USB Tuner: AF9015 devices
Hello, I have TerraTec Cinergy T Stick Dual RC. It won't recognize in vu+duo. Dmesg will show:
"usb 2-1: new high speed USB device using brcm-ehci-1 and address 5
usb 2-1: configuration #1 chosen from 1 choice
input: Afatech DVB-T 2 as /class/input/input4
input: USB HID v1.01 Keyboard [Afatech DVB-T 2] on usb-ehci-brcm-1"
In ubuntu 11.10 it will recognize well. Ubuntu dmesg in attached file: Ubuntu_terratec.txt
Is there something what I'm doing wrong? I have istalled module af9015 as you can see in file: vu_lsmod.txt and firmware is present also: vu_firmware.txt
I will look into source code ....
I have problems with my USB tuner AF-9015 since BH 6.5. A lot of bitmapping. Not the same bitmapping as with bad signal but horizontal stripes of bitmaps. Looks like a problem in new drivers. Cannot download the old drivers anymore.
I have problem with af9015 on vu uno bh 1.7.0 and ubstuner driver 0.3.8, it's able to find only VHF channel and not UHF, any suggest? thank you.
I should make some tests..... but first I should find my AF9015 device..... I don't where is in my house....
I have an AF9015 for 99% ( or AF9005 - 1%)(this usb goo.gl/rhDzR ) On version 1.3.0 i was using the drivers below :
1. rapidshare.com/files/689144343/dm800-dvbt-af9015_14592-r001_del-1.tgz
or
2. rapidshare.com/files/509331405/dm800-dvbt-af9005_14592-r001_del.tgz
and working fine ,
now i have 1.6.6 and cannot activate my usb dongle... can i manually install one of those two drivers ? because i can only choose from predefined drivers to use.... please advice.
The AF9015 (second driver on list not working)
or
and working fine ,
I've removed the live links on your posts.
The links are for other boxes NOT SUPPORTED HERE and you cannot use them on Vu boxes.
You are using a very old image not yet supported. Upgrade it to a newer one.
