x041f] conflicts with ACPI region SMRG [io 0x400-0x40f]
[ 0.854986] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 0.855163] lirc_dev: IR Remote Control driver registered, major 252
[ 0.855169] IR NEC protocol handler initialized
[ 0.855172] IR RC5(x) protocol handler initialized
[ 0.855176] IR RC6 protocol handler initialized
[ 0.855179] IR JVC protocol handler initialized
[ 0.855182] IR Sony protocol handler initialized
[ 0.855186] IR RC5 (streamzap) protocol handler initialized
[ 0.855189] IR MCE Keyboard/mouse protocol handler initialized
[ 0.855384] cpuidle: using governor ladder
[ 0.855660] cpuidle: using governor menu
[ 0.855665] EFI Variables Facility v0.08 2004-May-17
[ 0.855669] No iBFT detected.
[ 0.856336] usbcore: registered new interface driver usbhid
[ 0.856341] usbhid: USB HID core driver
[ 0.856464] Netfilter messages via NETLINK v0.30.
[ 0.856910] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 0.856952] TCP cubic registered
[ 0.857104] NET: Registered protocol family 10
[ 0.858266] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 0.858298] NET: Registered protocol family 17
[ 0.858325] lib80211: common routines for IEEE802.11 drivers
[ 0.858330] lib80211_crypt: registered algorithm 'NULL'
[ 0.858335] Registering the dns_resolver key type
[ 0.859335] rtc_cmos 00:03: setting system clock to 2012-08-17 09:08:38 UTC (1345194518)
[ 1.006708] ata2: SATA link down (SStatus 0 SControl 300)
[ 1.006740] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1.055222] ata1.00: ATA-8: TOSHIBA MK3259GSXP, GN003J, max UDMA/100
[ 1.055230] ata1.00: 625142448 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[ 1.056097] ata1.00: configured for UDMA/100
[ 1.056349] scsi 0:0:0:0: Direct-Access ATA TOSHIBA MK3259GS GN00 PQ: 0 ANSI: 5
[ 1.056790] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1.056808] sd 0:0:0:0: [sda] 625142448 512-byte logical blocks: (320 GB/298 GiB)
[ 1.056815] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 1.057015] sd 0:0:0:0: [sda] Write Protect is off
[ 1.057022] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.057101] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.105061] sda: sda1 sda2
[ 1.105768] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.115522] Freeing unused kernel memory: 4364k freed
[ 1.118401] Write protecting the kernel read-only data: 8192k
[ 1.130061] Freeing unused kernel memory: 1432k freed
[ 1.134098] Freeing unused kernel memory: 380k freed
[ 1.238626] uvesafb: NVIDIA Corporation, GT218 Board - 06930002, Chip Rev , OEM: NVIDIA, VBE v3.0
[ 1.263381] usb 1-4: new high-speed USB device number 4 using ehci_hcd
[ 1.330019] uvesafb: VBIOS/hardware doesn't support DDC transfers
[ 1.330028] uvesafb: no monitor limits have been set, default refresh rate will be used
[ 1.330738] uvesafb: scrolling: redraw
[ 1.472226] Console: switching to colour frame buffer device 80x30
[ 1.475529] uvesafb: framebuffer at 0xcf000000, mapped to 0xffffc90010680000, using 10240k, total 14336k
[ 1.475535] fb0: VESA VGA frame buffer device
[ 1.478196] xhci_hcd 0000:05:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 1.478231] xhci_hcd 0000:05:00.0: setting latency timer to 64
[ 1.478239] xhci_hcd 0000:05:00.0: xHCI Host Controller
[ 1.478254] xhci_hcd 0000:05:00.0: new USB bus registered, assigned bus number 6
[ 1.478560] xhci_hcd 0000:05:00.0: irq 16, io mem 0xfbffe000
[ 1.478701] xhci_hcd 0000:05:00.0: irq 46 for MSI/MSI-X
[ 1.478717] xhci_hcd 0000:05:00.0: irq 47 for MSI/MSI-X
[ 1.478731] xhci_hcd 0000:05:00.0: irq 48 for MSI/MSI-X
[ 1.478743] xhci_hcd 0000:05:00.0: irq 49 for MSI/MSI-X
[ 1.478756] xhci_hcd 0000:05:00.0: irq 50 for MSI/MSI-X
[ 1.479431] xHCI xhci_add_endpoint called for root hub
[ 1.479436] xHCI xhci_check_bandwidth called for root hub
[ 1.479506] hub 6-0:1.0: USB hub found
[ 1.479520] hub 6-0:1.0: 2 ports detected
[ 1.479648] xhci_hcd 0000:05:00.0: xHCI Host Controller
[ 1.479659] xhci_hcd 0000:05:00.0: new USB bus registered, assigned bus number 7
[ 1.482065] xHCI xhci_add_endpoint called for root hub
[ 1.482069] xHCI xhci_check_bandwidth called for root hub
[ 1.482136] hub 7-0:1.0: USB hub found
[ 1.482150] hub 7-0:1.0: 2 ports detected
[ 1.490044] Refined TSC clocksource calibration: 1795.563 MHz.
