Switch to new default skin MX HQ10
enigma2: No more use a separate skin.xml for solo4k
Default skin: Switch to MX HQ9
fix youtubetv/chromium bug
bump bh version
04/04/2016
support kodi (16.1 rc2)
04/03/2016
[Frontend] Fix lock fail for linked tuners
[SEC] Fix 0 byte recording issue in linked tuner
There is a new online update available to update to 3.0.2.A
This is available as an online update from 3.0.2 or as a full flash update.
Changes from 3.0.2:
12/04/2016
update driver(solo4k)
Add proc entry to support some unicable equipments(needs a Solo4k Misc. plugin)
Add proc encry for DVB-CI timing control(needs a Solo4k Misc. plugin)
Fix misc. bugs
[Solo4kMiscControl] add new plugin.
There is a new online update available to update to 3.0.2.C
This is available as an online update from 3.0.2(A or B)
Full flash files will be available soon.
Support customized subtitles.
- font color, size, opacity, edge style,
- background color, opacity,
- subtitle position, align, etc.
- add quick menu for subtitle
This update also adds OpenMultiboot to Solo4K
*** Please note that there is a compatibility issue with openBH 0.4, if you wish to use both BH and OBH, for the moment, you must run openBH 0.4 in Flash and BH 3.0.2.C in OpenMultiboot ***
*** Please note that there is a compatibility issue with openBH 0.4, if you wish to use both BH and OBH, for the moment, you must run openBH 0.4 in Flash and BH 3.0.2.D in OpenMultiboot ***
There is a new online update available to update 3.0.2.E
This is available as an online update from 3.0.2 (A,B,Cor D)
Full flash update files also available.
-Fix Subtitles Autolanguage
*** Please note that there is a compatibility issue with openBH 0.4, if you wish to use both BH and OBH, for the moment, you must run openBH 0.4 in Flash and BH 3.0.2.E in OpenMultiboot ***
There is a new online update available to update 3.0.2.F
This is available as an online update from 3.0.2 (A,B,C,D or E)
-Update Solo4K Drivers -Support fast channel change. -Update chromiumos and youtubetv. -Update libvugles2 and directfb
*** Please note that Fast Channel Change support is experimental, so any bugs that you find, please report, but do not demand fixes, as we will need to wait for Vu+ to fix any issue's ***
*** Please note that there is a compatibility issue with openBH 0.4 for Solo4K, if you wish to use both BH and OBH, for the moment, you must run openBH 0.4 in Flash and BH 3.0.2.F in OpenMultiboot ***
There is a new online update available to update 3.0.2.G
This is available as an online update from 3.0.2 (A,B,C,D,Eor F)
-Update cyrpt info
-Update feeds
-Update Menu.xml with missing entry ID's
There is a new online update available to update 3.0.2.H
This is available as an online update from 3.0.2 (A,B,C,D,E,F or G)
- Implement Menu Ordering
- Support for new Matrix10 Skins
There is a new online update available to update 3.0.2.I
This is available as an online update from 3.0.2 (A,B,C,D,E,F,Gor H)
This is a minor update, and is only available via online update
- Restore original menu layout for older skins
