What is the latest BlackHole version ?
The latest Black Hole image is 3.0.5.A Quad PiP
What is new ?
Update drivers(4k models)
- Fix demux problem
[bluetoothsetup/util] update for solo4k.
[vuplus-blindscan-utils] update TT2L08/TT3L10
[Scan] Fix DVB-T2 Network Scan. (need update libdvbsi++ 0.3.8)
- Fix HDR/HLG problem
- Fix grab problem
- Fix demux problem
- Improve overall performance
- Update kernel config
- Adjust driver memory allocations
update kodiegl/chromium/directfb.
[libdvbsi++] update to 0.3.8
[dvbmediasink] update EXTRA_OECONF (solo4k, uno4k, ultimo4k, uno4kse).
update driver(zero4k)
- Fix DVB-CI problem
- Fix PLS
This is available as an online update from 3.0.5 or as a full flash update.
The latest Black Hole image is 3.0.5.C Quad PiP
What is new ?
[vuplus-blindscan-utils] update for mips.
update drivers(duo2, solo2, solose, zero)
- Improve frontend(TT3L10, TT2L08)
- Improve demux
update drivers(4k models)
- Fix HDMI IN(ultimo4k, uno4kse)
- Fix demux(zero4k)
- Fix some proc entries in VideoEnhancement
This is only available as an online update from 3.0.5, 3.0.5.A or 3.0.5.B
The latest Black Hole image is 3.0.5.F Quad PiP
What is new ?
Fix harddisk bug
update drivers(uno4k, uno4kse, ultimo4k)
- Fix DiSEqC timing
- Support Dual DVB-S2X FBC tuner(needs E2 update)
update drivers(solo4k, uno4k, uno4kse)
- Fix media playback(24Fps)
Fix default recording path and usb recording.
[dvbapp] update.
[autofs] remove sync option for broken recording issue for ext4 filesystem.
[udev] fix automount
This is only available as a full flash update.
*** WARNING IF YOU TRY TO ONLINE UPDATE YOU WILL GET AN ERROR AND WE CAN NOT BE SURE YOU WILL NOT SUFFER STABILITY ISSUE'S, THEREFORE W RECOMMEND YOU DO NOT TRY TO ONLINE UPDATE ***
The latest Black Hole image is 3.0.5.H Quad PiP
What is new ?
Fix USB recording [uno4kse, zero4k , solo4k]
[linux-vuplus-3.14.28] increase PR.
[dvbapp] remove patches in bsp layer and cleanup unused patch files. (patches were applied to E2)
Support DVB-S2X for uno4k, ultimo4k, uno4kse.
update driver(ultimo4k)
- Fix delsys in DVB-S2X FBC tuner
[Blindscan] Support zero4k.
[AnimationSetup] fix default animation speed for uno4k, uno4kse, zero4k.
Support DVB-S2X
*** THIS IS ONLY AVAILABLE AS AN ONLINE UPDATE FROM BH 3.0.5.F ***
The latest Black Hole image is 3.0.5.J Quad PiP
What is new ?
[opera-hbbtv] update hbbtv
[dvbapp] increase PR.
update drivers(4k models) ...
[dvbapp] increase dvbapp PR.
[webkit-hbbtv] improve stability for some services.
[RecordTimer] fix calculate filename for missing return value.
support 2160p video(VP9) (4K models)
fix fullbackup on uno4kse
Add Relevant PIDs Routing. (for support Extra high bitrate in DVB-CI)
*** THIS IS ONLY AVAILABLE AS AN ONLINE UPDATE FROM BH 3.0.5.I ***
The latest Black Hole image is 3.0.5.K Quad PiP
What is new ?
[linux-vuplus-3.14.28] fix SRC_URI for patch. (add missing dvbs2x patch for uno4k, ultimo4k)
update drivers(duo2, solo2, solose, zero, zero4k)
[dvbci] Change the location to add vtuner pid.
*** THIS IS ONLY AVAILABLE AS AN ONLINE UPDATE FROM BH 3.0.5.I or 3.0.5.J ***
The latest Black Hole image is 3.0.5.L Quad PiP
What is new ?
branding-compat fix patch
[libvupl] add missing model
Remove IMAGE_FSTYPES ext4 from 4k models.
[directfb] fix segmentation fault on exit
[RemoteControlCode] fix default type
*** THIS IS ONLY AVAILABLE AS AN ONLINE UPDATE FROM BH 3.0.5.I, 3.0.5.J or 3.0.5.K ***
The latest Black Hole image is 3.0.6
What is new ?
Completely re-written the BH EPG system.
Added EPGImport support
Added FreeSat, Netmed, ViaSat and Virgin EPG
Updated Sky EPG
Added options to Load-Save-Delete epg.dat
Updated CrossEPG
Fixed DVB Subtitles issue on some channels
Swapped Buttons around in BH panels to match layout of other images
Various Skin updates from MX10
*** THIS IS AVAILABLE ONLY AS A FULL FLASH UPDATE ***
**** PLEASE NOTE FROM BH 3.0.6 onwards, we will no longer be supporting Vu+ Solo, Duo, Uno, Ultimo or Zero ****
The latest Black Hole image is 3.0.7
What is new ?