[ 1.490054] Switching to clocksource tsc
[ 1.493371] usb 1-6: new high-speed USB device number 5 using ehci_hcd
[ 1.622238] scsi4 : usb-storage 1-6:1.0
[ 1.650279] EXT4-fs (sda1): couldn't mount as ext3 due to feature incompatibilities
[ 1.686917] EXT4-fs (sda1): couldn't mount as ext2 due to feature incompatibilities
[ 1.726712] usb 1-8: new high-speed USB device number 6 using ehci_hcd
[ 1.749391] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 1.852892] scsi5 : usb-storage 1-8:1.0
[ 2.076702] usb 2-1: new low-speed USB device number 2 using uhci_hcd
[ 2.150269] EXT4-fs (sda2): couldn't mount as ext3 due to feature incompatibilities
[ 2.166970] EXT4-fs (sda2): couldn't mount as ext2 due to feature incompatibilities
[ 2.371361] input: USB Keyboard as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1:1.0/input/input2
[ 2.371614] generic-usb 0003:04D9:1503.0001: input,hidraw0: USB HID v1.10 Keyboard [ USB Keyboard] on usb-0000:00:1d.0-1/input0
[ 2.461005] input: USB Keyboard as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1:1.1/input/input3
[ 2.461257] generic-usb 0003:04D9:1503.0002: input,hidraw1: USB HID v1.10 Device [ USB Keyboard] on usb-0000:00:1d.0-1/input1
[ 2.624813] scsi 4:0:0:0: Direct-Access Generic STORAGE DEVICE 0206 PQ: 0 ANSI: 0
[ 2.626191] sd 4:0:0:0: Attached scsi generic sg1 type 0
[ 2.627535] sd 4:0:0:0: [sdb] Attached SCSI removable disk
[ 2.686706] usb 3-1: new low-speed USB device number 2 using uhci_hcd
[ 2.854927] scsi 5:0:0:0: CD-ROM Optiarc DVD RW AD-7690H 1.00 PQ: 0 ANSI: 0
[ 2.860042] sr0: scsi3-mmc drive: 10x/24x writer dvd-ram cd/rw xa/form2 cdda caddy
[ 2.860049] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 2.860310] sr 5:0:0:0: Attached scsi CD-ROM sr0
[ 2.860532] sr 5:0:0:0: Attached scsi generic sg2 type 5
[ 2.881863] input: PIXART USB OPTICAL MOUSE as /devices/pci0000:00/0000:00:1d.1/usb3/3-1/3-1:1.0/input/input4
[ 2.882147] generic-usb 0003:093A:2510.0003: input,hidraw2: USB HID v1.11 Mouse [PIXART USB OPTICAL MOUSE] on usb-0000:00:1d.1-1/input0
[ 2.957978] EXT4-fs (sda2): recovery complete
[ 2.958172] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
>[ 3.665627] systemd-udevd[229]: starting version 187
[ 3.879904] coretemp coretemp.0: Using relative temperature scale!
[ 3.879938] coretemp coretemp.0: Using relative temperature scale!
[ 3.902329] ite-cir 00:0a: [io 0x02f8-0x02ff]
[ 3.905136] ite-cir 00:0a: [irq 5]
[ 3.909038] ite-cir 00:0a: activated
[ 3.909063] ite_cir: Auto-detected model: ITE8713 CIR transceiver
[ 3.909069] ite_cir: Using model: ITE8713 CIR transceiver
[ 3.909077] ite_cir: TX-capable: 1
[ 3.909082] ite_cir: Sample period (ns): 8680
[ 3.909087] ite_cir: TX carrier frequency (Hz): 38000
[ 3.909092] ite_cir: TX duty cycle (%): 33
[ 3.909097] ite_cir: RX low carrier frequency (Hz): 0
[ 3.909102] ite_cir: RX high carrier frequency (Hz): 0
[ 3.910889] Registered IR keymap rc-rc6-mce
[ 3.911647] input: ITE8713 CIR transceiver as /devices/virtual/rc/rc0/input5
[ 3.911999] rc0: ITE8713 CIR transceiver as /devices/virtual/rc/rc0
[ 3.912477] input: MCE IR Keyboard/Mouse (ite-cir) as /devices/virtual/input/input6
[ 3.912758] ite_cir: driver has been successfully loaded
[ 4.128035] dw2102: su3000_identify_state
[ 4.128039]
[ 4.128046] dvb-usb: found a 'Terratec Cinergy S2 USB HD Rev.2' in warm state.
