What is the latest BlackHole version ?
There is a new online update available to update 3.0.2.J
This is available as an online update from 3.0.2 (A,B,C,D,E,F,G,H or I)
This is a minor update, and is only available via online update
*** Please note that Fast Channel Change support is experimental, so any bugs that you find, please report, but do not demand fixes, as we will need to wait for Vu+ to fix any issue's ***
- Update drivers (Solo4K )
- Fix FCC problem (Solo4K)
- Add new FBC frontend proc interface (Solo4K)
The latest Black Hole image is 3.0.3.A
What is new ?
- Update default skin MX HQ10 to fix some plugin issues
- Update skin api to fix some plugin issues
- Update Unicable and Unicable II LNB support
This is available as an online update from 3.0.3 or as a full reflash.
The latest Black Hole image is 3.0.3.C
What is new ?
- update drivers(duo2, solo2, solose, zero)
- Fix refresh rate
- Fix FF in media playback
- Add more video codecs
- Add videomode_24hz proc entry(E2 update will follow)
- Fix misc.
This is only available as an online update from 3.0.3, 3.0.3.A or 3.0.3.B
The latest Black Hole image is 3.0.3.D
What is new ?
- Update default skin MX HQ10 to fix font issue's with Ultimo4K
- Update drivers (solo4k, uno4k, ultimo4k)
- Update libvugles2
- Update Satellites.xml, Cables.xml and Terrestrial.xml
- Update Danish, French, Italian, Lithuanian, Norwegian, Polish, Portuguese and Spanish translations
- Update epgcache for MHW2
- Update OpenWebif
This is available as an online update from 3.0.3, 3.0.3.A , 3.0.3.B or 3.0.3.C or as a fresh install
The latest Black Hole image is 3.0.3.G
What is new ?
- update drivers(uno4k, ultimo4k)
- Fix HDMI out problem(idle mode & wake up)
- Fix FBC DVB-C problem
- Fix pixelation problem(ultimo4k)
- Support 4K transcoding in idle mode
- Fix problem when there are 2 transcodings at the same time.(ultimo4k)
- Change recording resolution of HDMI-IN to fixed 720p (ultimo4k)
- update FCC plugin, Fix PIP issue due to FCC
- update FCC plugin, FCC is available only for dvb services (service type == 1)
- update autolanguage plugin to include: Ukrainian and Visual impaired commentary
- update Russian translations
- update usbtunerhelper to help with devices with unknown manufacturer
This is available as an online update from 3.0.3, 3.0.3.A , 3.0.3.B, 3.0.3.C, 3.0.3.D, 3.0.3.E or 3.0.3.F or as a fresh install
The latest Black Hole image is 3.0.3.H
What is new ?
- [gstreamer1.0-plugin-subsink] fix SRC_URI
- Support VUPLUS BLE RCU.
- update vuplus-bluetooth-util & bluetoothsetup.
- add new plugin wit.ai speech to text.
- [RcInput] handle key tape. (for VUPLUS BLE RCU)- update chromiumos to support bt-rcu.
- [webkit-hbbtv] update hbbtv.
- [linux-vuplus] enable usb serial device drivers for ARM receivers.
This is available as an online update from 3.0.3, 3.0.3.A , 3.0.3.B, 3.0.3.C, 3.0.3.D, 3.0.3.E, 3.0.3.F or 3.0.3.G or as a fresh install
The latest Black Hole image is 3.0.3.I
What is new ?
- Update Kodi 16.1 to 17.0 for ARM boxes only (Solo4K, Uno4K, Ultimo4K)
This is available as an online update from 3.0.3, 3.0.3.A , 3.0.3.B, 3.0.3.C, 3.0.3.D, 3.0.3.E, 3.0.3.F, 3.0.3.G, or 3.0.3.H
The latest Black Hole image is 3.0.3.L
What is new ?
- update drivers(duo2, solo2, solose, zero, solo4k, uno4k, ultimo4k)
- Fix DVB-T2 tuning problem(TT2L08)
- Support DVB-CI in vtuner
- Support scrambled playback(solo4k, uno4k, ultimo4k : E2 update will follow)
- Support Bluetooth(solo4k, uno4k : Needs USB Vu+ BT)
- Fix Misc.
This is available as an online update from 3.0.3, 3.0.3.A , 3.0.3.B, 3.0.3.C, 3.0.3.D, 3.0.3.E, 3.0.3.F, 3.0.3.G, 3.0.3.H or 3.0.3.I
The latest Black Hole image is 3.0.3.M
What is new ?
