USB Tuner: AF9015 devices
but how can it get ready for the DVB-T SNR ?????:shocked:
Do we know some chinese brand to order one of these? the only chinese sticks i have so far is sinovideo which is ok and show the signal info but i want something better.
I have no idea about cheap chinese DVB-T USB tuners :(
I've bought an original Avermedia Aver Volar Black HD A850 for testing purposes only but I use other USB DVB-T tuner better than AF9015 devices like PCTV 74e or Hauppauge WinTV Nova-T Stick :)
Hello
In instaled new version BlackHole and i have big problem
Why not support my DVB-T tuner ??
Leadtek WinFast DTV Dongle Gold
In first page is write is supported this USB dongle....
But not
Hello
But not
On the first post is reported a list of POSSIBLE supported devices.
We don't have any USB DVB device to make tests.
The tested devices are reported with an OK near it's name.
If you have troubles with your device, please report some infos about it and we can try to support better it.
First of all, thanks to the team to make this posible.
I have the Avermedia Aver Volar Black HD A850 conected with my VU+ Duo and I find nearly all stations (in the north of spain), but some are missing (two frecuencies with 6 stations). I can find them with the original sorftware on my notebook and the same conected device, so i can exclude a signal problem. I can´t find them neither by searching manually on the frecuencies.
If someone has a idea i would apreciate it.
Thanks in advance.
yasxc
Thanks in advance.
yasxc
try the other frequencies, I found that scanning ALL frequencies 6, 7 + 8 mhz found other "missing" channels,
although connected to PC all spanish DTT frequencies are within 8 mhz,,very strange indeed...
saludos desde cantabria
Any experience at all on HYBRID (DVB-T/C) TUNERS. For example:
AVERMEDIA AVerTV Hybrid Volar HD H830 USB-stick
I would like to use both DVB-c & DVB-t tuners
Hello. I have bought a KWorld PlusTV Dual DVB-T Stick (DVB-T 399U) and works perfectly with BlackHole 1.6.6 and AF9015 driver. You can watch one channel and record another at the same time
regards