[ 4.128091] dw2102: su3000_power_ctrl: 1, initialized 0
[ 4.128094]
[ 4.128755] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[ 4.129793] DVB: registering new adapter (Terratec Cinergy S2 USB HD Rev.2)
[ 4.134711] dvb-usb: MAC address: ff:ff:ff:ff:ff:ff
[ 4.159320] snd_hda_intel 0000:00:1b.0: PCI INT A -> GSI 20 (level, low) -> IRQ 20
[ 4.159430] snd_hda_intel 0000:00:1b.0: irq 51 for MSI/MSI-X
[ 4.161067] snd_hda_intel 0000:00:1b.0: setting latency timer to 64
[ 4.390967] Invalid probe, probably not a DS3000
[ 4.390983] dvb-usb: no frontend was attached by 'Terratec Cinergy S2 USB HD Rev.2'
[ 4.391385] input: IR-receiver inside an USB DVB receiver as /devices/pci0000:00/0000:00:1d.7/usb1/1-4/input/input7
[ 4.391532] dvb-usb: schedule remote query interval to 150 msecs.
[ 4.391542] dw2102: su3000_power_ctrl: 0, initialized 1
[ 4.391545]
[ 4.391550] dvb-usb: Terratec Cinergy S2 USB HD Rev.2 successfully initialized and connected.
[ 4.391642] usbcore: registered new interface driver dw2102
[ 4.608847] ath9k 0000:03:00.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 4.608867] ath9k 0000:03:00.0: setting latency timer to 64
[ 4.658915] ath: EEPROM regdomain: 0x60
[ 4.658921] ath: EEPROM indicates we should expect a direct regpair map
[ 4.658929] ath: Country alpha2 being used: 00
[ 4.658933] ath: Regpair used: 0x60
[ 4.662132] ieee80211 phy0: Selected rate control algorithm 'ath9k_rate_control'
[ 4.664299] Registered led device: ath9k-phy0
[ 4.664318] ieee80211 phy0: Atheros AR9285 Rev:2 mem=0xffffc90012420000, irq=18
[ 4.770961] r8168: eth0: link down
[ 4.771693] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 5.175495] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 5.405574] nvidia: module license 'NVIDIA' taints kernel.
[ 5.405581] Disabling lock debugging due to kernel taint
[ 5.432861] input: HDA Intel Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[ 5.433380] snd_hda_intel 0000:02:00.1: PCI INT B -> GSI 16 (level, low) -> IRQ 16
[ 5.433399] hda_intel: Disabling MSI
[ 5.433567] snd_hda_intel 0000:02:00.1: setting latency timer to 64
[ 6.309998] r8168: eth0: link up
[ 6.310738] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 6.513427] HDMI status: Codec=0 Pin=5 Presence_Detect=0 ELD_Valid=0
[ 6.540069] HDMI status: Codec=1 Pin=5 Presence_Detect=0 ELD_Valid=0
[ 6.566737] HDMI status: Codec=2 Pin=5 Presence_Detect=0 ELD_Valid=0
[ 6.593409] HDMI status: Codec=3 Pin=5 Presence_Detect=0 ELD_Valid=0
[ 6.607079] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1c.3/0000:02:00.1/sound/card1/input9
[ 6.607441] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1c.3/0000:02:00.1/sound/card1/input10
[ 6.607748] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1c.3/0000:02:00.1/sound/card1/input11
[ 6.608058] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1c.3/0000:02:00.1/sound/card1/input12
[ 6.609588] nvidia 0000:02:00.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
[ 6.609614] nvidia 0000:02:00.0: setting latency timer to 64
[ 6.609626] vgaarb: device changed decodes: PCI:0000:02:00.0,olddecodes=io+mem,decodes=none:owns=io+mem
[ 6.610472] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 295.71 Thu Aug 2 19:22:08 PDT 2012
[ 6.776697] r8168: eth0: link up
[ 11.222286] EXT4-fs (sda1): re-mounted. Opts: barrier=1,stripe=4,data=ordered,commit=0
[ 11.441942] EXT4-fs (sda2): re-mounted. Opts: barrier=1,data=ordered,commit=0
[ 18.016687] eth0: no IPv6 routers present
Could you please post a full "dmesg" output ?
Little update: some people @ LinuxTV.org website are working to support this kind of devices :)
I don't know the state-of-the-art but I will verify shortly if there is the possibility to use it on our boxes.
Any news on that USB DVB S2 device? Is it worth the gamble to buy it?
Alright angleofsky1980 happy new year!
Quick question when ya have the time,
I have a winTV t stick was working fine, I bought a tevii S2 USB tuner its working spot on on my Duo BH1.79 but now it does not recognise my DVB-T stick can the Duo only allow one USB tuner at a time?
Some driver combinations are very unstable :(
My AC power for teVii is broken :( and I need to replace it before do some tests :(
You can try to use an external powered hub USB .... can be a power problem if you use the two rear ports for USB tuners.
Yep I think I may of mentioned this before but my USB ports don't respond to anything unless the devices have their own power supply that's an on going problem and I haven't got a clue how to fix it unless some one has an answer
So both S2 and DVBT tuners have their own power supply both it will only identify one at a time!
What DVB-T device do you have?
