MyMetrix-OpenStore BH 2.0.x
here my own XPicon for those people need one
His own Picon? All you have designed?
Regards
Enviado desde mi GT-I9505
@capa don't tested cryptoinfo.
The problem only you.
It can't work because you are using "ExtremeInfo.pyo" Converter to show the ECM Icons, again there is no FTA/NET/*** function
in ExtremeInfo.pyo. So it cannot work. Only FTA is showing well because its as default if no crypted channel watching.
Im an using BlackHole Converter/Renderer for (EIB) widgets. And this renderer are not working in the Default InfoBar.
You can use your Crypt Info, but delete the FTA/NET/*** option
regards
@capa you don't see info NET FTA in skinpart
As Capa said he's got same as me.please can you tell us what,
'S included in cryptoinfo package?✅✅
Sent from my HTC One using Tapatalk
you're absolutely right. Only shows NET, CARD, EMU with mg camd.
i checked source code:on STATUS only show
FTA EMU CRD NET i get only FTA other is not working
<!--  STATUS  -->
<widget source="session.CurrentService" render="FixedLabel" text="FTA" font="Regular; 20" position="508,671" size="50,22" halign="left" valign="center" backgroundColor="metrixBackground" zPosition="10" transparent="1">
<convert type="ExtremeInfo">Fta</convert>
<convert type="ConditionalShowHide"/>
</widget>
<widget source="session.CurrentService" render="FixedLabel" text="EMU" font="Regular; 20" position="508,671" size="50,22" halign="left" valign="center" foregroundColor="metrixForeground" backgroundColor="metrixBackground" zPosition="11" transparent="1">
<convert type="ExtremeInfo">Emu</convert>
</widget>
<widget source="session.CurrentService" render="FixedLabel" text="CRD" font="Regular; 20" position="508,671" size="50,22" halign="left" valign="center" backgroundColor="metrixBackground" zPosition="12" transparent="1">
<convert type="ExtremeInfo">Crd</convert>
</widget>
<widget source="session.CurrentService" render="FixedLabel" text="NET" font="Regular; 20" position="508,671" size="50,22" halign="left" valign="center" backgroundColor="metrixBackground" zPosition="13" transparent="1">
<convert type="ExtremeInfo">Net</convert>
</widget>
<!--  Crypt-Info */  -->
Works with ** ca**.
@capa said...
Works with ** ca**.
@capa said...
Read Forum Rules, Please! No emu's here!
Works with ** ca**.
@capa said...
I've checked the ExtremeInfo.pyo, all options are available, FTA/NET/***, you only need right usage of them
Hi @capa, a question, I have the same problem as the next picture, the numbers as 2 ... look bad, no chance to solve this as PLI?
api
api
This could be because you connected your receiver with your openStore account. If yes, then you've got an Update from OpenStore and all files was overwriten in mymetrix plugin.
"MyMetrix - OpenStore for BH" include changed font as default. Dont need PLi font fix.
If you'll reinstall MyMetrix the font will be fixed again.
As best is to deactivate AutoUpdate because i've included some fixes to MyMetrix for BH
@capa
In AMS pressing menu/buckup-restore settings i had a crash
File "/usr/lib/enigma2/python/skin.py", line 170, in loadPixmap
raise SkinError("pixmap file %s not found!" % (path))
skin.SkinError: {MetrixHD/skin.xml}: pixmap file /usr/share/enigma2/MetrixHD/buttons/button_yellow.png not found!
(PyObject_CallObject(<bound method ActionMap.action of <Components.ActionMap.ActionMap instance at 0x464be90>>,('OkCancelActions', 'ok')) failed)
Hi m8
I am using BH 2.0.7.3 in flash as well as meoboot with MyMetrix skin.
When I press Blue and Blue again and press Black Hole Speedup = I get a green screen (crash). Also I want to swap file setting, I cannot.
I changed to default skin and everything ok.
thank you very much, reinstalled and perfect, I disabled autoupdate
Enviado desde mi iPad con Tapatalk HD
