VU+UNO and USB TUNER WINTV MINISTICK
Angelo, As if it's any help, USB driver version 0.32 with BH 1.6.2 or BH 1.6.2 BETA (don´t remember) works in Front USB panel ,but USB version 0.34 NO!! :(
Thanks very much
REgards from Spain
Angelo, Some news about this issue?
I don't understand because I bought a new Vu+uno. I though that Vu+uno could be better than my old vu+duo and the reality is that I don't have all the features which I had on Vu+duo...
I will be grateful if you solve this problem already.
Thank you very much.
I have the same problem with win-tv mini stick.
Install the driver fine but when I enable driver I get the message Sorry not compatible.
Please solve this problem.
Sorry for my bad english.
Thanks
Angelo, please tell me something about this issue...
Do we have to buy other tuner?
Thank you very much
I'm tryng some patches for the Siano (and Ministick too) drivers but I don't know if theyy works or not for the moment. I havn't applied all the patches needed.
For your info, I have tried again to download the driver and it does not work at this moment...
About how many time do you think it will be solved?
Thanks Angelo...
Angelo, please, could you send me usb turner 0.32 please or post a link to download? This version works in frontal usb......
Thanks for your work
Regards from Spain
Regards from Spain
On Duo and Solo the 0.3.4 release works without problem.
On Uno the problem there are the drivers and any kind of version I've tested doesen't work correctly :(
Thanks for your help again. I will buy another usb-dtt that works 100%. Any tested 100% in VuUno without zero problems?
Thanks very much again.
Regards from Spain
Regards from Spain
There are some devices who works without problem like Hauppauge WinTV Nova-T , Pinnacle PCTV 74e or AverMedia A867.
Angelo, any news of this issue?
For your info, I bougth a avertv volar hd and it doesn't work, when I do a search, 0 services appears...
Yes, avermedia Volar Green HD works correctly......Thanks again...and obviusly, waiting for WinTv MiniStick Driver fix....
Regards from Spain.
I need an info my friend.
Where are you connected the Ministick? Directly on box (front, back upper USB, back lower USB,) via Hub (specivy numbers of ports and where is connected the hub on box) .... Thanks!
In image 1.6.2 beta or 1.6.2 (dont remember) in FRONT USB DIRECTLY BOX....
If you need any otther info, plesae, tell me...
THANKS FOR YOUR WORK!!
Regards from SPAIN
Regards from SPAIN
Have you connected hub USB or any other kind of USB devices?
If YES, please connect the Ministick on the Hub and the hub on one USB port on the back of the box.
Thanks Angelo.But with Imagen 1.6.5? 1.6.2beta? any version?
Yes, I have 1 hub-usb only with Smartgo.
Tell me what you want to do ... and how do it!!
Seriously, Thanks for your time. :yahoo:
Any BH Version.
I would like to clarify me if the detection bug appear when the device is connected in certain conditions.
For example, my Uno has these USB devices connected:
Front: None
Back Upper port: None
Back Lower port: Hub 4 ports (Wifi, pendrive, smargo, pcsc)
If it's a similar configuration you have, you can try to connect the Ministick to Hub and report the "dmesg" output.
