USB Tuner: AF9015 devices
Hello, Angelofsky1980
I wanted to ask whether the latest version of the Black Hole which will be published in this week (today there are new drivers for VU + DUO and a new original image), or in this latest version of Black Hole will have already improved my device drivers for device AF9015 device with a QT1010 tuner? Or did these drivers can occur at any time to download from a USB tuner panel?
USB DVB drivers are a separate download (from dedicated panel).
The drivers for your device already exists but some bugs are inside them.
I still have a problem with DVB-T USB AF9015. The channels of the receiver can watch freely, but as I begin to switch to other channels after a while I have a black screen, and helps only a full restart tuner VU + DUO - angelofsky1980 wrote yesterday I bought a USB hub. Today I bought this USB hub and still have the problem that when switching from the tuner DVB-T USB AF9015 after a while I have a black screen and helps only a full restart tuner VU + DUO - USB hub that I bought today is of course an external power supply. Do not know if it's not the fault of drivers for the AF9015. Please help.
Test with USB tuner connected on front USB connector.
Angelofsky,
It's not possible. Neither the rear or front USB tuner my my device AF9015 device with a QT1010 tuner is not working properly - when switching channels between MPEG4 and MPEG2 have a black screen and helps only a full restart VU + Duo. When the drivers for my my device AF9015 device with a QT1010 tuner will be corrected? Angelofsky1980 help me please.
I've updated the package on the BH server for AF9015 devices (updated DVB API).
I've make some tests with Vu+Solo and my Aver Volar Black HD A850 and works correctly.
And now I can confirm that BOTH my AF9015 DBT-T tuners with the tda18218 chip are working! (I'm recording and watching multipe DVB-T streams on several PC's in my network!
This is really wonderfull!!
(By the way; I've a VU DUO with a powered hub for my DVB-T sticks).
As soon if I've found some errors I'll let you (all) know but hopefully I won't find any :D
Next step is a DVB-C tuner ;-) (Besides the expensive SUNDEK tuners..)
Angelofsky1980,
Thank you very much for the great work on the drivers! Now my device AF9015 device with a QT1010 tuner works great! Thank you very much for the image Black Hole 1.5.1 and for the drivers for DVB-T tuners.
Dear Angelofsky1980
why signal level progressive bar (SNR) do not show the sinal level in all channels (shows zero )?
Dear Angelofsky1980
Now my device AF9015 device with a QT1010 tuner works perfectly but on all channels the signal SNR: 0%. Is it possible to fix it?
