MyMetrix-OpenStore BH 2.0.x
I got it, I did everything you say, and Gui rebooted, but still get out the translation. In the German language, there are two files the. po and. mo, will not be for that?
I'll leave the translation here
hxxps://dl.dropboxusercontent.com/u/47361066/es.rar
Ok, you've forgotten to save it, my poedit save it directly as MyMetrix.mo file.
However, I've tried your file, and it seems to working. But I see you have forgotten something.
Still german red button
Maybe you'll take a look again over MyMetrix.po file and upload it again. I'll adapt to the official BH package if its ready
Thank you very much. Great job!
@villak
I've just seen you have translated the buttos too, But its shows still in german, I'll take a look
maybe a complete Box restart will helps
regards
MyMetrix - OpenStore - Update 25.11.13
25.11.2013
- added ITALIAN language. Thx to @Mito
- added SPANISH language. Thx to @villak
- fixed RED Panel (Teleportation)
- added GUI restart after installation from BH Addon Server
- fixed SecondInfoBar Code (for this who want use SIB SkinParts)
- changed Green- and Blue Panel to 2layer Style
25.11.2013
We will test the update!
Have to uninstall the old one?
Thanks for your great job
Try to reboot your box, and retry.
Hi,
Reboot box did not help.
In the end I decided to start from scratch.
I re-installed BH 2.0.7.1, set it up and then installed MyMextrix from the Addon server.
It was working great.
The next day I went to install other plugins from the BH Addon server (Permanent timeshift, 1 channel).
Although they appeared to install they did not - Same problem, I can't download from the BH Addon server.
I can download and install from MyMetrix Openstore ok.
I'm banging my head against the wall.
I think you can overwrite it
Again, Thanks for your great work
Two things, I've reinstalled blackhole and I see the ClockToText.py for different languages is not implemented it?
And as I told you yesterday in Spanish language, ChannelName not show correct. (C+FÚTBOL)
Thanks for all!
Thanks for all!
ClockToText.py cannot be included because there is only one. If you need a change, then overwrite with file from this thread.
Spanish Translation -- The translation was for the MyMetrix Plugin and not for the OSD
Is what I assumed. ;)
I know that, I have not explained well, it's not problem of translation. I refer to Default widget ChannelName (IB) does not show the characters (')
But if we change the code in xml
(font = "SetrixHD; 140) by (font =" SetrixHD; 139) works well.
This could be implemented in the skin, to avoid having to do it manually every time?
You understand?
@villak
Yes, thats right, but SkinParts for IB are used as original from MyMetrix by iMaxx.
To fix this i've to add: BH - Default Channelname (IB)
But, feel free to register to OpenStore as developer and add your modification to public "BlackHole Suite"
@villak
That meant! Remove the default and make a skinkpart ChannelName BH (IB)
Edit: Developer How to register?
I'll change the default IB to BH Default IB
Registration.
Go to mymetrix.de and simply create a accout and mark it as developer account. After then you can add widgets and screens to public panels
Thanks , thanks, thanks, thanks, and thanks...
Now I try to make ChannelName EIB and upload it to OpenStore. If anyone wants to use it
Thank you again.
Anyway could you tell me how to publish in OpenStore? I am already registered as developer
What if I encourage you to modify any widget
I don't know if all this will be useful. The most useful widgets are working by default from Openstore.
BH - Default SkinParts are only configured to BH own Converters and Renderer, all other widgets don't need this.
Like I wrote some posts before, let us report working widgets from OpenStore, and configure for BH only this which are not working
