VU+UNO and USB TUNER WINTV MINISTICK
Any news of this issue?
I've bought 4 TDT sticks, and none of these work on my vu+uno...
I don't find a TDT sticks that works correctly on my vu+uno.
Thanks a lot.
Thanks a lot.
What sticks have you bought?
The "problem" is into the box kernel and we have making some debug around this problem.
You know that doesn't work on my Vu+uno, there are more people with my problem and bh 1.6.5... You only must read the latest post...
yeah, of course!! In your VuUno dont work, but in mine works 100%, So I want Angelo compare it, to see what is the difference.....ok?
AverMedia Volar Green HD works 1000% in my VuUno at least....
Dear users, please specify where are you connected your DVB USB Aver Green HD.
Your device is the same product then it must be do same thing on the same model box.
My Tdt-usb is unplugged to usb-hub connected with smargo in back on top, It´s powerself.
Thanks Angelo.!
?¿?¿?¿could be voltage port problem?¿?¿?¿?¿
Same usb-dtt
Same firmware (usb-dtt) and revision
Same imagen 1.6.5
Same drivers beta (04-10-2011) and FPGA Beta (4.1)
Any idea Angelo?
Thanks again!!
Same usb-dtt
Same imagen 1.6.5
Any idea Angelo?
Thanks again!!
It's a possibility.
The use who had problems should use a powered hub USB.
Could you please turn off your box, turn on it and when the image is loaded post the output of the command
dmesg
Thanks Angelo, but I don´t know if you know that MrCaptain's problem is that his avermedia volar green always find 0 channels when he search them!! Do you undertand me?
Avermedia Volar Green is detected 100% always...
Thanks again for your time!! ;)
Regards from Spain
PID hash table entries: 4096 (order: 12, 16384 bytes)
Found MIPS counter frequency: 203 Mhz
Using 202.501 MHz high precision timer.
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 302720k/524288k available (2899k kernel code, 221320k reserved, 557k data, 148k init, 0k highmem)
Calibrating delay loop... 402.43 BogoMIPS (lpj=201216)
Mount-cache hash table entries: 512
Checking for 'wait' instruction... available.
plat_prepare_cpus: ENABLING 2nd Thread...
TP0: prom_boot_secondary: Kick off 2nd CPU...
CPU revision is: 0002a044
FPU revision is: 00130001
Primary instruction cache 32kB, physically tagged, 2-way, linesize 64 bytes.
Primary data cache 64kB, 4-way, linesize 64 bytes.
Synthesized TLB refill handler (23 instructions).
Calibrating delay loop... 404.48 BogoMIPS (lpj=202240)
Brought up 2 CPUs
migration_cost=2000
NET: Registered protocol family 16
PCI->SDRAM window size: 512MB
SCSI subsystem initialized
usbcore: registered new driver usbfs
usbcore: registered new driver hub
PCI: found device 14e4:8602 on SATA bus, slot 0 (irq 42)
NET: Registered protocol family 2
IP route cache hash table entries: 16384 (order: 4, 65536 bytes)
TCP established hash table entries: 65536 (order: 7, 524288 bytes)
TCP bind hash table entries: 32768 (order: 6, 262144 bytes)
TCP: Hash tables configured (established 65536 bind 32768)
TCP reno registered
brcm-pm: disabling power to USB block
brcm-pm: disabling power to ENET block
brcm-pm: disabling power to SATA block
JFFS2 version 2.2. (NAND) (C) 2001-2006 Red Hat, Inc.
