XBMC che non si avvia.
root@vusolo2:~# df -h
Filesystem Size Used Available Use% Mounted on
ubi0:rootfs 194.8M 138.0M 56.8M 71% /
devtmpfs 2.0M 92.0K 1.9M 4% /dev
tmpfs 279.9M 240.0K 279.6M 0% /var/volatile
udev 2.0M 92.0K 1.9M 4% /dev
tmpfs 279.9M 0 279.9M 0% /dev/shm
/dev/sda1 7.0G 22.9M 7.0G 0% /media/hdd
root@vusolo2:~# fdisk -l
Disk /dev/mtdblock0: 235 MB, 235929600 bytes
255 heads, 63 sectors/track, 28 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Disk /dev/mtdblock0 doesn't contain a valid partition table
Disk /dev/mtdblock1: 235 MB, 235929600 bytes
Disk /dev/mtdblock1 doesn't contain a valid partition table
Disk /dev/mtdblock2: 7 MB, 7340032 bytes
255 heads, 63 sectors/track, 0 cylinders
Disk /dev/mtdblock2 doesn't contain a valid partition table
Disk /dev/mtdblock3: 1 MB, 1048576 bytes
Disk /dev/mtdblock3 doesn't contain a valid partition table
Disk /dev/sda: 7759 MB, 7759462400 bytes
239 heads, 62 sectors/track, 1022 cylinders
Units = cylinders of 14818 * 512 = 7586816 bytes
Device Boot Start End Blocks Id System
/dev/sda1 1 1022 7571997+ 83 Linux
root@vusolo2:~#
non occorre spegnerlo da dietro
da telnet:
init 4
init 3
si DEVE avviare anche senza la penna, solo che si installa nella flash, che NON va bene!!
ok da adesso faccio cosi anzichè spegnerlo da dietro..se si deve avviare anche senza la penna potevo evitare di provare un altra chiavetta..
Ora, da telnet:
enigma2
poi lanci xbmc
copia cosa ne esce ...
su schermo nero, sempre da telnet:
init 4
poi
init 3
si riavvia enigma senza spegnerlo da dietro !
^H^Haction -> InfobarMenuActions mainMenu
loading mainmenu XML...
BhRed BhRedp_main
BhSettings DeliteSettings
PluginBrowser PluginBrowser
BhAddons DeliteAddons
BhEpgPanel DeliteEpgPanel
TimerEdit TimerEditList
allocating new converter!
action -> OkCancelActions ok
okbuttonClick
warning, skin is missing element green in <class 'Screens.PluginBrowser.PluginBr
owser'>
action -> WizardActions ok
[ ERROR] socket() fail : [Errno 125] Address already in use
stopService
Looking for embedded skin
Exception in thread Thread-3:
File "/usr/lib/python2.7/threading.py", line 552, in __bootstrap_inner
self.run()
File "/usr/lib/enigma2/python/Plugins/Extensions/XBMC/pipc.py", line 113, in r
un
self.mSock.listen(1)
File "/usr/lib/python2.7/socket.py", line 224, in meth
return getattr(self._sock,name)(*args)
error: [Errno 22] Invalid argument
-----------------+ XBMC ENVIRONMENTS +
+ CRASHLOG_DIR : /media/hdd
+ HOME : /media/hdd
+ HDD_MOUNT_POINT : /dev/sda1 /media/hdd ext3 rw,relatime,errors=continue,user
_xattr,barrier=1,data=ordered 0 0
Could not init logging classes. Permission errors on ~/.xbmc (/media/hdd/.xbmc/t
emp/)
ERROR: Unable to create application. Exiting
It's now Thu Jan 1 01:24:51 1970
[timer.py] next activation: 1591 (in 99998 ms)
It's now Thu Jan 1 01:26:31 1970
[timer.py] next activation: 1691 (in 99999 ms)
[timer.py] next activation: 1691 (in 99998 ms)
It's now Thu Jan 1 01:28:10 1970
[timer.py] next activation: 1791 (in 99999 ms)
It's now Thu Jan 1 01:28:11 1970
[timer.py] next activation: 1791 (in 99998 ms)
It's now Thu Jan 1 01:29:51 1970
[timer.py] next activation: 1891 (in 99999 ms)
[timer.py] next activation: 1891 (in 99998 ms)
It's now Thu Jan 1 01:31:31 1970
[timer.py] next activation: 1991 (in 99998 ms)
[timer.py] next activation: 1991 (in 99996 ms)
Scoperto l'arcano mistero allora!
XBMC via SCART non va!
non c'è soluzione nemmeno tramite un cavo hdmi -scart? collegando hdmi sul decoder e scart sulla tv? :(
tipo questo
http://www.amazon.it/gp/product/B00J7OHTGI?keywords=cavo hdmi scart&qid=1444165221&ref_=sr_1_4&s=electronics&sr=1-4
Non esiste un cavo in questo modo..esiste un adattatore attivo da HDMI a scart...
nel pmio post precedente a questo l'ho editato inserendo il link..controlla..ho letto che è valido anche per ps4 e xbox one, bisogna vedere se nel nostro caso risolve il problema..secondo voi?
Quello che hai linkato e un cavo HDMI-DVI
Ovvero da digitale con audio (HDMI) a digitale senza audio (DVI)
La scart è un tipo di connessione analogica...ovvio che serva un adattatore...
