What is the latest BlackHole version ?
The latest Black Hole image is 3.0.9.E Multistream
  • Remove Duplicate CrossEPG entry in menu
*** THIS IS ONLY AVAILABLE AS AN ONLINE UPDATE FROM 3.0.9 / 3.0.9.A / 3.0.9.B / 3.0.9.C / 3.0.9.D ***
***** IT IS RECOMMENDED TO ONLY USE BH 3.0.9.x IN OMB (OpenMultiboot) with Vu+ Solo, Duo, Uno models *****
The latest Black Hole image is 3.0.9.F Multistream
  • Add Support for Vu+ Zero Rev.2.0
*** THIS IS ONLY AVAILABLE AS AN ONLINE UPDATE FROM 3.0.9 / 3.0.9.A / 3.0.9.B / 3.0.9.C / 3.0.9.D / 3.0.9.E ***
**** AVAILABLE AS FULL FLASH FOR Vu+ ZERO ONLY, IF YOU HAVE NEW Vu+ ZERO REV.2.0 YOU MUST USE THE NEW 3.0.9.F FLASH FILE ****
The latest Black Hole image is 3.0.9.G Multistream
  • Add Support for spinner to be skin dependant
*** THIS IS ONLY AVAILABLE AS AN ONLINE UPDATE FROM 3.0.9 / 3.0.9.A / 3.0.9.B / 3.0.9.C / 3.0.9.D / 3.0.9.E / 3.0.9.F ***
The latest Black Hole image is 3.0.9.H Multistream
  • Add Support for BH Cron to use any script in /usr/script folder
  • Update encoding for new providers
*** THIS IS ONLY AVAILABLE AS AN ONLINE UPDATE FROM 3.0.9 / 3.0.9.A / 3.0.9.B / 3.0.9.C / 3.0.9.D / 3.0.9.E / 3.0.9.F / 3.0.9.G ***
The latest Black Hole image is 3.0.9.I Multistream
  • Add rtl8192eu rtl8812au rtl8814au Wi-Fi drivers
*** THIS IS ONLY AVAILABLE AS AN ONLINE UPDATE FROM 3.0.9 / 3.0.9.A / 3.0.9.B / 3.0.9.C / 3.0.9.D / 3.0.9.E / 3.0.9.F / 3.0.9.G / 3.0.9.H ***
The latest Black Hole image is 3.0.9.J Multistream
  • Update driver(duo4k)
- Fixed AAC-HE audio problem
- Fixed audio noise problem
- Cleaned up DVB-CI
*** THIS IS ONLY AVAILABLE AS AN ONLINE UPDATE FROM 3.0.9 / 3.0.9.A / 3.0.9.B / 3.0.9.C / 3.0.9.D / 3.0.9.E / 3.0.9.F / 3.0.9.G / 3.0.9.H / 3.0.9.I ***
The latest Black Hole image is 3.0.9.K Multistream
  • Fix Rytec Providers update in CrossEPG
*** THIS IS ONLY AVAILABLE AS AN ONLINE UPDATE FROM 3.0.9 / 3.0.9.A / 3.0.9.B / 3.0.9.C / 3.0.9.D / 3.0.9.E / 3.0.9.F / 3.0.9.G / 3.0.9.H / 3.0.9.I / 3.0.9.J ***
The latest Black Hole image is 3.0.9.L Multistream
  • update driver(duo4k)
    - Limit the PiP window size up to the one fourth of the main window
*** THIS IS ONLY AVAILABLE AS AN ONLINE UPDATE FROM 3.0.9 / 3.0.9.A / 3.0.9.B / 3.0.9.C / 3.0.9.D / 3.0.9.E / 3.0.9.F / 3.0.9.G / 3.0.9.H / 3.0.9.I / 3.0.9.J / 3.0.9.K ***
The latest Black Hole image is 3.0.9.N Multistream
  • Add support for Vu+ Turbo SE usb tuner.
*** THIS IS ONLY AVAILABLE AS AN ONLINE UPDATE FROM 3.0.9 / 3.0.9.A / 3.0.9.B / 3.0.9.C / 3.0.9.D / 3.0.9.E / 3.0.9.F / 3.0.9.G / 3.0.9.H / 3.0.9.I / 3.0.9.J / 3.0.9.K / 3.0.9.L / 3.0.9.M / 3.0.9.N ***
****** VU+ TURBO SE USB TUNER ONLY WORKS ON IMAGES IN OMB IF THE IMAGE IN FLASH HAS THE DVBSKY-CLASSIC DRIVER INSTALLED FIRST ******
The latest BlackHole image is 3.1.0 Multistream
  • Add Duo4K SE Support
  • Various bug fixed and tweaks in the background
*** THIS IS ONLY AVAILABLE AS A FULL FLASH UPDATE ***
***** IT IS RECOMMENDED TO ONLY USE BH 3.1.0 IN OMB (OpenMultiboot) with Vu+ Solo, Duo, Uno models *****
The latest BlackHole image is 3.1.0.A Multistream
  • [vuplus-wifi-util] fix SSID issue (Duo4K, Duo4K SE, Ultimo4K)
  • Update Russian Translation
*** THIS IS ONLY AVAILABLE AS AN ONLINE UPDATE FROM BH 3.1.0 ***
The latest BlackHole image is 3.1.0.B Multistream
  • Add support for Vu+ Turbo2 tuner
*** THIS IS ONLY AVAILABLE AS AN ONLINE UPDATE FROM BH 3.1.0 / 3.1.0.A***
***** IT IS RECOMMENDED TO ONLY USE BH 3.1.0.x IN OMB (OpenMultiboot) with Vu+ Solo, Duo, Uno models *****
The latest BlackHole image is 3.1.0.C Multistream
  • Fix OSD Transparency
*** THIS IS ONLY AVAILABLE AS AN ONLINE UPDATE FROM BH 3.1.0 / 3.1.0.A / 3.1.0.B ***
The latest BlackHole image is 3.1.0.D Multistream
  • Add vuplus-tuner-turbo2 driver. (solo2, duo2, solose, zero)
*** THIS IS ONLY AVAILABLE AS AN ONLINE UPDATE FROM BH 3.1.0 / 3.1.0.A / 3.1.0.B / 3.1.0.C ***
The latest BlackHole image is 3.1.0.E Multistream
  • Update Unicable.xml
*** THIS IS ONLY AVAILABLE AS AN ONLINE UPDATE FROM BH 3.1.0 / 3.1.0.A / 3.1.0.B / 3.1.0.C / 3.1.0.D ***
The latest BlackHole image is 3.1.0.F Multistream
  • Update Rytec Sources in CrossEPG
  • Add VM to cryptobar
*** THIS IS ONLY AVAILABLE AS AN ONLINE UPDATE FROM BH 3.1.0 / 3.1.0.A / 3.1.0.B / 3.1.0.C / 3.1.0.D / 3 .1.0.E ***
The latest BlackHole image is 3.1.0.I Multistream
  • Make Label and SelectionList compatible with OE-A plugins
*** THIS IS ONLY AVAILABLE AS AN ONLINE UPDATE FROM BH 3.1.0 / 3.1.0.A / 3.1.0.B / 3.1.0.C / 3.1.0.D / 3 .1.0.E / 3.1.0.F / 3.1.0.G / 3.1.0.H ***