Initializing Cryptographic API
io scheduler noop registered
io scheduler anticipatory registered (default)
io scheduler deadline registered
io scheduler cfq registered
Serial: 8250/16550 driver $Revision: 1.90 $ 1 ports, IRQ sharing disabled
serial8250: ttyS0 at MMIO 0x0 (irq = 22) is a 16550A
loop: loaded (max 8 devices)
brcm-pm: enabling power to ENET block
Broadcom BCM7413 P21 Ethernet Network Device v2.0 Sep 7 2011 13:41:57
Config Internal PHY Through MDIO: 100 MB Full-Duplex (auto-neg)
bcmemac: no PHY detected on EMAC_1, disabling
blackhole initialised
Broadcom STB NAND controller (BrcmNand Controller)
i=0, CS[0] = 0
NAND_CS_NAND_XOR=00000001
Enable XOR on CS#0
brcmnand_probe: CS0: dev_id=ecf10095
After: NandSelect=40000101, nandConfig=15142200
NAND Config: Reg=15142200, chipSize=128 MB, blockSize=128K, erase_shift=11
busWidth=1, pageSize=2048B, page_shift=11, page_mask=000007ff
BrcmNAND mfg ec f1 Samsung K9F1G08U0A 128MB
Found NAND: ACC=f7ff1010, cfg=15142200, flashId=ecf10095, tim1=4232222d, tim2=00000d94
BrcmNAND version = 0x0302 128MB @00000000
Found NAND chip on Chip Select 0, chipSize=128MB, usable size=128MB, base=0x
brcmnand_scan: B4 nand_select = 40000101
brcmnand_scan: After nand_select = 40000101
ACC_CONTROL for SLC NAND: f7ff1010, eccLevel=15
SLC flash: ACC_CONTROL = f7ff1010
page_shift=11, bbt_erase_shift=17, chip_shift=27, phys_erase_shift=17
Brcm NAND controller version = 3.2 NAND flash size 128MB @18000000
mtd->oobsize=64, mtd->eccOobSize=16
brcmnand_scan: mtd->oobsize=64
brcmnand_scan: oobavail=50, eccsize=512, writesize=2048
brcmnand_scan, eccsize=512, writesize=2048, eccsteps=4, ecclevel=15, eccbytes=3
brcmnand_default_bbt: bbt_td = bbt_main_descr
Bad block table found at page ffc0, version 0x01
Bad block table found at page ff80, version 0x01
nand_read_bbt: Bad block at 0x01760000
nand_read_bbt: Bad block at 0x01ec0000
nand_read_bbt: Bad block at 0x02720000
nand_read_bbt: Bad block at 0x02de0000
nand_read_bbt: Bad block at 0x04000000
nand_read_bbt: Bad block at 0x055a0000
nand_read_bbt: Bad block at 0x071a0000
brcmnandCET: Status -> Deferred
numchips=1, size=8000000
nandinfo->brcmnand.CS[0] = 0
bcm7XXX_nand_parts=80336f08, bcm7XXX_new_partition=80336bb8, bcm7XXX_old_partition=80336d50
numParts=8
Part[0] name=rootfs, size=7200000, offset=0
Part[1] name=kernel, size=400000, offset=7200000
Part[2] name=boot, size=400000, offset=7600000
Part[3] name=splash, size=200000, offset=7a00000
Part[4] name=cfe, size=100000, offset=7c00000
Part[5] name=mac, size=80000, offset=7d00000
Part[6] name=env, size=80000, offset=7d80000
Part[7] name=nvm, size=100000, offset=7e00000
Creating 8 MTD partitions on "bcm7xxx-nand.0":
0x0000000000000000-0x0000000007200000 : "rootfs"
0x0000000007200000-0x0000000007600000 : "kernel"
0x0000000007600000-0x0000000007a00000 : "boot"
0x0000000007a00000-0x0000000007c00000 : "splash"
0x0000000007c00000-0x0000000007d00000 : "cfe"
0x0000000007d00000-0x0000000007d80000 : "mac"
0x0000000007d80000-0x0000000007e00000 : "env"
0x0000000007e00000-0x0000000007f00000 : "nvm"
usbmon: debugfs is not available
ehci_hcd_brcm_init: Initializing 2 EHCI controller(s)
brcm-pm: enabling power to USB block
10 Dec 2004 USB 2.0 'Enhanced' Host Controller (EHCI) Driver (EHCI-brcm-0)
drivers/usb/host/ehci-brcm.c: starting brcm EHCI USB Controller
- USB h/w setup mode <B>
- USB power enable set for active HIGH mode
brcm-ehci brcm-ehci.0: BRCM EHCI
brcm-ehci brcm-ehci.0: new USB bus registered, assigned bus number 1
brcm-ehci brcm-ehci.0: irq 62, io mem 0x10480300
brcm-ehci brcm-ehci.0: USB 0.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
10 Dec 2004 USB 2.0 'Enhanced' Host Controller (EHCI) Driver (EHCI-brcm-1)
brcm-ehci-1 brcm-ehci-1.1: BRCM EHCI
brcm-ehci-1 brcm-ehci-1.1: new USB bus registered, assigned bus number 2
brcm-ehci-1 brcm-ehci-1.1: irq 57, io mem 0x10480500
brcm-ehci-1 brcm-ehci-1.1: USB 0.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
ohci_hcd_brcm_init: Initializing 2 OHCI controller(s)
2005 April 22 USB 1.1 'Open' Host Controller (OHCI) Driver (OHCI-brcm-0)
drivers/usb/host/ohci-brcm.c: starting brcm OHCI USB Controller
- Resetting at b0480408
brcm_start_hc
brcm-ohci-0 brcm-ohci-0.0: BRCM OHCI
brcm-ohci-0 brcm-ohci-0.0: new USB bus registered, assigned bus number 3
brcm-ohci-0 brcm-ohci-0.0: irq 63, io mem 0x10480400
usb 1-2: new high speed USB device using brcm-ehci and address 2
usb usb3: configuration #1 chosen from 1 choice
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
2005 April 22 USB 1.1 'Open' Host Controller (OHCI) Driver (OHCI-brcm-1)
- Resetting at b0480608
brcm_start_hc
brcm-ohci-1 brcm-ohci-1.1: BRCM OHCI
brcm-ohci-1 brcm-ohci-1.1: new USB bus registered, assigned bus number 4
brcm-ohci-1 brcm-ohci-1.1: irq 64, io mem 0x10480600
usb 1-2: configuration #1 chosen from 1 choice
usb usb4: configuration #1 chosen from 1 choice
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 2 ports detected
TCP bic registered
Empty flash at 0x03502a40 ends at 0x03503000
Empty flash at 0x037b4820 ends at 0x037b5000
Empty flash at 0x05f9cac8 ends at 0x05f9d000
VFS: Mounted root (jffs2 filesystem).
