USB Tuner: AF9015 devices
dont work...
USBTuner v0.2.6 started Sat Jan 1 01:01:16 2000
Log file in use: /tmp/usbtuner.log
PID: 0 --- SID: 852
Box in use: dm8000
Video Delay: ACF0 --- Audio Delay: ACF0
Open device /dev/dvb/adapter1/frontend0
Device Name: Afatech AF9013 DVB-T
i have it back usb
dvb-usb: found a 'AverMedia AVerTV Volar Black HD/HD+ (A850)/(A850+)' in cold state, will try to load a firmware
dvb-usb: downloading firmware from file 'dvb-usb-af9015.fw'
dvb-usb: found a 'AverMedia AVerTV Volar Black HD/HD+ (A850)/(A850+)' in warm state.
dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
DVB: registering new adapter (AverMedia AVerTV Volar Black HD/HD+ (A850)/(A850+))
af9013: firmware version:5.1.0
DVB: registering adapter 1 frontend 0 (Afatech AF9013 DVB-T)...
MXL5005S: Attached at address 0xc6
dvb-usb: AverMedia AVerTV Volar Black HD/HD+ (A850)/(A850+) successfully initialized and connected.
usbcore: registered new driver dvb_usb_af9015
0x33428f00 0xa5f0780 0xc01b2eaf 0x0 0x0 0x2
DVB: registering adapter 0 frontend 0 (Afatech AF9013 DVB-T)...
that is?
I am testing an AF9015 compatible device, sold as "Crypto Redi PC 50". This stick was reported working on old Dream Elite image for Dreambox but I personally haven't tested it back then. Now trying to work on VU.
Stick is detected, driver loads fine, but when trying to tune I get many error messages in dmesg
af9015: command failed:1
mxl5007t_write_regs: 494: failed!
mxl5007t_tuner_init: error -140 on line 548
mxl5007t_set_params: error -140 on line 676
mxl5007t_soft_reset: 528: failed!
mxl5007t_tuner_init: error -140 on line 541
etc etc
device details
T: Bus=01 Lev=01 Prnt=01 Port=01 Cnt=02 Dev#= 3 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=15a4 ProdID=9016 Rev= 2.00
S: Manufacturer=Afatech
S: Product=DVB-T 2
S: SerialNumber=010101010600001
C:* #Ifs= 2 Cfg#= 1 Atr=80 MxPwr=500mA
I: If#= 0 Alt= 0 #EPs= 4 Cls=ff(vend.) Sub=00 Prot=00 Driver=dvb_usb_af9015
E: Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=84(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=85(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I: If#= 1 Alt= 0 #EPs= 1 Cls=03(HID ) Sub=00 Prot=01 Driver=dvb_usb_af9015
E: Ad=83(I) Atr=03(Int.) MxPS= 64 Ivl=64ms
Any hint?
etc etc
device details
S: Product=DVB-T 2
Any hint?
We need the complete dmesg to try to determine what revision of MXL5007T tuner your device use.
I will post later dmesg from VU Duo, but for now I want to add that this tuner was not working with ubuntu 10.10 and latest ubuntu kernel (2.6.35). There was a message "problem af9015: tuner id:177 not supported, please report!". Then I downloaded latest v4l drivers from hg repository, http://linuxtv.org/hg/v4l-dvb , compiled and installed and usb stick works fine. In dmesg, the info about tuner is the following:
[ 48.142238] dvb-usb: found a 'Afatech AF9015 DVB-T USB2.0 stick' in cold state, will try to load a firmware
[ 48.151979] dvb-usb: downloading firmware from file 'dvb-usb-af9015.fw'
[ 48.221042] dvb-usb: found a 'Afatech AF9015 DVB-T USB2.0 stick' in warm state.
[ 48.221110] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[ 48.221435] DVB: registering new adapter (Afatech AF9015 DVB-T USB2.0 stick)
[ 48.267287] af9013: firmware version:4.95.0.0
[ 48.271276] DVB: registering adapter 0 frontend 0 (Afatech AF9013 DVB-T)...
[ 48.297744] mxl5007t 5-00c0: creating new instance
[ 48.300053] mxl5007t_get_chip_id: unknown rev (3f)
[ 48.300060] mxl5007t_get_chip_id: MxL5007T detected @ 5-00c0
[ 48.300799] Registered IR keymap rc-empty
[ 48.300917] input: IR-receiver inside an USB DVB receiver as /devices/pci0000:00/0000:00:1d.7/usb2/2-1/rc/rc0/input8
[ 48.300999] rc0: IR-receiver inside an USB DVB receiver as /devices/pci0000:00/0000:00:1d.7/usb2/2-1/rc/rc0
[ 48.301019] dvb-usb: schedule remote query interval to 500 msecs.
[ 48.301025] dvb-usb: Afatech AF9015 DVB-T USB2.0 stick successfully initialized and connected.
[ 48.309488] usbcore: registered new interface driver dvb_usb_af9015
[ 48.309492] usbcore: registered new interface driver usbhid
[ 48.309496] usbhid: USB HID core driver
So, it seems this is some MXL5007T unknown revision (3f) that works fine with latest drivers.
I have a device with SAME tuner who is on the SAME revision :D
I will try to add the new tuner on the AF9015 driver.... please be patient :)
So, people who reported that Crypto Redi PC 50 was working with old dream-elite drivers must have had some older revision of this stick with different tuner. This seems to be a very new revision. There is no rush, I have the Crypto Redi PC 100 (smsusb) to use till this is also supported!
It's possible that old hw revisions of Crypto 50 devices uses a different tuner, but I will try to implement correctly the new device revision :)
I have dreambox 800, how to deal with the "TUNER" FAILED "to the DVB-T channels
..... No external links...
cat /proc/bus/usb/devices
S: Product=DVB-T 2
I: If#= 1 Alt= 0 #EPs= 1 Cls=03(HID ) Sub=00 Prot=01 Driver=usbhid
__________________
