MyMetrix-OpenStore BH 2.0.x
@ all_users
Maybe it's possible to report which SkinParts from OpenStore are working 100%
all tested Parts will be listed in #1 Post
..:: Tested and working SkinParts from OpenStore
- Extended Volume Bar
- Hermes -MoviePlayer with Description
- Modern Style Movieplayer -- INFO
mmmmm i was looking the first post and all the menu and i was looking for widget infocam when in the middle of the screen is a window with the information regarding the program..
i went to the menu of the skin and couln't find it....
Look here #165 at the second picture, you can see all Active BH Parts. Downlaod, Activate, Build Skin, Restart Gui ...
Sorry,but now I have no icon bar, and no second infobar
If you have downloaded BH parts for EIB then
Please go to Menu->Settings->System->Second Info Bar and deactivate it.
Then you will have orginal BH ExtraInfoBar
UPDATE 21.11.13 - Download on BH Addon Server
!! Please uninstall old Skin as FIRST !!
21.11.13
+ added full Support for BH ExtraInfobar incl. all SkinParts (EIB)
+ added BlackHole SkinParts in OpenStore
- removed 2IB Plugin and SkinParts (SIB)
I can't figure out the strange behavior that I have with infobar ...
While watching press ok appears for a split second ... only to additional pressure appears on a regular basis, and depending on the set time ...
Everything every time I press ok to display infobar
21.11.13
Hi,
I installed from the BH addon server.
It said installed successfully, but nothing has been installed.
Am I doing something wrong?
Hi,
Before you create Skin with MyMetrix you have to go MyMetrix --> Settings and choose "BlackHole @capa Mod" as SkinTemplate.
After then save, and all will works
Hi,
Thanks for reply.
That isn't the problem -
After install there isn't a MyMetrix plug-in in my plugins folder and there is no MyMetrix skin for me to select in the skin settings.
If I connect to my Solo 2 with Filezilla there is no MyMetrix folder in /usr/share/enigma2.
So although my box says it installed it, it hasn't.
I have tried several times....
Hi,
Thanks for reply.
Install it then restart enigma it just happened to me... Will be in plugins then
