MyMetrix-OpenStore BH 2.0.x
No program info displayed on Astra 28. It works on the other satellites.
I tested your converter and green screen
Hi Villak,
I see in openStore 1 comments that it is not working and 1 that it is working !?! (I presume, because I use google translate... :P )
Strange?
As soon as I go home I will test it....
In the meantime, can anyone confirm if it is working and in which OSD language you are using?
Thanks
PS: Like I say I am not a pynthon coder, but using the dictionaries I defined in a small python program I tested online it was working!
Hi Villak,
I see in openStore 1 comments that it is not working and 1 that it is working !?! (I presume, because I use google translate... :p )
Strange?
Thanks
With the file of @capa, I tested all languages (IT, NL, ES, PT, DE and FR) and works perfectly
BH - CryptInfo optimized FTA (IB)
This is optimized Cryptinfo with optimized font size FTA (Infobar). For blackhole combined with BH - Default 4x TUNER Info (IB) by @capa, and ResolutionInfo
api
regards
1ST Thankz for your wrok but when i use your Cryptinfo(IB) NET is missing???
As Capa said he's got same as me.please can you tell us what,
'S included in cryptoinfo package?✅✅
Sent from my HTC One using Tapatalk