- [BluetoothSetup] update firmware of VUPLUS-BLE-RCU (v1.05)
- [RemoteControlCode] Setup new Vu+ Bluetooth RCU.
- Update default Skin (added Bluetooth and Wit.ai Speech to text)
- Update Norwegian and Polish Translations
This is available as an online update from 3.0.3, 3.0.3.A , 3.0.3.B, 3.0.3.C, 3.0.3.D, 3.0.3.E, 3.0.3.F, 3.0.3.G, 3.0.3.H, 3.0.3.I, or 3.0.3.L
The latest Black Hole image is 3.0.3.N
What is new ?
- [DVBCI] set tuner source A~R
- [DVBCI] Fix to work dvbci on vtuner.
- Support scrambled playback.
This is available as an online update from 3.0.3, 3.0.3.A , 3.0.3.B, 3.0.3.C, 3.0.3.D, 3.0.3.E, 3.0.3.F, 3.0.3.G, 3.0.3.H, 3.0.3.I, 3.0.3.L, or 3.0.3.M
The latest Black Hole image is 3.0.3.O
What is new ?
- Openwebif update to fix CVE 2017-9807
- update driver(ultimo4k)
This is available as an online update from 3.0.3, 3.0.3.A , 3.0.3.B, 3.0.3.C, 3.0.3.D, 3.0.3.E, 3.0.3.F, 3.0.3.G, 3.0.3.H, 3.0.3.I, 3.0.3.L, 3.0.3.M or 3.0.3.N
The latest Black Hole image is 3.0.3.P
What is new ?
- Fix DVB-T2 problem in single DVB-C/T2 tuner(SSH108)
- update libvugles2 (ultimo4k, uno4k, solo4k)
- Fix Transcoding issue (solose)
This is available as an online update from 3.0.3, 3.0.3.A , 3.0.3.B, 3.0.3.C, 3.0.3.D, 3.0.3.E, 3.0.3.F, 3.0.3.G, 3.0.3.H, 3.0.3.I, 3.0.3.L, 3.0.3.M, 3.0.3.N or 3.0.3.O
The latest Black Hole image is 3.0.4 Quad PiP
What is new ?
- Add Quad Picture in Picture support (Ultimo4K, Uno4K, Solo4K)
- Update CrossEPG to support new Rytec xz compression XMLTV listings
- Update CrossEPG to include latest Rytec Providers
- Update OpenWebif to fix Grab and WebTV
- Update Drivers (Ultimo4K, Uno4K, Solo4K, Duo2, SoloSE, Solo2, Zero)
- Fix FCC to work with usb tuners (Ultimo4K, Uno4K, Solo4K)
- Update Bluetooth Support (Ultimo4K, Uno4K, Solo4K)
- Update default skin to support Quad PiP
- Update Italian translations
This is available as a full flash update only
The latest Black Hole image is 3.0.4.A Quad PiP
What is new ?
Add option to disable mhw2 internal reader
(Blue button>>red>>red>>Enable Mhw2.. yes/no
Disable no, to enable again yes restart box)
This is available as an online update from BH 3.0.4
The latest Black Hole image is 3.0.4.D Quad PiP
What is new ?
- Update Norwegian Translations
- [chromium] fixed freezing bug.(ultimo4k)
- [chromium] fixed freezing issue when seeking a video.
- update drivers(solo4k, uno4k, ultimo4k)
- Add proc entries to support Amazon service
- Support vtuner and channel stream in QuadPiP(solo4k, uno4k, ultimo4k)
- Update drivers(uno, ultimo)
- Support TT2L08(uno, ultimo)
- Improve demux
- Fix misc.
*** ONLINE UPDATE WILL ONLY WORK FROM 3.0.4.C ***
The latest Black Hole image is 3.0.5 Quad PiP
What is new ?
- Update and fix CrossEPG
- Fix Timer recording bug
- Fix USB recording
- Add Overlayfs for new kernel (Uno4KSE, Zero4K)
- Add Uno4KSE support
- Add Zero4K support (beta)
- Add VP9 Support (Ultimo4K, Uno4KSE, Uno4K, Zero4K)
- Add Dvb-S2X support (Zero4K)
- Add Multistream/PLS support (Zero4K)
- Add Blindscan support (Zero4K)
- Update Drivers (Ultimo4K, Uno4KSE, Uno4K, Solo4K, Zero4K, Duo2, SoloSE, Solo2, Zero)
