USB Tuner: AF9015 devices
Hello Angelofsky1980,
I also have troubles to get my DVT-T stick to work. (It did work under 1.43 with a older usbhelper script).
Dmesg told me the following:
DVB: registering adapter 0 frontend 0 (Afatech AF9013 DVB-T)...
af9015: too much data; cmd:41 len:59
I2C write failed ret:-22 reg:00 len:59
Have you got any clue?
(I've tried single tuner directly connected to the VU Duo, with a powered hub, but no luck yet...)
(My problem is that the tuner does not tune... (During scanning is does not pickup any signal). The USB sticks are working on my notebook!
And I'm using the Avermedia VolarBlack HD A850/HD+ 850+ driver which worked with the older usbhelper script).
I will try my AverMedia Volar Black HD A850 (original stick) and report what happen.
I have tried it on Solo and works correctly (for general info of course).
I was wondering if it is possible to active the older version of the usbtuner tool (perhaps v0.2.9) so that at least one USB DVB-T tuner can work?
In my case I have a AF9015 chip which is using the tda18218 demodulator.
And this stick has worked with a older version of the usbtuner tool!
Or do you think that this demodulator will not work with future versions of the usbtuner tool?
With the release of BH 1.5 we have completed a big upgrade on DVB USB drivers.
Thanks for your report about TDA18218 demodulator. We will investigate around the problem.
I bought a usb dvb-t tuner "pin avid pctv solo" with af9015 chip that is a new product of pinnacle company and my vu+ solo recognized it by "aver media black hd" driver in tuner panel and show it as second tuner in setup->system->tuner configuration menu but it can not find any channel in both auto and manual search. what is the wrong?
please help me
thanks
please help me
thanks
Disconnect your device, reconnect it and post the output of
dmesg
command.
ok
usb 2-1: USB disconnect, address 2
af9015: bulk message failed:-22 (8/3)
af9013: I2C read failed reg:d417
af9015: bulk message failed:-22 (8/-2144272384)
af9015: bulk message failed:-22 (9/-2144665600)
mxl5007t_write_reg: 474: failed!
mxl5007t_sleep: error -140 on line 725
af9015: bulk message failed:-22 (9/0)
mxl5007t_sleep: error -140 on line 727
af9015: bulk message failed:-22 (8/-2144440832)
af9015: bulk message failed:-22 (8/100)
af9015: bulk message failed:-22 (8/131072)
af9013: I2C read failed reg:d730
out of order segment: rcv_next C016F7C0 seq C016F7F9 - C016FCC9
ofo requeuing : rcv_next C016F7F9 seq C016F7F9 - C016FCC9
thanks a lot
ok
thanks a lot
Your AF9015 device use the MXL5007T tuner.
It's very useful if you can restart your box and report the complete dmesg output because I need to know more details in the init of your DVB device.
Thanks
ok
I restarted the box and made the dmesg file with "dmesg >/tmp/dmesg " and attached dmesg.txt
thanks a lot
Your device is too new :( the MXL5007T tuner used is too recent (rev 3f) and is not (now) supported by Linux.
I've a similar device with same tuner and chip (MXL5007T and AF9015) but don't work at this time :(
I can confirm that this little piece of s... is working!!!
does this model dvb-t work on vu+ solo ?
this is a no name chinese cheap dvb-t dongle
Thanks
mehr43 imho stay away from that device just only for the adapter cable: i have one that looks the same and the antenna adapter cable is really bad.. you need to use some cianacrylic glue for keep it connected to the device...
hi dear angelofsky1980
i bought this dvb-t but it`s not work either :sad:
i attached dmesg file to this message .
please help me
thanks
I cannot help you at the moment.
The AF9015 driver will be more debugged by BH Team.
Thanks for your dmesg it's very useful.
