usbtuner -VPost also the output of the following command:Code:usbtuner -V
Mine: 0.3.4Post also the output of the following command:Code:usbtuner -V
Mine: 0.3.4
Thanks Angelo
For your information angelo,
The driver I had while I maked the test was 0.3.5...
I think the problem is on this driver version...
Angelo, finally I reflash now 1.6.5 with dtt driver 0.3.5, and DON´T SERCH CHANNELSI will make some tests with my colleague admin who has a usb stick who use the same driver of Aver Green HD.
Could you please post or attach here the usbtuner log file? It's localized into USB stick or hdd (in this order)Angelo, finally I reflash now 1.6.5 with dtt driver 0.3.5, and DON´T SERCH CHANNELS
With 1.6.5 and dtt driver 0.3.4, ALL IS OK!!
I will come back to 1.6.5 0.3.4 driver.
Thanks a lot Angelo
Regards from Spain
Angelo, did you forget this two issues?
I need avertv green hd or hauppage wintv ministick working with Vu+uno....
Thanks a lot
I haven't forgotten the problems. We are making internal tests around these two devices.
But do you need some log from my side?