Many bug fixes
Added new feature to let you know when an online update is avaliable
Changed default Skin to MX Black Sea
New Bootlogo
New defualt Spinner
Improved Wi-Fi setup
Added Duo4K support
Reintroduced Support for Solo, Duo, Uno, Ultimo and Zero
*** THIS IS ONLY AVAILABLE AS A FULL FLASH UPDATE ***
***** IT IS RECOMMENDED TO ONLY USE BH 3.0.7 IN OMB (OpenMultiboot) with Vu+ Solo, Duo, Uno models *****
The latest Black Hole image is 3.0.8
What is new ?
Many bug fixes
Added Serviceapp with Exteplayer3
New Bootlogo
Updated Mediatree to support more USB tuners
Updated Duo4K Drivers
***** IT IS RECOMMENDED TO ONLY USE BH 3.0.8 IN OMB (OpenMultiboot) with Vu+ Solo, Duo, Uno models *****
The latest Black Hole image is 3.0.8.A
What is new ?
Fix VOD Skip Buttons
*** THIS IS ONLY AVAILABLE AS AN ONLINE UPDATE FROM BH 3.0.8 ***
***** IT IS RECOMMENDED TO ONLY USE BH 3.0.8.A IN OMB (OpenMultiboot) with Vu+ Solo, Duo, Uno models *****
The latest Black Hole image is 3.0.8.B
Fix Picons to work with IPTV
Added Streaminfo on 2nd infobar for IPTV
Fix suburi for youtube plugin (thx to taapat)
Updated Exteplayer3
Updated Drivers Duo4K
*** THIS IS ONLY AVAILABLE AS AN ONLINE UPDATE FROM BH 3.0.8 / 3.0.8.A ***
***** IT IS RECOMMENDED TO ONLY USE BH 3.0.8.B IN OMB (OpenMultiboot) with Vu+ Solo, Duo, Uno models *****
The latest Black Hole image is 3.0.8.C
Changed Default Skin to MX_SlimLine
Added NetSpeed info
Various tweaks behind the scenes
*** THIS IS ONLY AVAILABLE AS AN ONLINE UPDATE FROM BH 3.0.8 / 3.0.8.A / 3.0.8.B***
***** IT IS RECOMMENDED TO ONLY USE BH 3.0.8.C IN OMB (OpenMultiboot) with Vu+ Solo, Duo, Uno models *****
The latest Black Hole image is 3.0.9 Multistream
Support MIS with 45308X DVB-S2X Tuner (Ultimo4K, Duo4K, Uno4K SE, Uno4K)
Various background updates, tweaks and bug fixes.
Support DVB-C in Dual MTSIF DVB-T2 tuner (Ultimo4K, Duo4K, Uno4K SE, Uno4K)
** *Limitation : TS is broken when both tuners are in use, if one tuner is configured as DVB-C and the other is configured as DVB-T2.
*** THIS IS ONLY AS AVAILABLE AS A FULL FLASH UPDATE ***
***** I REPEAT THERE IS NO ONLINE UPDATE FROM ANY PREVIOUS BH VERSION TO 3.0.9 Multistream *****
***** IT IS RECOMMENDED TO ONLY USE BH 3.0.9 IN OMB (OpenMultiboot) with Vu+ Solo, Duo, Uno models *****
The latest Black Hole image is 3.0.9.A Multistream
  • update drivers(duo2, solo2, solose(v2), zero)
  • - Fixed demux(incorrect pid)
  • - Fixed DVB-CI init.
  • - Fixed Misc.
*** THIS IS ONLY AS AVAILABLE AS AN ONLINE UPDATE FROM 3.0.9 ***
The latest Black Hole image is 3.0.9.B Multistream
  • Fix bug in BH Weather (stop image crashing if your city is not available).
  • Update Exteplayer3 (you can not use subtitles with Exteplayer3 otherwise image will crash).
  • Add Astra-sm to feeds for T2-MI support (for boxes that support MIS only).
*** THIS IS ONLY AS AVAILABLE AS AN ONLINE UPDATE FROM 3.0.9 / 3.0.9.A ***
***** IT IS RECOMMENDED TO ONLY USE BH 3.0.9.x IN OMB (OpenMultiboot) with Vu+ Solo, Duo, Uno models *****
The latest Black Hole image is 3.0.9.C Multistream
  • Fix bug in downloader
  • Update CrossEPG
*** THIS IS AVAILABLE AS AN ONLINE UPDATE FROM 3.0.9 / 3.0.9.A/3.0.9.B OR AS A FULL FLASH UPDATE ***
The latest Black Hole image is 3.0.9.D Multistream
  • Add Avs stream support*
* Please note, this is experimental as we are unable to test this ourselves. If it works then great, but if any problems are reported we may have to remove this support.
*** THIS IS ONLY AVAILABLE AS AN ONLINE UPDATE FROM 3.0.9 / 3.0.9.A/3.0.9.B/3.0.9.C ***