Freeing unused kernel memory: 148k freed
JFFS2 notice: (20) check_node_data: wrong data CRC in data node at 0x037b4800: read 0x6942978e, calculated 0x76388f98.
libata version 2.00 loaded.
brcm-pm: enabling power to SATA block
sata_svw 0000:01:00.0: version 4.0
PCI: Enabling device 0000:01:00.0 (0000 -> 0003)
ata1: SATA max UDMA/133 cmd 0xB0510000 ctl 0xB0510020 bmdma 0xB0510030 irq 42
ata2: SATA max UDMA/133 cmd 0xB0510100 ctl 0xB0510120 bmdma 0xB0510130 irq 42
scsi0 : sata_svw
ata1: SATA link down (SStatus 4 SControl 300)
ATA: abnormal status 0x7F on port 0xb051001c
scsi1 : sata_svw
ata2: SATA link down (SStatus 4 SControl 300)
ATA: abnormal status 0x7F on port 0xb051011c
i2c /dev entries driver
procmk_init
dvb_bcm7413: module license 'Proprietary' taints kernel.
DVB: registering new adapter (vuuno)
enable MII = 0
Booted !
NEXUS_Frontend_GetUserParameters 0 0
bcm7335: hotplug_callback():
Hotplug - status.connected 1
Hotplug - connecting HDMI to display 0xe
[GPIO]Default
[GPIO]RST Default
[GPIO]fpga secu
[GP]:brcm_pwm_init
brcm_demux_init: $Id: bcm7335_demux.c,v 0.6 $
[VID]: <6>bcm7335_video_init
[AUD]: <6>bcm7335_audio_init
DVB: registering adapter 0 frontend 0 (Vuplus FE)...
bcm7335: bcm7335_frontend_init(): vtuner1 : 2
[MPVR]: >> misc_pvr_init
input: dreambox advanced remote control (native) as /class/input/input0
[LCD]: registered
[CI]:0 1
[CI]: registered ci0 0
[CI]: registered ci1 0
[DFP]: registered dbox fp
[DFP]: Scart 9597 is found 4
[SC]: registered sci0
[SC]: registered sci1
system_time_set wakeup mode get
system_time_set wakeup mode get 0xc4
fpga update driver loaded
Initializing USB Mass Storage driver...
usbcore: registered new driver usb-storage
USB Mass Storage support registered.
NTFS driver 2.1.27 [Flags: R/W MODULE].
[VID]: VIDEO_SET_STREAMTYPE 0
[VID]: VIDEO_SELECT_SOURCE 1
[VID]: VIDEO_PLAY 1 2 0
[VID]: VIDEO_CONTINUE 1 1
[VID]: VIDEO_CLEAR_BUFFER 1 1 0
[VID]: VIDEO_STOP 0 1
[VID]: VIDEO_SELECT_SOURCE 0
bh_api: exports duplicate symbol bh_api_call (owned by kernel)
dvb-usb: found a 'Avermedia AverTV Volar HD (A835)' in cold state, will try to load a firmware
dvb-usb: downloading firmware from file 'dvb-usb-af9035-01.fw'
dvb-usb: found a 'Avermedia AverTV Volar HD (A835)' in warm state.
dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
DVB: registering new adapter (Avermedia AverTV Volar HD (A835))
af9033: firmware version: LINK:11.15.10.0 OFDM:5.48.10.0
DVB: registering adapter 1 frontend 0 (Afatech AF9033 DVB-T)...
tda18218: NXP TDA18218HN successfully identified.
dvb-usb: Avermedia AverTV Volar HD (A835) successfully initialized and connected.
usbcore: registered new driver dvb_usb_af9035
[LCD]: unknown cmd 0x1015
[CI]:ci_dev_open
[CI]:Opening A GPIO's for 7335 platform
[CI]:Opening A GPIO's for 7335 platform....done
[CI]:entering.. A NEXUS_DvbCi_Open
[CI]:NEXUS_DvbCi_Open done..
[CI]:Installing callbacks
[CI]:Forcing card check
[CI]:Card insertion status changed
[CI]:Opening B GPIO's for 7335 platform
[CI]:Opening B GPIO's for 7335 platform....done
[CI]:entering.. B NEXUS_DvbCi_Open
[CI]:Card B insertion status changed
[CI]: CI interface initialised
[CI]:ci1_dev_open
[AUD]: AUDIO_SET_MUTE 0
[AUD]: AUDIO_SET_MIXER -2118779424
[AUD]: AUDIO_SET_MIXER : amixl 0, amixr 0
[AUD]: AUDIO_SET_MIXER : next left volume 0, right volume 0
[AUD]: AUDIO_SET_MIXER : next left volume -70, right volume -70
[AUD]: AUDIO_SET_MIXER : amixl 54, amixr 54
[AUD]: AUDIO_SET_MIXER : next left volume -3927, right volume -3927
FE tune
dvb_demux_feed_del: feed not in list (type=0 state=0 pid=ffff)
[AUD]: AUDIO_SET_BYPASS_MODE 0
[AUD]: AC3 proc_get_ac3 0 audio_passthrough_spdif : 0
[AUD]: AUDIO_PAUSE 1
[AUD]: AUDIO_PLAY 1 decoder start : 0
[AUD]: bcm7335->audio_dec_ss.codec 7
[VID]: VIDEO_SET_STREAMTYPE 1
[VID]: VIDEO_FREEZE 1 0
[VID]: VIDEO_PLAY 1 5 2
[VID]: VIDEO_SLOWMOTION 0 1
[VID]: VIDEO_FAST_FORWARD 0 1
[AUD]: AUDIO_CONTINUE 1 1 audio pid_hndl : 0xc0b25564
[AUD]: setting mute : 0
[AUD]: AUDIO_CHANNEL_SELECT 0
out of order segment: rcv_next E170820C seq E17087B4 - E1708D54
out of order segment: rcv_next E170820C seq E1708D54 - E17092F4
out of order segment: rcv_next E170820C seq E17092F4 - E17095C2
ofo requeuing : rcv_next E17087B4 seq E17087B4 - E1708D54
ofo requeuing : rcv_next E1708D54 seq E1708D54 - E17092F4
ofo requeuing : rcv_next E17092F4 seq E17092F4 - E17095C2
out of order segment: rcv_next E42049EB seq E4204F93 - E4205533
out of order segment: rcv_next E42049EB seq E4205533 - E420553B
out of order segment: rcv_next E42049EB seq E420553B - E4205ADB
out of order segment: rcv_next E42049EB seq E4205ADB - E420607B
ofo requeuing : rcv_next E4204F93 seq E4204F93 - E4205533
ofo requeuing : rcv_next E4205533 seq E4205533 - E420553B
ofo requeuing : rcv_next E420553B seq E420553B - E4205ADB
ofo requeuing : rcv_next E4205ADB seq E4205ADB - E420607B
out of order segment: rcv_next 289897FB seq 28989D9B - 28989EAB
ofo requeuing : rcv_next 28989D9B seq 28989D9B - 28989EAB
out of order segment: rcv_next E420A0E6 seq E420A686 - E420A6EE
ofo requeuing : rcv_next E420A686 seq E420A686 - E420A6EE
out of order segment: rcv_next D3F1DE4A seq D3F1DE73 - D3F1DE74
ofo requeuing : rcv_next D3F1DE73 seq D3F1DE73 - D3F1DE74
out of order segment: rcv_next 4616D285 seq 4616D825 - 4616DAD7
ofo requeuing : rcv_next 4616D825 seq 4616D825 - 4616DAD7
out of order segment: rcv_next 9C8AE014 seq 9C8AE01C - 9C8AE05B
out of order segment: rcv_next 9C8AE014 seq 9C8AE063 - 9C8AE0A2
ofo requeuing : rcv_next 9C8AE01C seq 9C8AE01C - 9C8AE05B
ofo requeuing : rcv_next 9C8AE063 seq 9C8AE063 - 9C8AE0A2
out of order segment: rcv_next 4616E245 seq 4616E7E5 - 4616EA50
ofo requeuing : rcv_next 4616E7E5 seq 4616E7E5 - 4616EA50
